Old 06-12-2013, 03:22 PM
xseler's Avatar
xseler xseler is offline
Stephen1, I've sent you a PM.
You're never lost until you run outa gas.
Old 06-12-2013, 03:37 PM
dodge dude94's Avatar
dodge dude94 dodge dude94 is offline
Originally Posted by stephen1 View Post
foul a plug can i clean it and use it again its a 3 prong plug
Unless you're working on break-in, just replace the crap plug with an NGK of some flavor. I was cleaning my 3 prong with Throttlebody cleaner all the time before my NGK. Have not had to clean my NGK once.
2 WHEELS: '11 Huffy Good Vibrations, '11 Skyhawk GT5, 44t, CNSV2, NGK BPR7HIX, Bosch wire, shutupexhaust, 26x1.75kevlar tires, Tektro C230's, new stupid Bell chain
Old 06-12-2013, 11:41 PM
Huffydavidson's Avatar
Huffydavidson Huffydavidson is offline
STREETRACER/MANUFACTURER
Put 15 miles on my "DAX GP360 BALANCED" MOTOR . No bad vibes on my bike.
"RIDE IT LIKE YOU STOLE IT"
Old 06-13-2013, 07:04 PM
stephen1 stephen1 is offline
got a new kit riding around braking it in but its to slow want to go faster any ideals
Old 06-13-2013, 07:13 PM
DaveC's Avatar
DaveC DaveC is offline
Ideas? Just read everything you can here, there's sooooo many things you can do from bolt-on stuff to getting into the insides of the motor. Just about every part in the kit has aftermarket replacement parts including hi performance parts.
One thing to know, you can build up one thing only to have another part fail because it can't handle the stress of the upgrade. Like building in some HP and the clutch won't hold or something like that.
Use the search function but if you're not finding what you need the ask questions. Many here will help you out without copping attitude
Old 06-13-2013, 07:54 PM
bigbutterbean bigbutterbean is offline
Noticed that my saddlebags have been rubbing my drive chain and my wheel, so I prepped some flat steel supports that will bolt to my axle and my luggage rack to keep my bags away from the trouble areas. Tomorrow I will get some hardware and drill the holes.
Old 06-13-2013, 09:03 PM
I'be got reallllllyyyyyy cool 8.5 mile circle I ride. It runs threw my little town and out to that outskirts of town and back around into town and I stop at the house and let it cool down and retorque the head and have a cold sweet tea . and I went again for 3 more laps so I rode a total of 34 miles on my break in today .that's what I did on my motorbike today.
Old 06-14-2013, 06:03 AM
I got a hold of a 1988 Suzuki rm80 triple tree bracket for measurements. Looks like this one:
http://www.ebay.com/itm/Steering-Ste...b2e8cb&vxp=mtr
Made of cast aluminum, it's weighs 3.2lbs, heavier than a DS80 tree.
It also has a 1" steerer tube and is 1" shorter than the DS80 steerer tube. That means no cutting/rethreading and less shimming. The beauty of this model is that it comes with a factory motorcycle disc brake!
This triple tree accepts 33mm fork legs, compared to the DS80's 26mm legs., so fork travel should be less. It also has adjustable top and bottom clamps, which means that the fork tubes don't have to be opened when you remove the tree top or make adjustments. No oily mess!
The Suzuki RM80 uses a 17" wheel. To run a 26" tire, one needs to respoke the hub to a larger rim. However, the RM125/RM250 uses a 26" tire. I'm gonna look for that triple tree bracket. If it has a 1" steerer tube and fits onto my bike, I'll consider that one. Since the RM125 has 35mm fork tubes, fork travel will be even less. It also has adjustable top and bottom triple tree clamps, so no messy oil spills too. If it fits and isn't too heavy, I'll use the RM125 and factory 26" tire.
Update:
I got to see an RM125 triple tree bracket.
It is HUGE and weighs 5.6lbs! the steerer tube looks to be a tad over 1". It MIGHT fit my headset. However, I believe its size is not proportional to a bicycle.
RM125 tube WILL slip into a 1" headset. However, the shaft's bottom is tapered to a larger diameter to accept a bigger cone-style bearing. You'd have to machine the tube to accept a standard 1" bottom bearing race, then shorten and rethread the shaft. Too much trouble and expense.
And I haven't even seen the 35mm fork tubes, which are larger than the 33mm RM80s. All this adds more weight, so I'll stick with installing an RM80 fork with motorcycle disc brake.
RM80s have a 17" front tire, RM125s have 26" tire. With the right axle and bearings, maybe the large wheel will fit in the smaller fork.
Update:
YAY! RM80 triple tree fits an early cruiser frame like a glove!
It simply needs 38 ball bearings, 19 up/19 below the headset to match your standard cups. Balls are 3/16" size. I'm using the motorcycle's bottom bearing race and its top bearing retainer. Cost is less than $4. Upper bearing retainer must be reamed a fraction of a millimeter to clear the tube's machined shoulder. Instead of rethreading the steerer tube, a few large washers above the retainer will permit the ball bearings to be adjusted. The handlebar clamps are 7/8" and massive; no fear of cracking, and the standard bike handlebar should bolt on with no reaming. Then the RM80's brake lever should bolt onto my motorized bicycle.
Now I can start hunting for wheels, RM80 forks, axle and its entire front hydraulic brake system.
The first wheel I'll get is the RM125 26" one with disc rotor. Maybe an RM80 axle and bearings will slip onto the wheel.
And maybe the larger wheel's rotor will match the smaller fork's caliper. If that happens, I'm a happy camper. If the larger wheel won't fit, then I'll find
two RM80 17" wheels, one to run as is. The second one is to respoke its hub to the RM125's rim.
If I'm lucky there, the larger wheel's spokes can be re-used.
More researching needed.
Old 06-14-2013, 07:51 PM
Installed some head tube reducers to properly fit my 1" fork to my 1 1/8" frame and drilled some support brackets to keep my saddlebags out of my spokes and chains. I have some new tires to put on, but didn't get to them today.
Old 06-14-2013, 11:06 PM
One of the guys in my riding crew discovered and located a Velodrome here in St.Louis, Mo. It was actually use for board trackers back in the twenties and thirties . nowadays its a black top but its still an active function in the St Louis City Parks system .upon this discovery on Facebook we found a group that races motorbikes there every Sunday at 9 a.m. So you know what we're doing this Sunday . then my boy Thomas called me and said come over here and get these blocks we gotta build a race bike.So I got the engine built Thomas finished the frame Jimmy went got tags on his trailer. Now we're a race team all in a afternoon. Four crazy motorbikers from North County .
Tags
MotorBicycling.com
