Old 11-01-2013, 12:36 PM
dodge dude94's Avatar
dodge dude94 dodge dude94 is offline
Originally Posted by culvercityclassic View Post
They are going in some custom frames
oooooo purdy. *drool*
2 WHEELS: '11 Huffy Good Vibrations, '11 Skyhawk GT5, 44t, CNSV2, NGK BPR7HIX, Bosch wire, shutupexhaust, 26x1.75kevlar tires, Tektro C230's, new stupid Bell chain
Old 11-01-2013, 12:43 PM
mapbike's Avatar
mapbike mapbike is offline
Yep that bike makes ya want to grin like a fifteen year old boy in love with the prettiest cheerleader in the squad..........
map
Old 11-01-2013, 12:50 PM
culvercityclassic's Avatar
culvercityclassic culvercityclassic is online now
Default
Thanks guys.... Another one in the raw, just clear coat
CulverCityClassic
wolfcreativecustoms.com
Old 11-01-2013, 01:04 PM
mapbike's Avatar
Talking Re: what did you do to your motorized bicycle today?
excellent......... making me wish I had my shop set up already, I have a GX200 196cc clone engine with several mods I plan to have on a bike in the future and I have two little grey hound 79cc engines still in the box new I plan to stick on bikes, when I have things set up to do better fabricating work......
beautiful bike man....... I love that raw industrial look, Bairdco has a couple bikes that have that look, just raw steel mill looking and I like it, just looks tough and mean....!
map
Old 11-01-2013, 02:36 PM
map
That's a good comparison.
I'd ride that. Most definitely.
Old 11-01-2013, 11:56 PM
Default
I worked on getting the carb adjusted on my latest ride... She flys now....
CulverCityClassic
Old 11-02-2013, 12:00 AM
xseler's Avatar
xseler xseler is offline
^^^ That's how I want my bike to turn out when she finally grows up!! ^^^
You're never lost until you run outa gas.
Old 11-02-2013, 07:33 PM
Default
I left the bike in the garage and rode a real one.... Malibu coast.... The weather was perfect....sorry to all you foul weather guys....
CulverCityClassic
Old 11-02-2013, 07:44 PM
CTripps's Avatar
CTripps CTripps is offline
I've been working on the new build (no thread for it yet, and my pc has decided it won't talk to my phone today, so no pics right now).
  • Front motor mount was widened successfully, it's a tight fit but that's fine
  • Sprocket's center hole was widened just enough to fit, and it's mounted.. (added bonus, 36 spoke wheels)
  • Motor is mounted
  • Muffler had to have the holes filed to clear the crank, done and installed
  • I'd raided this motor for the magneto coil some time ago. Pulled out a 'dead' magneto coil and went over it. Discovered the problem was where the coil is 'soldered' by the factory. Got that fixed, and it's within spec on the Ohm meter. (Feeling good about that). Removed the white wire, coil's installed in the motor now.
  • Pulled apart the front hub. On the outside, there was a layer of gunk that felt and looked like it'd been around a deep fryer.. thick and sticky. The inside of the hub was also had deposits of that gunk, and the bearings and races were solid with it. Cleaned everything out, wiped all the gunk off the bearings and so on. Repacked in green heavy duty axle grease, reassembled and installed the front wheel. Never opened up a hub before, it went pretty well.
  • Replaced the wire and boot on a CDI, haven't installed it yet.
So, let's see... that leaves
  • install CDI, throttle, clutch lever and cable
  • decide if I'm going to make a clutch roller or not
  • mount tank
  • install carb (probably pull that apart first to be sure it's clean), fuel line and filter
  • install chain (and roller if needed)
  • put the seatpost and seat back on
  • dig out a kickstand and give it a leg to stand on when it comes down out of the sling.
Not bad.. should be ready to test ride and tune pretty soon.
CT
Any day that starts with a good ride is already a better day, and a bad day riding still beats a good day working.
My Builds: My Beast, Harley59's bike, my Cruiser
Old 11-02-2013, 08:26 PM
truckd's Avatar
truckd truckd is offline
I drove out to see Dan (Taylar Motor Bikes) and the weather was absolutely Great, smells of fall in the air and blue sky's as well, GREAT! weather either on the coast or in the High Desert.
Tags
MotorBicycling.com
