Old 08-12-2013, 11:35 PM
Huffydavidson's Avatar
Huffydavidson Huffydavidson is offline
STREETRACER/MANUFACTURER
Started final fine tuning of the Jaguar on the new DAX bottom after cross over 700 miles its time find the REDLINE.
"RIDE IT LIKE YOU STOLE IT"
Old 08-13-2013, 03:04 AM
mapbike's Avatar
mapbike mapbike is offline
Got my Dax balanced lower build put on bike, and ready to get broken in and then I'll do the exhaust, Puch head and the better carb mods, all I can say is WOW....!
These lowers are way better balanced than anything I've seen in the other kit engines, worth every penny....!
Old 08-13-2013, 09:24 AM
Krealitygroup's Avatar
Krealitygroup Krealitygroup is offline
Added 2 Specialized Armadillos with Thorn Resistant Tubes
Trued my back wheel.
Broke my engine housing due to a stripped screw.
Upgraded chain
Fixed some spokes
Old 08-14-2013, 10:35 AM
I got the lower timing curve of the Jag set, the I made three test runs for top end of the timing curve . With B2 jumper in she peaked out @ 7500RPM.s , with B1 she peaked out @ 7850 RPM.s BUT with setting "X" (no Bees) I cranked her up to 8520 RPM.s and still climbing just BLOW-UP all my work. After running the stock CDI and the JAG I have come to the termination that the engine is so balanced there's no difference in vibration between the two CDI.s SMOOOOOTH BOYS once you DAX you won't go BAX!!
Old 08-14-2013, 01:54 PM
xseler's Avatar
xseler xseler is offline
Just bought the copper supplies I need to 'engineer' a custom exhaust setup for my bike. Gonna use copper and a standard, old fashioned 3/4" threaded 8" muffler. I think that it'll do ok. Picts tomorrow.
You're never lost until you run outa gas.
Old 08-14-2013, 02:32 PM
dracothered's Avatar
dracothered dracothered is offline
How are you going to put it all together?
Old 08-14-2013, 02:46 PM
mapbike's Avatar
Just wanted to say here that I also plan to build an exhaust by using all or mostly copper tubing and fittings, I'll be brazing mine together, copper to copper and copper to steel, the brass will bond all of it good.
(Note: to any who may not know, this brazing can't be done with a simple hand held propane torch.)
Map
Old 08-14-2013, 05:06 PM
Nunyadam Nunyadam is offline
Nothing. waiting on parts to rebuild the top end after a very successful experiment.
(wrist pin retaining clip failed, and took out the piston and cylinder.)
is there a better clip than the originals?
Old 08-14-2013, 05:56 PM
Jumpa's Avatar
Jumpa Jumpa is offline
Made a new one!
On my 1995 Clear Creek
Old 08-14-2013, 10:00 PM
Went got gas and whipped up my special premix .
Tags
MotorBicycling.com
