Old 02-27-2013, 08:21 PM
russaroll russaroll is offline
i was going to put my new muffler on and go for a ride, but it doesn't fit right i need to heat it up and bend it a little. also discovered that the inside of my plug wire fell out.
Old 02-27-2013, 11:45 PM
GearNut's Avatar
GearNut GearNut is offline
The inside of the factory spark plug cap fell out?
They are notorious for that.
Get yourself an NGK cap or replace the whole wire and cap as an assembly with an automotive one.
The_Aleman:
________________________
ROTFLMAO!!!!!!
Old 02-28-2013, 12:06 AM
Trey's Avatar
Trey Trey is offline
$50 Cruiser
Originally Posted by Skarrd View Post
so i think i managed to track down the vacuum leak, it seems to be coming from the hose coupling i have on the intake.
got some black RTV and coated the outside of the pipe and the inside of the coupler with it, then clamped it down tight, we'll see in about an hour if it helped.
That's GOTTA do it. Maybe even electrical tape?
It's cooler to not fall off your bike.
Old 03-02-2013, 09:55 AM
Skarrd's Avatar
Skarrd Skarrd is offline
uugghhhhh....
so much for using the 24" frame... the rear dropouts bent and now i can't get the wheel to fit straight, as well as don't know if they have been compromised structurally. I get the feeling that even if i fix the dropouts they may crack and completely break apart.
time to find a light weight 26" steel frame. at least i have spare parts now.
They see me rollin'
they hatin'
Originally Posted by biknut View Post
Traditional bicycle riders think we're cheaters. Non riders think our bikes are toys. Bicycle shops think we're a threat. Tree huggers think we're polluters. The police don't know what to think.
Old 03-02-2013, 05:13 PM
killercanuck's Avatar
killercanuck killercanuck is offline
That sucks Skarrdman. A peice of 2x4 cut to fit between, then hammer the dropouts back in line may work. Then some oversize washers inside and outside will help them stay inline too. May need an extra washer on the left side to keep the chain alignment in check though.
gl.
Cards, 29er, Trailer, Hack'em'up
Build with pride! Build to ride!
"A clean shop is a sure sign of a cluttered mind" ~ fasteddy
Old 03-02-2013, 05:47 PM
Skarrd's Avatar
gl.
it doesn't look that bad and i could probably get it bent back in place, but it just worries me that the metal might have cracked in a place i can't see and could break even worse next time.
They see me rollin'
they hatin'
Old 03-02-2013, 09:07 PM
Nashville Kat's Avatar
Starting to peck together the next build and shaking off the winter doldrums- only 50 degrees here in Jacksonville so no riding-
Put a little tiny 25 tooth front pedaling sprocket onto a steel one piece carnk so I can use the 17 single freewheel thats been in the drawyer,
to keep a really light peddling gear-
and the chain links will be MINIMUM-
surprised at how light it is then- the build is almost ready to take out and ride a bit without the motor
Huffy cruiser with 26 wheels this time 1.95 smooth tires- staying small and this much rubber because it's gonna have a a HUGE wald basket on the front and saddlebag baskets on the back
66 chrome motor with speed carb and 36 sprocket-
anno red with anno blue trim- proabably paint the baskets some color-
Wal-Mart out of anno paint now- temporary or closed out for good?
I think you can still get it online- they have a green they NEVER sell at the store too.
Old 03-02-2013, 09:25 PM
Trey's Avatar
$50 Cruiser
[QUOTE=Nashville Kat;464532]Starting to peck together the next build and shaking off the winter doldrums- only 50 degrees here in Jacksonville so no riding-
Please see my picture below. Man I just can't feel sorry for you because it's cold in FLORIDA?
Old 03-03-2013, 01:33 AM
dracothered's Avatar
dracothered dracothered is offline
[QUOTE=Trey;464546]
Even with the propane heater running in the garage it wasn't as warm as 50 . . .
Old 03-03-2013, 03:32 PM
happycheapskate's Avatar
I installed a 3 speed freewheel ($10 on ebay), and cleaned my drivetrain really well.
I am trying to decide whether to use a staton throttle lever or old friction shifter like I have been doing, or to use an old gripshift as a twist throttle.
1" roller Dax Friction Drive and Tanaka 3300 with mods.
Tags
MotorBicycling.com
