Old 08-10-2013, 10:15 PM
dracothered's Avatar
dracothered dracothered is offline
I checked my front end geometry today on the AMF build and it looks to be good I think.
It looks to be about 3" of trail which if I remember right is in the good range.
Old 08-12-2013, 01:24 PM
Nunyadam Nunyadam is offline
Wednesday
The first batch of parts arrived. (49cc jug and piston, mounting bracket, and Banana looking expansion pipe.) (I Ordered a couple kits and parts for friends they bought my pipe for me.)
Went for a Ride.
Slapped the Expansion chamber on the bike. One of the Exhaust studs stripped out when i took the old muffler off so I used what i had handy to fix it. I had a 10mm bolt that was to long, so i put the 10mm nut on the bolt added the washers, threaded the bolt in until it bottomed out, and tightened the nut down on the flange. works so well i plan to do the other the same way.
Nice improvement on the low end, but the top end dropped off a bit.
I looked at the pipe before i put it on and knew I would be doing some work on it, but needed to get some new bit, stones and Sand paper for the Dremel.
Went for a Ride.
Friday
The Kits i ordered for friends arrived at about 11AM. (this would never happen if the parts were for me.) Bob and Todd picked up the kits and started working on there Bikes.
Went for a Ride.
Saturday
bought tips and some new wrenches.
Bob and Todd completed there builds. (I lent a hand when they needed, but they didn't need much help.( not there first bikes.))
Went for a Ride with Bob, Todd, and Greggo. I wanted to smack Greg upside the head a couple times for STUPID maneuvers he made.
best way to put express Todd's feelings about his new bike?
The funny part of the first ride is Bob saying it gonna be Wide open right from the get go, and Todd saying he is going to baby it during break in. They did just the opposite.
Sunday
Pulled the Jug and Piston, Cleaned up the Transfers, notched the skirt on the intake side. It is still not completely open, but close to it.
Went for a Ride. Bike seemed to perform better.
Monday
Pulled the Jug and Piston again.
The Welds and pipe fit at the flange of the Expansion pipe were TERRIBLE. (I should have taken pictures) So I spent some time this morning working on that. Followed that up with a little work on the Piston crown at the transfers and Exhaust. (Minor changes) did a bit of reading, and used Fred's Ebay Pistons as a guide.
After I put the bike back together I took it out for a test ride. Couldn't get the Bike to start, pulled over to have a look, and connected the plug wire.
Did a couple laps, and the Bike Died, pulled the gas cap, Yup you know it, Out of Gas. Pedaled about a block back home, and put some gas in.
So how did My Mods work out you ask?
Very well. the bike has good power all around. Strong off the line, and the top end speed is back. Can't wait until I actually get it broke in.
Time to go mix up my 3rd Gallon of gas(50:1), and go for a Ride.
I noticed today when i pulled the jug that the Carbon on the piston was burning off, which tells me i must be doing something right with the mods.
Old 08-12-2013, 02:35 PM
bigbutterbean bigbutterbean is offline
Attempted to use electrical solder to repair a leak in my gas tank. It's a whizzer style tank with the petcock threads on the outside, and leaking around the welds. The solder didnt work. I'm off to the auto parts store in a few to get some gasproof epoxy. I'll prep the surface with a wire brush before applying the epoxy.
Old 08-12-2013, 02:57 PM
racie35's Avatar
racie35 racie35 is offline
removed and checked the clutch one way and race...cleaned everything and fixed an air leak at the intake gasket....its A-Ok now
Old 08-12-2013, 03:42 PM
Swapped out the chain tensioner for a self adjusting version.
Old 08-12-2013, 04:12 PM
Went to Walmart and got some Quiksteel epoxy putty. Already applied it to the leaky gas tank (drained the gas, then lit the tank with a lighter, one quick POOF and it was done, son). It takes an hour to cure, so we'll see what happens then.
Old 08-12-2013, 07:47 PM
VIKTR VIKTR is offline
Began building a bike for my brother.
Drilled the sprocket to mount to a disc brake rotor, removed the cassette and replaced with a single speed adapter.
Pieced the bike together, mounted the engine, aligned the chains
Just need a gas tank and brakes and it'll be ready to go... I hope
Old 08-12-2013, 09:17 PM
dodge dude94's Avatar
dodge dude94 dodge dude94 is offline
Well, today was eventful.
Sort of...
While riding, my chain finally went snapo. Unbeknowst to me, taking a tooth off the engine sprocket with it. Sh1t. Well, I just made a new chain, so I ran it anyway. Runs fine.
Here's the scary part: the engine wouldn't fire properly. Oh crap. Misfiring like nobodies business. So I pull it back by it's normal resting place, figuring I'll jack with it tomorrow.
Engine is backfiring through the carb, spitting smoke through the carb and exhaust. Great, engine is gone. I look down and see arcing on the frame. WTF? It's the ground wire arcing! It had decided to come out of it's connection. Great! So I fix that, try to ride it. No fire. Damn.
Look down, what do you know? The hot wire off the mag decided it wanted to come out too. Stick that sucker back in, hop back on, clear the fuel from the engine and it fires right up and takes off.
Me gusta.
Got a couple pictures later.
2 WHEELS: '11 Huffy Good Vibrations, '11 Skyhawk GT5, 44t, CNSV2, NGK BPR7HIX, Bosch wire, shutupexhaust, 26x1.75kevlar tires, Tektro C230's, new stupid Bell chain
Old 08-12-2013, 09:28 PM
Lol, I sorta did the same thing today, although it was my spark plug boot that was off. I had removed it while trying to get my fuel line back on. My spark plug sticks out from the side of the head on my 98cc Lifan, under and to the right of my tank petcock. So I forgot the boot was off, pulled the starter rope 3 or 4 times, nothing. Finally look down and see the boot hanging there, and go oh yeah, duh! Put the boot back on and she fires right up. The good news is the quiksteel patched the tank up just fine. No more leaking.
Old 08-12-2013, 10:42 PM
Pictures I mentioned earlier:
modified exhaust cap
KA-BOOM!
Modified clutch cover, plastidipped.
Gotta get some bolts for the cover, then I'm good to go and the bike doesn't look AS ghetto as it does now. lmao
Tags
MotorBicycling.com
