Old 10-22-2013, 08:45 PM
xseler's Avatar
xseler xseler is online now
Did my first cylinder inspection this evening. Not too bad.......there is slight scuffing on the exhaust side, however, the cylinder still feels shiny smooth. Exhaust port is squeaky clean, but it still looks like it's running slightly rich. If I lean it down anymore than where it's at, it's a biotch to start. I guess I'll leave it where it's at for now.
This is at about 350 miles.
You're never lost until you run outa gas.
Old 10-22-2013, 09:31 PM
dodge dude94's Avatar
dodge dude94 dodge dude94 is offline
Looks way better than mine. I've got a nasty groove in my jug. Still runs good though. lol
2 WHEELS: '11 Huffy Good Vibrations, '11 Skyhawk GT5, 44t, CNSV2, NGK BPR7HIX, Bosch wire, shutupexhaust, 26x1.75kevlar tires, Tektro C230's, new stupid Bell chain
Old 10-23-2013, 09:38 AM
Cruise's Avatar
Cruise Cruise is offline
Marked out a template to both fab some ragjoints and re-drill a sprocket to suit a 68 spoke wheel.
Also discovered the brittle nature of the diecast clutch lever Assy as I tried to gently open the diameter of the handlebar hole a tiny amount. $nap !
Old 10-23-2013, 03:31 PM
Danschutz's Avatar
Danschutz Danschutz is offline
Finished the Puch head install last night, had to grind down the 1/4 14mm long socket to fit in there. When I looked at the head studs the two at the rear of the motor are straight but positioned forward in the block so when you put the head on those rear studs are even harder to fit a socket over.
Performance, way increased! It was 35 degrees outside last night when we went for a 30 minute ride and in the flat straights my buddy Brian was just inching away from me, but he has a 4.5 hp arrow motor and is about 70 pounds heavier.
Basically my motor went from topping out at around 22 mph (remember Im at 5200 ft elevation) and last night I was gaining mph going uphill and as I went by a lamppost I could see I was at 22 mph and climbing. Now I really need an exhaust!!!!
Dan.
Thanks, again Map!!!!!
Old 10-23-2013, 05:18 PM
mapbike's Avatar
mapbike mapbike is offline
Talking Re: what did you do to your motorized bicycle today?
Dan.
You're welcome Dan, Glad you're enjoying the added performance and of course the Puch head looks pretty cool in my opinion also, a good free flowing exhaust will add even more gain, just be sure to check the spark plug after you add a free flowing exhaust, dont want to have a lean run condition, if you're already a bit rich it may turn out to be a good tune for you but sure want to be for sure and not lean that engine to much.
Map
Old 10-23-2013, 05:43 PM
truckd's Avatar
truckd truckd is offline
Just a question : why ? doesn't anyone use the grade 8 Allen bolts for the heads instead of ruining a socket or spending HRS. looking for a bolt with a small head, Allen bolt sockets are made for the bolts as well.
Old 10-24-2013, 02:00 AM
Danschutz's Avatar
That is a good question. A couple weeks ago I picked up some grade 8 allen bolts for my next ragjoint install. Overkill but I think it will look good.
Dan.
Old 10-24-2013, 02:28 AM
truckd's Avatar
I mean think about all the trouble everyone is going through to modify tools to get the bolts into a Puch head DAH! use an Allen bolt, I've even used them in my Fred Head and by the way this is what I did to my Pope/Shapleigh tore it down and stripped the head badge and polished it.
Old 10-24-2013, 09:42 AM
FMB42 FMB42 is offline
There various reasons for using studs and nuts rather than just bolts to secure cylinders and heads;
1. Studs can help align the cylinder and/or head with the engine cases or block (this can eliminate the need for cyl. and head alignment pins and/or dowels).
2. Studs are not as likely to be twisted when the nuts are torqued down in comparison with bolts. The result is that studs offer increased torque accuracy as well as the ability to maintain their torque settings.
3. Assembly is often easier with studs (many automotive engine builders use several long studs that are lightly threaded into the block to help with cylinder head installation (these studs are removed and replaced with head bolts after the cylinder is seated to the block.
Note: imo, none of this means that you can't effectively use high grade Allen bolts in place of the cylinder/head studs on these engines.
Old 10-24-2013, 09:59 AM
Trey's Avatar
Trey Trey is offline
$50 Cruiser
Yesterday I rode about five miles, and didn't worry about a thing. It's nice when you finally get em right.
It's cooler to not fall off your bike.
Tags
MotorBicycling.com
