Old 06-08-2013, 02:37 PM
d_gizzle's Avatar
d_gizzle d_gizzle is offline
I didn't see it either. Its not a call out,its a request for a link slick mouth.
Old 06-08-2013, 03:48 PM
Traffic was very light, due to school being out. It was an exciting 20-minute amusement ride to and from work, instead of 25 minutes. A cop was parked next to the bike path, where homeless encampments are. Turned off engine, kept pedalling a few feet past him until I was out of sight, then motored away.
Yesterday, my 6" square 1/4" aluminum plate arrived, so I'll work on motor mounts today.
Also arriving was my new rear disc brake adaptor. YAY! Bolted that onto the frame, installed my commuter bike's 8-speed rear wheel tire and brake setup. The part that slides onto the rear axle is perfect. Bike's seat stay (dropout) is 9/16" diameter. The clamp on the disc brake adaptor bottoms out @ 13/16" diameter. Clamp needs an inner metal or rubber sleeve/bushing to be secure. Looking from the rear, the caliper could be shimmed ever so slightly to center the 203mm disc. Despite the glitches, the rear brake worked okay when pulled by hand.
The big tire looks AWESOME! on my NOS Diamondback cruiser frame It is a huge 2.35 x 26" Schwalbe Big Apple, rotor is 203mm. Might as well measure it for dropout clearance. Tire is 26'" diameter and 2.35" wide. There is 5/8" top clearance to the fender cross/brace, but the tire must be flat and pushed forward to bolt the wheel on. There is almost 1" clearance towards the front of the chainstay. Left side chain stay clearance is 1/4"; right side is 1/2". Left side seat stay clearance is 9/16"; right side is 1/2". Surprisingly, this frame has more room than my 2006 Diamondback Response mountain bike (commuter motorized bike).
I REALLY like my Schwalbe Big Apples.
Excellent handling for a 61lb. bike @ 35mph. The soft tire's tread is shallow, but the bike's never slipped on wet roads or gravel. Ride is softer, especially with lower tire pressure (35psi).
Old 06-08-2013, 04:56 PM
I measured my Diamondback cruiser frame to see if my Dunlop motorcycle tire would fit in the rear dropout. It's gonna be EXTREMELY tight in the rear frame!! Measurements were taken without the rim, but the tire is so stiff that the numbers should still be very accurate. I'm using measurements from my 2.35" x 26" Schwalbe rear tire as reference points on the frame.
The Dunlop 404 80/90-21 is the front tire for Harley Davidsons. It is 5/8" taller than my 26" tire and 3" wide. There is 5/16" clearance to the top fender bracket/cross brace, and 11/16" clearance to the front of the chainstay. Left side chainstay clearance is tight @ minus 1/16"+. Right side chain stay clears by 1/16"+". Left side seat stay clears by 1/8"; right side seat stay by 1/16"+.
Looks like the left-side chainstay and the right-side seat stay will need "clearancing". Since issues are on both sides of the dropout, the wheel cannot be "dished" to solve the problem.
Well, I won't be certain until I mount the motorcycle rim onto the bike's rear wheel hub and try to bolt it on the bike. I believe this is the smallest motorcycle tire available in 21" rim size (26.625" tire diameter).
This Dunlop won't fit my 28" Rockshox fork. Sooo, I'm getting a 1987 Suzuki RM80 disc brake 17" fork and an RM125 21" wheel. The trick is to fit the Suzuki fork onto my bike. Then the next trick is to fit the RM125 wheel and caliper onto the RM80 fork. Correctly-sized wheel bearings SHOULD match the RM125 hub with the RM80 axle. This is the EASY way of installing a 21" m/c tire. If rotor and caliper don't line up, then I'll re-spoke the RM80's (17") wheel hub onto the RM125's (21") rim. More expensive to do it this way, so it's the last resort.
First I need to fit the RM80 fork onto my bike, which has 1" steerer tube. If cannot, then I'll use a K10 fork and its hub brake, and re-spoke it for the 21" m/c wheel.
Old 06-09-2013, 09:11 AM
After searching the 'net for hours, I've found that there's a 2.75" x 21" tire. Sad part is that it's only available in offroad, trails, enduro or dual-purpose. The last choice looks like knobby mountain bike tires, but for motorcycles, like this one:
http://www.motorcycle-superstore.com...port-Tire.aspx
Using reference information, rear tire side clearances on my rear dropout should increase by 1/4". The tightest left-side chainstay clearance would be ~1/8".
