Old 05-04-2013, 09:35 PM
CTripps's Avatar
CTripps CTripps is offline
Originally Posted by maniac57 View Post
clogged fuel petcock?
Hmm... possible, I'll put it on the check list. I'm wondering about the exhaust getting gooped up interally as well, since it's still on break in mix.
CT
Any day that starts with a good ride is already a better day, and a bad day riding still beats a good day working.
My Builds: My Beast, Harley59's bike, my Cruiser
Old 05-05-2013, 12:32 AM
Toadmund's Avatar
Toadmund Toadmund is offline
Originally Posted by CTripps View Post
Took the cruiser out for a while. It runs pretty nicely, and has nice pull when you hit the 'sweet spot' in the throttle. A new problem's popped up, of course. I'll be cruising along at about 1/3rd throttle, and you can hear the engine start slowing down until it stalls out. There's little or no positive throttle response at this point. Opening the gas cap had no effect, nor did holding the primer on the float down. After a short time, it fires right up again and powers up to speed smoothly, but a few minutes later the same slow down and eventual stall out will occur. Scratching my head a bit on this one.
My intuition tells me that your bowl fuel level isn't meeting the demands of your throttle usage.
Not sure but what i do know for sure is that if you are using an NT carb, the distance from your float tangs and base should be 21 mm's (tuirn your carb upside down)
Well what i AM BASICALY SAYING IS YOUR BOWL ISN'T REFILLING FAST ENOUGH TO MEET DEMAND AND YOU MUST ALTER THE float needle to allow more to flow in to meet demand.
Damn cpas lock, I ain't fixin that, Dammit!
(yes I am drinking, so I am just talking outof my a$$.)
I love my Motor Bicycle, I love Beer, I'll try not to like them both at once.
Old 05-05-2013, 02:26 AM
Today I started trial-fitting 17" moped wheels and Michelin tires onto my motorized bicycle. LBS said it's gonna be a major project.
After sleeping on it, I decided to have the LBS respoke the moped rims to the bicycle hubs with 13-14g SS spokes. Should be much easier and cheaper. My bike hasn't broken any spokes in a year, and it uses OEM SS 14g spokes front and rear.
Old 05-05-2013, 04:01 PM
577-Jersey's Avatar
577-Jersey 577-Jersey is offline
I dont think its the muffler,,sounds like fuel flow/float/jet issue.
Ghost pedaling in NJ....
Old 05-05-2013, 04:23 PM
CTripps's Avatar
That's what I'm thinking, too.. It's had that problem before. I have drilled the cap to relieve vacuum lock (which was one issue), already tweaked the float level, probably needs more of a bend.
CT
Old 05-05-2013, 04:53 PM
obesepolice obesepolice is offline
Tore it back down to fix a few more things. Decided I wanted to go with a faux patina look. I've been poking around Ratrodbikes.com to much lately. I did some experimenting with color and process. I ended up laying down a grey sand-able primer base and wet sanding that. Then a coat of brown primer, wet sand. Then a couple coats of khaki beige. I then top coated it with clear engine enamel. Let that dry for a couple of days. Then lightly dabbled heavy duty gel stripper in the usual places. let that dry and went to town with a dish sponge and 600 grit paper. Then a mixture of salt, hydrogen peroxide, and venager. I've been spraying it occasionally thought the weekend. I like it. the way i allpied the stripped, i could control how much actually went on so i could kinda feather the paint out easily. with out really getting sanding marks.
Old 05-05-2013, 05:29 PM
CTripps's Avatar
Pulled the carb off the cruiser, drained it and pulled the bowl. Tweaked the tines for the float up again so it should be open for the longest it can be. Any more than where they are now and I might as well just take them out altogether. Put it back together and on, then pulled the fuel line off the petcock. Using my compressor and a piece of kit-line, I gently ran pressure backward through the petcock (after loosening the gas cap) until there was a steady gurgling in the tank. Held that level of air flow for 20-30 seconds. In doing so, I saw bubbles/leaking coming from around the (yes, stock) petcock, around where the plate/top fastens on to it. Though they looked good, one screw took a full turn, the other took a turn and a half. No more bubbling there.
Now it's time for a test ride.
CT
Old 05-05-2013, 09:07 PM
577-Jersey's Avatar
Good deal,,
Hope it runs better,,I have an after market petcock on my bike along with one on the carb,,I noticed the fuel runs out kinda slow,,but the bike runs great,,Im gonna up the line to 1/4" and see if that helps with the flow,,I also put on a briggs fuel filter(clear)I found at advance auto parts for $4.99.Went for a 17 mile ride today cruised around 23-24 MPH perfect the whole way.I plan on going to moms this week,,its 15 miles one way with some big hills,,cant wait,,should make it there in less than 50 minutes,,takes me like 30 min in my truck.So far I have just over 70 miles on this build and its getting stronger after every ride.I really appreciate all I have learned from you guys in such a short time here on the forum.
Good times...
Old 05-06-2013, 09:35 PM
CTripps's Avatar
Well, the ride went as planned, but I ended up taking the beast instead of the cruiser. All it wanted to do was dribble fuel from flooding. Too much on the float lever, I'll tweak it back a bit.
Not a bad trip out, wound out to around 64 kph at one point. The store finally got them in, so I got a phone/GPS holder for the handlebars. It can be moved to another bike easily, so I'll be able to put it on the cruiser for a GPS speedo.
CT
Old 05-06-2013, 10:34 PM
killercanuck's Avatar
killercanuck killercanuck is offline
That's a good top end CTripps, can keep up with traffic in town at least.
Had time to burn on a mock up for a change. Rear wheel is temporary, sry for the skinny butt. Getting there:
Cards, 29er, Trailer, Hack'em'up
Build with pride! Build to ride!
"A clean shop is a sure sign of a cluttered mind" ~ fasteddy
Tags
MotorBicycling.com
