Old 08-01-2013, 03:22 PM
bigbutterbean bigbutterbean is offline
I adjusted my headset and painted my flex-pipe exhaust with hi-temp bbq paint. Then started the engine and watched the paint bake on. Good times.
Old 08-01-2013, 03:40 PM
xseler's Avatar
xseler xseler is offline
I consider it a great day when you have time to watch paint dry!!
You're never lost until you run outa gas.
Old 08-01-2013, 04:38 PM
Huffydavidson's Avatar
Huffydavidson Huffydavidson is offline
STREETRACER/MANUFACTURER
change my rear axle or to a solid chromoly getting away from the chrome moly quick release Jim and sick bike parts recommends ,after breaking this one I want to the bike shop in a should go solid we don't replace the hollow chrome moly .so I change it out to 3/8 solid chrome moly and installed tensioners because 5 horsepower I tend to yank the wheel on the right side. it's your problem my street racer race hard brake parts .
"RIDE IT LIKE YOU STOLE IT"
Old 08-01-2013, 06:50 PM
VIKTR VIKTR is offline
Made a reserve tank out of a tin can
Old 08-01-2013, 07:51 PM
mapbike's Avatar
mapbike mapbike is offline
Picsare always nice......got a tank idea myself the other day.......
Wont post anything on it until it a project underway.
Map
Old 08-01-2013, 08:26 PM
dracothered's Avatar
dracothered dracothered is offline
Took care of my carb float bowl clearance to the top of the the crank case/gear box on my Honda CRF50 clone. I remembered that the Tecumseh AH600 engine has a spacer between the carb and engine. So I thought, lets see if it fits and what do you know it is perfect. Now I am glad I got those other two AH600 engine off of curtisfox.
Old 08-02-2013, 11:54 AM
dodge dude94's Avatar
dodge dude94 dodge dude94 is offline
Picked up an NGK BPR7HIX plug. Going to brave the heat soon and pull the bike out and redo the exhaust, boring out the exhaust flange on the muffler as well.
2 WHEELS: '11 Huffy Good Vibrations, '11 Skyhawk GT5, 44t, CNSV2, NGK BPR7HIX, Bosch wire, shutupexhaust, 26x1.75kevlar tires, Tektro C230's, new stupid Bell chain
Old 08-02-2013, 02:08 PM
Well, took the dremel and a grinder and opened up the exhaust a bit, filed it to get it as clean and flat as possible. Then I took the dremel to the gasket, bored it out a bit, filed it. Tried to clean everything really good, then ran some beads of copper rtv on it.
Hope it works out. New spark plug going in next week when I can ride.
Old 08-02-2013, 02:42 PM
trackfodder trackfodder is offline
As I stated elsewhere I finally learned how to adjust the Sturmey-Archer tranny I use for a jackshaft. I had only been getting low and 2nd. The bike shop guy told me the shift chain moves 1/2". Mine was moving 3/8" because the axle was shifted to the right side limiting the travel of the shift bar in the axle slot. As soon as it quits raining and I repair the cable it should be AWESOME. It is geared pretty high with balls of torque and acceleration from 6-1/2 HP so may have to go to a bigger rear sprocket. It ran in the mid 50's with 2nd gear.
Old 08-02-2013, 03:40 PM
mapbike's Avatar
Nice looking rig you got there, those fenders scare the crap outta me though..... sure hope one those fender mounts dont decide to give it up when your cruising at 50mph...... that could get ugly real quick......ouch.....LOL!
Map
Tags
MotorBicycling.com
