Old 09-05-2013, 09:32 AM
mapbike's Avatar
mapbike mapbike is offline
Originally Posted by Danschutz View Post
What pipe is that?
Thanks, Dan.
It is the SBP expansion chamber pipe, I got rid of all the silicone tubing mess and plumbed it with 3/4" copper fittings, ill take some close up pix later today and post them here on how I did it, nothing fancy and not as good as if it were a solid welded up tube but it works just fine on this bike and I think it looks better than it does with all the silicone hose conections that didnt last no time before I was all burned out.
Map
Old 09-05-2013, 11:33 AM
crassius crassius is offline
I find that these things need 5 to 7 miles to fully get up to operating temp, with performance changing throughout the first part of the ride until you hit that distance.
I've never been quite sure how to tune for just short-ride usage : (
Old 09-05-2013, 12:01 PM
Huffydavidson's Avatar
Huffydavidson Huffydavidson is offline
STREETRACER/MANUFACTURER
Hey Map, so its a Special Limited Edition HUM-DINGER by Huffydavidson?
They must of slipped this one past me when I was on vacation .
This will come up with the next board meeting and believe me heads are gonna roll .
LMAO
"RIDE IT LIKE YOU STOLE IT"
Old 09-05-2013, 08:50 PM
Took the trailer out shopping today.
Old 09-05-2013, 10:24 PM
mapbike's Avatar
LMAO
Lol....!!!!!!!!!!!
Old 09-06-2013, 03:48 AM
Danschutz's Avatar
Danschutz Danschutz is offline
Map
Thanks Map,
Yeah I didn't like the looks of the silicone connections. Not sure if I want to get that pipe or the arrow pipe and the pipe from Jakes (sponsor) looks pretty good, the one that wraps around the frame but I haven't read or seen any reviews on it.
TIA for the pics and write up
Dan.
Old 09-06-2013, 08:41 AM
mapbike's Avatar
Danschutz
Sorry I didn't get these posted last night, fell asleep and just didn't get it done, these may not be great but maybe you can see in the pix which common fittings I used to get this pipe put together like I did it.
Map
Old 09-06-2013, 06:15 PM
Danschutz's Avatar
Thank you Map!
A picture is worth a thousand words......X4
Dan.
Old 09-06-2013, 09:22 PM
maniac57's Avatar
maniac57 maniac57 is offline
Swapped the plug wire and cap. Made the bike ride smoother and four stroke less in the midrange so it seems the stock wire was slightly bad.
Got lucky and didn't have to dig the wire out of the cdi, it screwed right out.
Also installed a front disc brake.
If more is better, then too much is just enough.
If you can't afford it, build it yourself.
Old 09-06-2013, 09:30 PM
xseler's Avatar
xseler xseler is offline
How's the comparison of the stopping power? I've never ridden a bike that had discs.....somehow, I just know that my next ride will have them.
You're never lost until you run outa gas.
Tags
MotorBicycling.com
