Old 04-27-2013, 05:17 PM
happycheapskate's Avatar
I rode mine to the "Backstreet bash" street fair, and to the park to play with my kid.
1" roller Dax Friction Drive and Tanaka 3300 with mods.
Old 04-28-2013, 03:18 AM
On the way to work yesterday, the chain jumped off the front sprocket outward this time. Maybe I need to use thinner spacers. Anyway, since the head bolts were flatter, the chain didn't break and it was easier to untangle the mess. The chain began skipping to and from work yesterday. A trip to the bike shop today determined it to be stiff chain links, so a new chain fixed the problem. I usually check for stiff links, but I guess I missed it. Since my wife followed me into town, I decided to leave my bike @ my workplace's secured garage. I locked the fork and front tire with cable, then used a motorcycle chain to secure the frame and rear tire. It'll be safe there 'til Monday.
Old 04-28-2013, 10:22 AM
Trey's Avatar
Trey Trey is offline
$50 Cruiser
Got the $50 Cruiser running for the first time in a couple of months, and finally- brakes! And a new throttle control. Not the things normal people wait 6months to do Sorry for the picture quality.
1) Had to round over the edges of this cable grommet to fit into the hole on the throttle handle, then drilled a hole into the handle inside the hole to feed in the end of the cable. Works good!
2) Dual brake lever installed.
3) Front brakes pillaged from a Huffy parts bike. Had to grind the pad attachment slot lower to fit around the tires.
4) Had to file down the end of the throttle cable to fit into the carb lever.
It's cooler to not fall off your bike.
Old 04-28-2013, 10:34 AM
Trey's Avatar
$50 Cruiser
Originally Posted by happycheapskate View Post
120mph on flat ground.
By the way- HOLY CRAP!
Old 04-28-2013, 11:08 AM
GearNut's Avatar
GearNut GearNut is offline
Originally Posted by xseler View Post
I put a little over 5 miles on my new build this evening......baby steps, I guess. I wanna make sure everything is good to go before I attempt something farther than my neighborhood. I can certainly say that I'm gonna have to find some higher performance/longer lasting brake pads!
Kool-Stop Salmon pads are HIGHLY recommended.
The_Aleman:
________________________
ROTFLMAO!!!!!!
Old 04-28-2013, 11:17 AM
Toadmund's Avatar
Toadmund Toadmund is offline
I went to my local bike shop (LBS) and asked for the stickiest brake pads they got, he sold me Jagwire brand.
I can stop on a dime with these, and for soft brake pads, they sure are lasting a long time.
PS, I did nothing to my bike today, but going to spread the slime I put in my tubes with some serious centrifugal force later today, vrooom!
I love my Motor Bicycle, I love Beer, I'll try not to like them both at once.
Old 04-28-2013, 12:19 PM
stewpedassle stewpedassle is offline
**** all i did was put a pair of kend claw xt tires on and compared to old cruiser tires got 3.6 more mph on my gps guess less rolling resistance woohoo!!
Old 04-28-2013, 07:57 PM
CTripps's Avatar
CTripps CTripps is offline
Working on the new cruiser (Build Thread / Album), not my beast or Harley59's ride.
Bolted the exhaust back on yesterday, the JB Weld was still a little soft (could mark it with a thumbnail), so I moved on to torquing the head down and left it for today to try starting up. I did have a blown head gasket, both front and back actually, so I had to clean it up and replace the gasket.
It started, after some fiddling and adjusting the clutch a little as the engine was almost engaged when the lever was pulled in. It starts and runs, but it still has a bad habit of running on or dieseling, the kill switch doesn't always do it, I often have to choke the motor to shut down. It will even run with no wires connected, so that's not good. I'm going to go over the electrical again (once I've grabbed the numbers I'm looking for from here for the multimeter). It was all checked out several times during assembly and checked out fine then, but something doesn't seem right.
Also put the headlight back together and got it working again. The JB there should hold the bulb holder in place. It's back on the bike now, but I'm still not sure whether I will leave it as chrome, or clean it down and do a paintjob on it like I did for the tank.
CT
Any day that starts with a good ride is already a better day, and a bad day riding still beats a good day working.
My Builds: My Beast, Harley59's bike, my Cruiser
Old 04-28-2013, 08:08 PM
bigbutterbean bigbutterbean is offline
Adjusted my front brake (drum), my chain tensioner (spring loaded), my throttle cable, and turned up my idle a bit.
Old 04-28-2013, 08:14 PM
Trey's Avatar
$50 Cruiser
My humble suggestion; leave it be. Classic.
Tags
MotorBicycling.com
