Old 08-05-2013, 03:39 PM
Dan's Avatar
Dan Dan is offline
Staff
Originally Posted by VIKTR View Post
A day late but here they are
That is so cool Viktr.
worst apocalypse ever
http://www.youtube.com/watch?v=y6Sxv-sUYtM
Old 08-05-2013, 09:08 PM
mapbike's Avatar
mapbike mapbike is offline
Originally Posted by dodge dude94 View Post
Nose (electrode) of the plug facing the forward on the bike or toward the carb?
If it's facing toward the front of the bike it retards ignition timing a bit.
I can help but say.......WHAT? on this one, how do you figure rotating the head will change ignition timing?
Just curious..
Map
Old 08-05-2013, 09:16 PM
dodge dude94's Avatar
dodge dude94 dodge dude94 is offline
Just curious..
Map
Pointing the plug toward the incoming air/fuel mixture helps to increase the timing a tad as well as putting in a projected nose plug.
2 WHEELS: '11 Huffy Good Vibrations, '11 Skyhawk GT5, 44t, CNSV2, NGK BPR7HIX, Bosch wire, shutupexhaust, 26x1.75kevlar tires, Tektro C230's, new stupid Bell chain
Old 08-05-2013, 09:48 PM
16v4nrbrgr's Avatar
16v4nrbrgr 16v4nrbrgr is offline
Rode the piss out of it, of course!
---LEAD--->---BY--->---EXAMPLE--->
KTM50 Schwinn Chopper - 6000W E-Motard - 52cc Auger BMX - 9sp+CVT 52cc Cagllari Moped
Old 08-05-2013, 10:27 PM
maniac57's Avatar
maniac57 maniac57 is offline
Personally, I think anyone who says they notice a difference from the clocking of the spark plug in a china girl engine needs to have their meds adjusted. Adding compression by filling the chamber with a projecting spark plug iffy at best, even in these weak kittens.
In any other motor, it's a good way to explore the wonderful world of pre-ignition.
If more is better, then too much is just enough.
If you can't afford it, build it yourself.
Old 08-05-2013, 10:31 PM
xseler's Avatar
xseler xseler is offline
I noticed a difference in my clock when I changed the plug........
......wait, I see what you did there........
You're never lost until you run outa gas.
Old 08-05-2013, 10:36 PM
In my Ram projected nose plugs are installed for emissions purposes.
Then again...that V8 is HOW much larger than these HTs?
hmm...5900cc vs 66cc
Old 08-05-2013, 10:38 PM
CTripps's Avatar
CTripps CTripps is offline
I replaced the original guts of my bullet light with parts from a newer style LED light. The LED light's control/switch didn't work, but it was a donor for the LED cluster and the battery holder. The old bullet I found in a bin'o'stuff at a bike repair shop for around $3.00. Unfortunately the plastic internal parts were very brittle to begin with, and there was a lot of corrosion on the old 'spring' contacts for the batteries. The power loss on the old bullet was ridiculous. Two new 'C' cells giving 3.37v combined, and less than 2.0v were making it to the bulb. The light looked good but didn't do much more than that.
So, to widen the hole for the lamp holder in the reflector I used the dremel with a sanding drum and widened the hole a little at a time until the LED cluster would just barely slide into it. The LED cluster is epoxied in place with JB Weld.
The original switch on this old bullet was salvageable, I drilled a small hole in the tab on the off-side of the contact to solder the pos/+ lead to from the battery box. I spliced on to the old wire and connector and ran that in to the LED Unit, then neg/- to neg/- on the battery box. Soldered and heat-shrinked every connection. There's no loss now, 6.56v at both the batteries and the cluster. I wrapped the 'AAA' battery pack in some foam and packed it into the housing. When the front is closed and latched, everything is nice and firm.
The difference in brightness is staggering, can't wait to see what it's like on the road at night.
CT
Any day that starts with a good ride is already a better day, and a bad day riding still beats a good day working.
My Builds: My Beast, Harley59's bike, my Cruiser
Old 08-05-2013, 10:55 PM
mapbike's Avatar
I've done some experimenting with some led lights, some of them set up with the right reflector project the light very good while other will almost blind you when you look at them but the do not proj ct the light well, in my experience in normally takes at least a 5watt led to give good projected light.
I hope that set up works out great for and ill be curious to know how it works out.
Map
Old 08-06-2013, 01:10 AM
Huffydavidson's Avatar
Huffydavidson Huffydavidson is offline
STREETRACER/MANUFACTURER
Designed some custom parts for a fellow motorized bicycle
"RIDE IT LIKE YOU STOLE IT"
Tags
MotorBicycling.com
