Old 04-20-2013, 06:02 PM
racie35's Avatar
racie35 racie35 is offline
Put a few miles on it
Old 04-20-2013, 08:24 PM
577-Jersey's Avatar
577-Jersey 577-Jersey is offline
Well lets see,,
Repaired a fuel line,,
snugged up all hardware
bent my tensioner a little more
greased my primary gears and push rod/ball
lubed cables
fixed a tight carb slide
Enjoyed every minute of it..
Now Im going riding!!
Good times
Ghost pedaling in NJ....
Old 04-21-2013, 01:22 AM
MEASURE TWICE MEASURE TWICE is offline
Originally Posted by Outraaageous View Post
Nothing, Nothing at all today! Once i get off my but ill be attaching my throttle and cut off switch to my handlebars. Then i need to refab a piece that will attack my spindal to my flywheel. The gentleman i got to drill the holes in my washes did a piss poor job and they are not centered >.> I told the man they were $1.50 a piece and a 20 min drive away. Yet he still f***ed them up pretty bad. So another trip to ace hardware it is!
How the below post relates: With a drill press you can do the work yourself drilling the washers being sure they are centered.
Without a dill press, if you have a Dremel Tool or the like, the grinder wheels as I mentioned below I save a couple of each of various sizes worn to different diameters, they can cut the hole in a washer as I have done. A cheap vice to go along with it I make parts whenever I like.
When I have for the largest bit only a 3/8" bit for my 3/8" chuck drill, although stepped bits are available, I resort to using the largest bit first followed by the grinder thin disks. If the metal is really thick, the cost in disks would not be worth it, but for washers, I have made 5/8" bore quite nicely.
Here is a post I made:
http://motorbicycling.com/showthread...176#post474176
FYI, I found that when using the Dremel cut off wheels, I stop using them at various levels of wear when I am cutting.
This allows me to have a couple of different diameter sizes so they fit where they otherwise would not. I intend to use them not so much as cutters when they are worn smaller diameter but as shapers. The solid grinders have too much surface area to shape quickly in a small area I have found usually.
It has helped me out many times over. I have to switch wheels, but they seem to allow carving more smooth than the metal cutter.
I know the metal cutters have there use, but I am partial to those grinder wheels even though they wear way faster.
MT
Old 04-21-2013, 03:32 PM
CTripps's Avatar
CTripps CTripps is offline
MT
I was going to mention that somewhere myself.. I recently had a small job that the 'left over' wheels made easy and a full size just wouldn't have fit or done the job well if it had.
CT
Any day that starts with a good ride is already a better day, and a bad day riding still beats a good day working.
My Builds: My Beast, Harley59's bike, my Cruiser
Old 04-22-2013, 06:09 PM
dodge dude94's Avatar
dodge dude94 dodge dude94 is offline
Broke the carb.
2 WHEELS: '11 Huffy Good Vibrations, '11 Skyhawk GT5, 44t, CNSV2, NGK BPR7HIX, Bosch wire, shutupexhaust, 26x1.75kevlar tires, Tektro C230's, new stupid Bell chain
Old 04-22-2013, 09:38 PM
577-Jersey's Avatar
Originally Posted by dodge dude94 View Post
Broke the carb.
How the heck did you manage that,,or was it the china girls fault,,did the casting break?
Old 04-22-2013, 09:40 PM
Casting broke at the carb neck.
I think it was weak since the clamping part at the intake was almost completely closed.
Hit too many hard bumps at 35 mph down hill (like a boss) and it goes snap.
Couldn't figure out why it fell off twice.
Old 04-22-2013, 09:54 PM
577-Jersey's Avatar
Oh I hear ya,,
I was thinking to take a ride down the river here on Weds.its an old train track that they made a bike path out of,,it looks a little rough,,but Ill take my time,,5 miles down 5 back.
Take care and have fun brother!!
Good times
Old 04-22-2013, 09:58 PM
Oh I hear ya,,
Good times
Man I wish I could take the beast down the local concrete bike/walk path. It's got lots of tight twists and turns. But I would be afraid of getting stopped by the cops and being made to ride back under pedal power. Ugh. lol
Either way, since the bike is down at the moment, the engine is going to be ripped out, cleaned up, and I'm gonna get some work done to smooth it out a bit.
Should be fun.
Old 04-22-2013, 10:10 PM
577-Jersey's Avatar
Should be fun.
Good thing about this tow path is the cops cant get to it very easy,,there is a canal between the road and the path and miles before an entry way,,guess they could wait for me at the end,,by then I would be back to my truck so no pedaling...lol..I do most of my riding over in PA.its right across the bridge from me..they seem alot cooler over there,,I have not had any problem with the cops around here yet,,but I just creep around 18-20 MPH and obey all the traffic rules.I really enjoy riding at night also,,feels like your going so much faster in the dark
Tags
MotorBicycling.com
