Old 08-06-2013, 02:25 AM
dracothered's Avatar
dracothered dracothered is offline
Got my new Triple Tree Forks and right away cut the steer tube off and welded on the right size one.
Still need to run two more welds and then mod the top bracket.
Old 08-06-2013, 06:01 PM
Nunyadam Nunyadam is offline
Originally Posted by maniac57 View Post
Personally, I think anyone who says they notice a difference from the clocking of the spark plug in a china girl engine needs to have their meds adjusted. Adding compression by filling the chamber with a projecting spark plug iffy at best, even in these weak kittens.
In any other motor, it's a good way to explore the wonderful world of pre-ignition.
The bike is noticeably faster. better response, better top speed. top speed the before the switch 35, its now 40.(speeds off the speedometer) We made the same change on another bike with similar results.
Rotating the head so the Spark Plug is on the front (nearer to the front tire.) is the only change we made.
I don't know why it works, but it did for me.
Old 08-07-2013, 02:23 AM
bigbutterbean bigbutterbean is offline
Played around with my generator mount. I had to come up with my own mounts for this generator because the generator was given to me without all the hardware. Recently someone gave me a generator mount, but it didn't have the generator in a good position, and a corner of the generator wheel was digging a groove into my tire. I went back to my original mounts, and now the generator sits where I want it. It shouldn't wear into my tire anymore.
Old 08-07-2013, 03:51 PM
VIKTR VIKTR is offline
Originally Posted by mapbike View Post
There ya go.... cant go wrong with some extra fuel on board
Yeah, I ran out of fuel once a couple miles from the nearest gas station. With the 4 stroke engine, the bike weighs 100lbs, not fun to pedal.
I could have just carried some gas in a bottle, but this was more fun
Originally Posted by scotto- View Post
And a nice nozzle, in case ya got's to put a fire out or water the veggies
See ya next weekend VIKTR
Funny thing about the nozzle. I had bought a standard cap for 2 dollars at home depot and was going to have that hooked up to a dirt bike vent that would have been another 10 dollars... then found the nozzle at the dollar store and never looked back
See you Sunday
Originally Posted by Dan View Post
That is so cool Viktr.
Thanks, I was quite proud of myself
Old 08-07-2013, 04:51 PM
I went back to my old brake light (same bulb, just a different housing, this one is an old yamaha turn signal the other one was a trailer stop/tail light that I decided I didn't like the look of), and tried to get my headlight switch working better. It now appears that there is some sort of slight short in the switch itself, because sometimes when I throw it it lights up right away and sometimes has to be wiggled. Its the same as it was before I played around with it, so I figure it has to be the switch itself. No big deal, I guess. Once the light is on it usually stays on, so I guess I'm good.
Old 08-07-2013, 07:46 PM
maniac57's Avatar
maniac57 maniac57 is offline
Had to repair the exhaust flange since I whacked the snot out of the pipe on a parking block. Added a thicker flange behind the stocker and welded it from inside to seal the boltholes too. Also added a second MUCH better weedeater gasket.
Working great so far...
If more is better, then too much is just enough.
If you can't afford it, build it yourself.
Old 08-07-2013, 10:09 PM
Huffydavidson's Avatar
Huffydavidson Huffydavidson is offline
STREETRACER/MANUFACTURER
Made some exhaust gaskets from an old license plate . I love my dremel tool !
"RIDE IT LIKE YOU STOLE IT"
Old 08-08-2013, 04:34 PM
KenX KenX is offline
Got my spare set of wheels in the mail with correct gearing. Already had the tires. My next project is to learn how to true the wheels.
Old 08-08-2013, 07:03 PM
Did some mill work to my new triple tree.
Old 08-08-2013, 08:34 PM
Learned how to true a wheel finally. I have read bits and pieces about how to do it, but I didn't specifically look anything up today before attempting it, and I didn't watch any videos or anything. I just had an idea in my head of how to do it, and decided to give it a go. I grabbed the spare frame down in the garage (eventually I'll need some sort of wheel stand as the spare frame isnt mine) and used a pair of needle-nose vice grips as a feeler. I clamped the vice grips around the frame pointing toward the edge of the rim and spun it. I didn't have a tire on it, so it was easy to hear the rim scraping the tips of the needle nose. Wherever the rim scraped the needle nose, I would tighten a spoke or two on the opposite side, about a quarter turn at a time. I did this on both sides of the rim. Once the rim didn't scrape anymore, I'd tighten each spoke a quarter turn to get better tension, then go back to checking for trueness, repeating the process until the spokes were evenly tight and the rim didn't scrape the needle nose anymore. It's time consuming, but not nearly as difficult as I thought it would be. The rim may not be PERFECTLY true, but its as close as I can get it, and I can't tell by eyesight. To clarify, I did bolt the wheel to the frame. I tried it without bolting the wheel down first, but the wheel would move slightly, making it impossible to accurately true the rim. Now that the rim is true and the spokes are evenly tensioned, I just need to get a sprocket adapter that will fit this hub in order to use this rim. Tomorrow I'll be truing the pos huffy rim thats on my bike now, so I can at least drive it until my new adapter gets here.
Tags
MotorBicycling.com