Looking better, might not need to clearance the rear dropout with a 2.75" x 21" m/c tire.
Old 06-09-2013, 09:28 AM
Huffydavidson's Avatar
Huffydavidson Huffydavidson is offline
STREETRACER/MANUFACTURER
I skirted and ramped my new type-A Piston. Then I carefully yet very skillfully milled in the third transfer port into the jug I purchased from BGFER. LOL and of course port and polished the transfer ports to accompanyed by my ArrowReedblock and RT Carby. Which will perch rather nicely on top of my GTX 360 balanced Crank shift bottomend that I was so to be one of the first to purchase from THATSDAX.COM which will be topped off with the coolest looking and performing 6.0 RCMachine Head . That what I'm doing yesterday today and tomorrow .
"RIDE IT LIKE YOU STOLE IT"
Old 06-09-2013, 10:00 PM
Searching websites again.
Suzuki RM125 brake caliper doesn't look like it'd bolt onto the RM80 fork's caliper bracket.
Therefore, the RM125's rotor more-than-likely will not slip into the RM80's caliper. It MIGHT, but I don't know that.
The simplest option would be to try to instal the entire RM125 front end onto my bike. That'd be its fork, 21" wheel, tire, axle, rotor, caliper, hose and brake lever. If I'm lucky, the bike's handlebar clamps on. If I'm REALLY fortunate, the 1986 Suzuki 125 fork's triple tree slips right into my bike's frame. Okay, maybe after the correct bearings/races are installed.
Old 06-10-2013, 08:56 AM
CTripps's Avatar
CTripps CTripps is offline
Spent some time yesterday tinkering...
  • Removed the exhaust hangers from the cruiser and examined the end of the expansion chamber the exhaust was welded to. Turns out it wasn't my poor weld job that failed, it was the pipe I welded to that gave out (sheared).
  • Found that the tank was still leaking at a stud. Going to have to pull it and figure something out.
  • Found I had an air leak behind the carb, so fixed it. Found it by shining an LED penlight into the intake of the carb and opening the throttle. The pinpoints of light showed clearly around the intake. I used a piece of scrap wood across the front of the carb to work it in the last half millimeter it needed. (Slid between carb and seat stay, twisted scrap until it pushed against both, at about 1/3rd and again 2/3rds of the way down the air intake until it was all the way in).
  • Tweaked the clutch a little to account for cable stretch and break in wear.
  • Wired up the speedo/trip comp on the cruiser as well.
  • Mixed up a can of 40:1 for the beast and fueled it for work this morning. (Almost exactly 10 litres of gas (2 cans) filled for $14.30 on Saturday).
Ans another week of riding to work begins..
CT
Any day that starts with a good ride is already a better day, and a bad day riding still beats a good day working.
My Builds: My Beast, Harley59's bike, my Cruiser
Old 06-10-2013, 10:39 AM
crassius crassius is offline
not hardly worth the effort to fix a leaky tank, but if you really need to it can be done
first, cut off the stud and drill a hole right there
put a metal washer, then a neoprene (or other fuel resistant) washer on the bolt
shove a piece of saftey wire thru hole & out the filler hole on top of tank
tie wire to end of bolt and pull bolt down into tank & out the hole
add another metal & neoprene washer, then three nuts
double nut the last two nuts at the end of the bolt to hold the bolt while you tighten the third nut against the washers at the tank base
remove the doubled nuts and you're done & dry
Old 06-10-2013, 03:42 PM
Moto's Avatar
Moto Moto is offline
Set up a three brake system:
-homemade dual pull brake lever pulls front v brake and rear caliper
-Front disk brake
It stops so well now.
Made a secondary spring loaded chain tensioner
Put on a new stem
New grips
Rejetted from a 66 to a 67
New exhaust gaskets that only leak a little but *~*
Hit 38.1 mph on my test run before I had to stop at a stop sign - it still had some more to give. Sux because I live in the city and there are not really any places where I can wind out my bike without interference from cars / lights / stop signs.... Whatever.
Old 06-10-2013, 08:58 PM
my new ThatsDax balance GP 360 balance crankbottom in showed up today so I got my motor built painted in in frame. I cursed out my girlfriend and gave the landward the finger .it was a good day all in all .
Tags
MotorBicycling.com
