Old 07-25-2013, 11:13 PM
dracothered's Avatar
dracothered dracothered is offline
Worked on the AMF's battery box that I am making out of an old chain saw gas tank.
Old 07-26-2013, 12:51 PM
Matheneyr3's Avatar
Matheneyr3 Matheneyr3 is offline
Great Battery box- Nice idea !
Old 07-26-2013, 01:19 PM
dodge dude94's Avatar
dodge dude94 dodge dude94 is offline
Well, 300 miles, decided to pull my head and replace the gasket, it was looking kind of sad. Found a nice streak on the inside of my jug. I think the cheap chrome plating is not working very well. lol Also clean the head as well, apparently the sanding job I had done a couple months ago has worked well, as the carbon film is very smooth, not rough and sooty like it was before.
Nice chocolate brown:
Lovely streaks...
Pay no mind to the ridge in the head, manufacturing ridge. This was after I sprayed the crap out of it with TB cleaner
2 WHEELS: '11 Huffy Good Vibrations, '11 Skyhawk GT5, 44t, CNSV2, NGK BPR7HIX, Bosch wire, shutupexhaust, 26x1.75kevlar tires, Tektro C230's, new stupid Bell chain
Old 07-26-2013, 02:34 PM
mapbike's Avatar
mapbike mapbike is offline
Are those streaks actually grooves or are they just discolored areas?
The widest mark that goes all the way to top of cylinder could only be caused by something being between piston and cylinder and riding on top of top piston ring at some time or the other, the second streak is in the area that the piston ring retaining pin would be at, if it has worked out of the piston and is rubbing against cylinder wall that is why that mark is likely there.
Might not be a bad idea since your already into it this far to go ahead and pull that jug/cylinder and take a look at the piston ring retaining pin and see if it has worked out against the cylinder wall, if it has I'd get me a new piston asap or you will destroy the engine in time as that groove gets deeper.
if you cant feel a groove with your finger nail then maybe its not an issue but if you can feel a groove you have a problem, my cylinders with 1000-2000 miles on them dont look like that....
Map
Old 07-26-2013, 02:49 PM
Map
Well, it's back together. The streaks are grooves. I don't think the retaining pin is the problem, because if you look, both are just to the right of the exhaust port. If it were the retaining pin wouldn't it be right on with the transfer port? It just doesn't make sense, engine runs well, no weird noises, has good power. I dunno, maybe when I get a job I'll just replace the top end on it and call it a day. Granted, by that time I'd probably be looking at a complete engine replacement. (dax lower, you know. )
Old 07-26-2013, 03:50 PM
mapbike's Avatar
Actually if piston wa sin backwards the retaining pin for piston ring would be in that exact spot, got a jug and a piston in front of me now and that is what it shows would be the case, as long as it is running good just run it and if it goes ka-poot..... than you can go from there since you cant change any parts right now, it will probably be fine, just giving you some ideas on what it could be thats causing the grooves, if it is that pin it will get worse until the pin is able to come out and then you will have serious issues more than likely but maybe that wont happen..... fingers crossed for ya bro.
Map
Old 07-26-2013, 03:52 PM
Map
Gotcha now.
I pop the top on my engine every 100 or so miles anyhow, so if anything happens, I'll find it.
Old 07-26-2013, 04:11 PM
mapbike's Avatar
Originally Posted by dodge dude94 View Post
Gotcha now.
Sounds good man...... happy safe riding wishes....!
map
Old 07-26-2013, 04:15 PM
map
Thanks for the well wises.
Old 07-26-2013, 05:33 PM
mapbike's Avatar
Your welcome.... just keep the rubber side down.
map
Tags
MotorBicycling.com
