Old 09-11-2013, 04:13 PM
crassius crassius is offline
can't stand watching some vids where camera angle is so low that one sees only a couple feet in front of wheel - just too disturbing to not see the road ahead
Old 09-11-2013, 04:48 PM
mapbike's Avatar
mapbike mapbike is offline
Yeah I agree with you on that one for sure, I like it when its an all the way up the road camera shot and maybe even a little side to side so I can see some of the other surroundings, another thing that bothers me is when some one puts a loud bunch of music in the vid and you can hardly if any at all hear the engine, a little music in the background is OK if its the right type but Id rather here the engine screaming and the rider talking a bit about the bike or the surroundings of where the ride is being done at, that makes it fun and interesting to me.
Map
Old 09-12-2013, 12:33 PM
BonusParts BonusParts is offline
Thats exactly why im using my footage. in my buddies videos its pointed so low the handle bars are nearly centered horizontally in the shot. :banghead:
Old 09-12-2013, 06:09 PM
Danschutz's Avatar
Danschutz Danschutz is offline
Just ordered a Dax balanced lower and the upper kit with a high comp head today. Hopefully I can get it all together before the first snowflakes start falling! I guess I'm officially an addict because my first bike has less than 90 miles on it lol. Thanks guys.......
Dan.
Old 09-12-2013, 07:45 PM
xseler's Avatar
xseler xseler is offline
I can surely say that Sick Bike Parts delivers what they say.....only took 3 days to get my complete order. Installed the new expansion chamber this evening. Seems like a touch more power than my homemade Frankenstein exhaust ---- it's certainly quieter!!
I've still got to get another brake caliper for the rear so I can utilize the dual pull handle that I also got. I'll save that for a different day! I also need to grind off the hanger bracket that ended up on the wrong side for my install....again, another day.
You're never lost until you run outa gas.
Old 09-12-2013, 10:52 PM
mapbike's Avatar
Pipe looks good, I know mine pulls the hills much better with the expansion pipe, if that silicone tubing ever burns out, you can set the pipe up with out any silicone hose like I did mine just using copper tubing fittings, nothing to ever burn out.
I had to cut that tab off mine also, rubbed on nside of my leg when I pedaled the bike.
Map
Old 09-12-2013, 11:08 PM
Huffydavidson's Avatar
Huffydavidson Huffydavidson is offline
STREETRACER/MANUFACTURER
Broke the trailer again today , so I could to the go to the laundromat . Then I order the
turn signal/light/horn switch. In the morning I'll start my search for a ROADRUNNER"
Sounding horn. BEEP-BEEP my A$$.
LAUGH-MY- BEEP-BEEP-A$$-OFF
"RIDE IT LIKE YOU STOLE IT"
Old 09-13-2013, 12:13 AM
mapbike's Avatar
Seen some old shwinn battery power bicycle horns on ebay a couple days ago that say they make the beep beep tone....
Im at work and on my galaxy III phone. Makess things a bit more trouble but ill try to get you a link here shortly.
Map
Old 09-14-2013, 05:32 AM
Talking Re: what did you do to your motorized bicycle today?
I figured out how to improve the Jag Clone, I'm work on it to incorporates two coils.
Next will be the twin spark plugs head from Fred . Advance the timing curve to Rev even Higher . By extending the time curve, it will also extend the powerband pull .
Just imagine a the Ultimate Tunable High Performance CDI With a HD Twin Fire Coil.
35,000 volts traveling threw (Blue of course) MSD Racing Wires, to the NGK Racing Plugs
that
Snuggled into RCMachine's 5.3cc Twin Sparkplug Head.
Old 09-14-2013, 08:41 AM
Danschutz's Avatar
that
Whoa dang
Tags
MotorBicycling.com
