Old 08-09-2013, 04:41 PM
dodge dude94's Avatar
dodge dude94 dodge dude94 is offline
Installed my NGK BPR7HIX plug today.
MAN! WHAT A DIFFERENCE! Gained 2mph flat ground speed, up from 32 mph. Part. throttle response and acceleration is amazing!
Old B7HS on bottom, new plug on top.
Spiffy fuel filter.
Might set up a youtube account to post my fly-by video. idk.
*EDIT*
Here's the video!
http://www.youtube.com/watch?v=v8yK2...ature=youtu.be
2 WHEELS: '11 Huffy Good Vibrations, '11 Skyhawk GT5, 44t, CNSV2, NGK BPR7HIX, Bosch wire, shutupexhaust, 26x1.75kevlar tires, Tektro C230's, new stupid Bell chain
Old 08-09-2013, 04:47 PM
bigbutterbean bigbutterbean is offline
I took the Huffy wheel off the cruiser to inspect the bearings and true it. One of the bearings was shot, I replaced it with a spare. I did true the rim, though it was nowhere nearly as badly warped as I had thought. I trued it anyway, in order to get better tension on the spokes. It did not take very much at all to get good tension. I put the wheel back on the bike and test drove it. I would not call the wheel good as new, but it will survive a few trips back and forth to work until my Sportsman adapter arrives and I swap this wheel out for a wheelmaster wheel. I did figure out the source of the problem, though. It was improper cone adjustment causing my wheel to lean to one side and rub the frame, and eventually causing my bearings to self destruct. Oh well, live and learn. The wiggle is still there and I am still unable to determine exactly what is causing it. Luckily, I do not have to use this wheel much longer and I have spare bearings in case I should have another failure before swapping out rims.
Old 08-09-2013, 05:47 PM
KenX KenX is offline
I just wiped it down, checked the bolts, for leaks and tomorrow I will ride. Everything AOK.
Old 08-09-2013, 06:47 PM
Dasmailca's Avatar
Dasmailca Dasmailca is offline
Mapbike
Suitable for head gasket ?
Old 08-09-2013, 08:42 PM
mapbike's Avatar
mapbike mapbike is offline
Originally Posted by Dasmailca View Post
Mapbike
If you're referring to the gasket material I use for intake and cylinder base gasket the answer is no..... you must use a metalic material sucha as aluminum, copper or brass, standard fi er type gasket material will not work for head gasket but is good for all other accept head gasket and exhaust gasket which needs to be something made to take the exhaust heat.
I have made my own head gaskets several times but without proper tools it would be very difficult to do.
Hope this answers your question.
Peac, map
Old 08-10-2013, 01:04 AM
bairdco's Avatar
bairdco bairdco is offline
a guy who makes cool bikes
today i finished up a friend's bike. he did most of the heavy work due to my shoulder, and i laced up a wheel. then i finished rebuilding a tomos moped engine for a custom "chalopy" moped i'm slowly building.
now i'm drinking beers and icing my shoulder...
Old 08-10-2013, 01:58 AM
mapbike's Avatar
Hope you get that shoulder better soon bro, and by the way I love an old chalopy, so be sure and show us some pics as it goes if you feel like it, my project are moving real slow right now so Im feeding off of everyone elses engineering. ......!
Map
Old 08-10-2013, 03:03 AM
Huffydavidson's Avatar
Huffydavidson Huffydavidson is offline
STREETRACER/MANUFACTURER
Routine fastener check and Juiced her up. Started my next custom fabrication project . Phone/GPS/Video Camera Mount . I have it designed and all drawn up in head. I'm awaiting my builders communities approval . They're discussing it like I'm
not even there.
"RIDE IT LIKE YOU STOLE IT"
Old 08-10-2013, 03:07 AM
The last head gasket I made was out of a pie pan. For the stud holes I simply used a notebook paper punch. $3.00 works on all the gaskets. O on the exhaust I use a license plate off a car. Nothing bets free material .
Old 08-10-2013, 05:10 AM
mapbike's Avatar
I buy .016 thick aluminum sheets at a local hardware store and make my head gaskets from that, I use a hole punch from a set I got at HF and use a hole saw for the center bore of the gasket.
Map
Tags
MotorBicycling.com
