Old 09-29-2013, 01:44 AM
Danschutz's Avatar
Danschutz Danschutz is offline
Originally Posted by mapbike View Post
Dan, if Im following you correctly........ you're wanting a coaster brake rear wheel on the bike.
As far as I know all single speed coaster brake hubs are relatively the same width, if you want a good heavy spoked 26" coaster wheel you can get a good one at a good price at http://huskybicycles.com
I hope Im following what you said correctly....... sorry if I missed something.
Map
I probably bumbled my point lol. I have a coaster wheel but I want a freewheel that has either the same width or maybe a little bigger because my other freewheel wheels are so much wider I just don't want the stress on the frame. My current bike I had to spread the frame to get a freewheel with 5 sprockets in there, but like I said this older Huffy is much narrower.
I found a Point Beach Schwinn on Facebook that I might be able to buy for 80 bucks if the seller would get a hold of me, I think that rear wheel would solve my issues. Actually I might keep the Schwinn as is and paint the frame flat black or a flat darkish blue color. My only issue with the Schwinn is I'll probably be stuck again with sub par wheels. Geez it's confusing staying on task when I can't visualize the end product due to my lack of knowledge lol. But with you guys helping it sure makes things easier!
Dan.
Originally Posted by trackfodder View Post
I like the Worksman bike rear wheel. It is about $66 and has 0.10" spokes, 4" sprocket. Coaster brake. Actually, I got fed up with the brake and went to foot-operated bike rim caliper. With a motorcycle front wheel with disk brake/ go kart caliper I can shut down safely from ~55 now.
I've heard great reviews on that wheel and your set up sounds great but its all Greek to me!
Dan.
Old 09-29-2013, 03:40 AM
Huffydavidson's Avatar
Huffydavidson Huffydavidson is offline
STREETRACER/MANUFACTURER
WELL, after a week of self imprisonment In the "Bike Kave" I rose to discover that the world was just as I had left it . Damit anyway. 6 CDI's 2 rolls of solder later its goods to get some second hand smoke . Today I ran the mail man down on my bike because he left without delivering me my three packages . I knew you had them because the tracking numbers in I for delivery yet the box was empty . So being the complete maniac that I am , I jumped on my bike with just my shorts and t-shirt and Fire mother up. After , hijacking what was rightfully mine I return back to the "bike Kave".
"RIDE IT LIKE YOU STOLE IT"
Old 09-30-2013, 03:17 AM
Well today I rode over to home depot and got the hardware I need to mount my led turn signals .
Old 09-30-2013, 10:00 PM
mapbike's Avatar
mapbike mapbike is offline
Pix when you get it done would be great......
Map
Old 10-01-2013, 12:15 AM
Today I got most if it installed and 2 Morrow I'll wire it up.
Old 10-01-2013, 08:00 PM
xseler's Avatar
xseler xseler is offline
Well, I found out that my bike absolutely hates 9000ft elevation. Didn't think it was gonna start --- ran like poop when it did. Never did get the carb adjusted to where it was acceptable. Decided the bike won't go to the mountains anymore.
With this in mind, I think that a question we should ask a 'newbie' is "what elevation do you live?" when they post that 'won't start' thread.
You're never lost until you run outa gas.
Old 10-01-2013, 09:57 PM
tme07 tme07 is offline
broke in the new chain, took a bad bump with the old one :\
Old 10-03-2013, 06:18 AM
happycheapskate's Avatar
I put new pedals on it. I tried to bend back the Dax Friction Drive tension strap by standing on it, but it's stout! I will have to use a hammer or bench vise! (it got bent by falling into the wheel weeks ago when some trash in the wheel knocked it loose.)
1" roller Dax Friction Drive and Tanaka 3300 with mods.
Old 10-03-2013, 06:20 AM
If it's the "china doll" engine, you could customize a carb for that elevation, and bring a spare for everything lower. Since it's so easy to swap carbs on the china kit engines, that is probably the best solution.
Old 10-03-2013, 01:40 PM
CTripps's Avatar
CTripps CTripps is offline
There's information about air density and altitude available at this site: Engineering Toolbox. More specifically, this page covers air density and altitude.
I haven't explored the altitude factor much, I found it when I was looking at air temperature and it's effects on volume (thread regarding that is here).
Hope the links help a bit.
CT
Any day that starts with a good ride is already a better day, and a bad day riding still beats a good day working.
My Builds: My Beast, Harley59's bike, my Cruiser
Tags
MotorBicycling.com
