Old 01-21-2011, 05:43 AM
bitsnpieces bitsnpieces is offline
Rode it from my house to Point Cook, approximately 22 kilometres away. Took about 40 minutes? I didn't go very fast, wasn't going flat out.
On the way home from Seddon though, about 12 km, I forgot to check time but riding along cars going at 60km/h, I was probably around 45-50km/h WOT for speed.
I wonder if it'll get faster after the break in period? o.O
Old 01-21-2011, 06:22 PM
RebelHellbilly's Avatar
RebelHellbilly RebelHellbilly is offline
did routine check over today. cleaned spark plug,wipe off chain N lil oil on it. we ready for the weekend
Old 01-22-2011, 12:26 AM
Skarrd's Avatar
Skarrd Skarrd is offline
Originally Posted by jaguar View Post
Installed motorcycle CDI and high voltage coil. Had to shave 1mm off the side of the woodruff key to retard the ignition to get it where it should be. Now it has a timing curve like a dirt bike! Here's the results:
19.2 BTDC at idle
24 at around 3200 rpm
17 at around 5000 rpm
what's your butt dyno say about it? anything gained?
They see me rollin'
they hatin'
Originally Posted by biknut View Post
Traditional bicycle riders think we're cheaters. Non riders think our bikes are toys. Bicycle shops think we're a threat. Tree huggers think we're polluters. The police don't know what to think.
Old 01-22-2011, 05:39 AM
Fix a leak (hopefully it's fixed now)
Used a soda can as a temporary exhaust tip (because I lost the proper exhaust tip, and yes, I did make a hole at the bottom of the can)
Tighten clutch and brakes a little more
Moved rear basket back a little more (so I can actually completely sit on the bike)
Refuel
Stuffed rubber bits between the cooling fins of the engine (one user posted it as a tip as it helped reduce the vibration on their bike)
Gave it a quick test run.
Things to do would be:
File down part of the engine mount parts so they can sit flush with the frame
Swap out old short studs on the front mounts and replace with longer ones so I can put the bracket on
Get a new exhaust to make the engine run quiet
Old 01-22-2011, 08:06 AM
solokumba's Avatar
solokumba solokumba is offline
Made a 1/4" spacer and inserted it into my throttle tension assembly to fix my small idle problem. Added my new Manic Mechanic Large CNS intake and didn't have to cut down the clutch alignment screw. He must be making them a bit longer now. If you are having CNS trouble and hate that crappy plastic spacer, this is a great product.
I may be slow, but I'm not very accurate.
Old 01-22-2011, 10:55 AM
Dan's Avatar
Dan Dan is offline
Staff
LOL, just sounded funny. But is amazing how much ya can gauge/figure out with yer butt dyno, gluteus gage, pontification pointer.
On a China girl, ya know when the forward, rt mount is loose 'cause yer upper left check feels it first.
worst apocalypse ever
http://www.youtube.com/watch?v=y6Sxv-sUYtM
Old 01-22-2011, 11:31 AM
GearNut's Avatar
GearNut GearNut is offline
Upper left cheek???
How many butt cheeks do you have Dan?
The_Aleman:
________________________
ROTFLMAO!!!!!!
Old 01-22-2011, 11:39 AM
Dan's Avatar
Dan Dan is offline
Staff
lol Gearnut. Before or after the last crash?
Does sound like the poorly worded "how to properly mount a Chinagirl"
Once again proving my editing skills are full proof.
Old 01-22-2011, 08:02 PM
Allen_Wrench's Avatar
Allen_Wrench Allen_Wrench is offline
Resident Mad Scientist
Wink Re: what did you do to your motor bike today?
Mine are about 80 proof
"There is nothing wrong with wanting a motorbike that is an extension of your personal taste and fashion sense; if you must ride somewhere, I say do it with style!"
Old 01-22-2011, 08:05 PM
matthurd matthurd is offline
made it work.
Tags
MotorBicycling.com
