Old 05-24-2013, 01:54 PM
JustAnotherBozoOnABike's Avatar
JustAnotherBozoOnABike JustAnotherBozoOnABike is offline
...i removed and discarded the stock, POS sparkplug and boot and replaced them with an NGK BPR7HIX plug and a new boot both purchased from SickBikeParts, a vendor you can not only rely on, you can actually reach them if you have a question, ...they KNOW how to do customer service over at SBP!
peace, bozo
"If a law is unjust, a man is not only right to disobey it, he is obligated to do so." -Thomas Jefferson
Old 05-24-2013, 02:30 PM
CTripps's Avatar
CTripps CTripps is offline
I took the cruiser out for a while this morning, it settles in to a nice purr at 40-44 kph (25-27 mph) with barely any throttle once it gets there. It feels like the clutch needs a little adjustment. Unfortunately, when I got back to the house I found it dripping gas from a different stud, and the L bracket in the middle of my rear fender has snapped. So it's up there (my garage is uphill of the house) with the fuel line feeding back into the gas can while I grab some caffeine.
CT
Any day that starts with a good ride is already a better day, and a bad day riding still beats a good day working.
My Builds: My Beast, Harley59's bike, my Cruiser
Old 05-24-2013, 02:38 PM
dodge dude94's Avatar
dodge dude94 dodge dude94 is offline
Originally Posted by xseler View Post
This one had matte finish plastic inserts. I tighten the round nut pretty tight with a pair of Channel locks then I pushed the lever over to finish tightening it. Seems pretty snug so far........Only went about 4 miles r/t to the store. It held a 6 pack of bottles nicely.
Maybe if you cut an old piece of intertube and wrapped it around the post before you slid the rack attachment over it, you might get a more snug fit....or, they make a product called "friction tape" --- it's usually found in the electrical department with the black tape. That stuff would work great, also!
That's basically what the box-supplied stuff is: thick innertube. I'll mess with it sometime this summer I imagine.
peace, bozo
You replace the wire too? The factory wire is crap as I found out when putting on my Bosch wire...
2 WHEELS: '11 Huffy Good Vibrations, '11 Skyhawk GT5, 44t, CNSV2, NGK BPR7HIX, Bosch wire, shutupexhaust, 26x1.75kevlar tires, Tektro C230's, new stupid Bell chain
Old 05-24-2013, 04:52 PM
killercanuck's Avatar
killercanuck killercanuck is offline
Got a midly ported engine back together on a prebuilt pull/centri. Replaced junk cable out of the box, of course centri was locked out of the box too... Luckily still had my hammer puller from the tandem job to get that off and fix it. Painted jug/head w/high heat, shaved the fin edges. Did some pin striping on the tank then sat down for a beer.
Was a good day in the shop/kitchen Too cold today to enjoy a good cruise anyway...
Cards, 29er, Trailer, Hack'em'up
Build with pride! Build to ride!
"A clean shop is a sure sign of a cluttered mind" ~ fasteddy
Old 05-24-2013, 05:06 PM
you could also use a more substantial shim to fill the gap although i wonder how strong and stable a rack like that will be with only one anchor point, i'd think you'd be safer with any kind of load if you had a rack that had supports that mounted at the dropouts as well so you'd have 3 anchor points.
...i'm actually considering this one but i haven't pulled the trigger yet because of the price. ...i like that it's rated to carry up to 77lbs though so i imagine i'll get it at some point, lol.
...and yeah man, you can't use the stock wire with an upgraded plug because the stock plug has the tip removed leaving a thin threaded rod that the stock boot attachs to, ...so the stock boot is too small for an upgraded plug.
peace, bozo
Old 05-24-2013, 06:37 PM
maniac57's Avatar
maniac57 maniac57 is offline
Originally Posted by 5-7HEAVEN View Post
It was another great ride to work. However, the pullstring jammed as I prepared to leave my workplace. Removing the pullstart to repair it, you can imagine what happened.....BOING! The clockspring popped out. Reassembling the pullstart was an exercise in futility for me. Luckily, my family happened to be a few blocks away. I secured my motorized bicycle onto the bikerack and went home with them. Fortunately, I have a spare 47R in storage. The next morning, I visited my storage locker, retrieved the pullstart, then my wife dropped me off @ work. At day's end, I installed the spare pullstart and enjoyed another great ride home.
Honey, it's just a bicycle. and i REALLY need it to excercise, and to ride it to work.(hehe)
Grind a small notch in your flywheel to allow you to use a knotted rope for emergency starts. Just wrap around the flywheel and pull like the old style engines. Notching a fin is easy and hardly visible.Carry a spare rope in your tool kit for just this emergency.
Did this with ALL my fourstroke Karts and minibikes for years. Got me home more than once.
Just be SURE the rope releases from the notch when you pull it! Otherwise things can get ugly and dangerous!
If more is better, then too much is just enough.
If you can't afford it, build it yourself.
Old 05-24-2013, 07:15 PM
CTripps's Avatar
I pulled the tank on the cruiser, cleaned it out, cleaned the base of the leaking stud and epoxied it. Waiting for it to set before I can do more there.
After that I dropped the cruiser's rear wheel and pulled the fender. The bracket I used as an upgrade from the stock one sheared across the bolt hole for the frame. I dug through my box of "assorted bits and stuff" and came up with what I think was a fire extinguisher hanger bracket. The holes on one end of it matched up perfectly with the holes in the fender, but it was about 1/32" too wide to go through the fender. I widened the slot and it slid right in. I used the bracket from the bike to center punch the other end in the right spot, then drilled it out. Everything went together pretty smoothly putting it back on the bike. I gave the tire a good cleaning and put the wheel back on.
CT
Old 05-24-2013, 07:50 PM
Trey's Avatar
Trey Trey is offline
$50 Cruiser
That fender came out nice...
It's cooler to not fall off your bike.
Old 05-24-2013, 09:25 PM
Muchos gratias,maniac! I will do that.
Old 05-24-2013, 10:02 PM
d_gizzle's Avatar
d_gizzle d_gizzle is offline
Moved all the parts of my motorized bicycle to the new digs. In the rain. Gotta love Tornado Alley during tornado season,been trying to move all week.
Tags
MotorBicycling.com
