Old 12-25-2012, 03:59 PM
racie35's Avatar
racie35 racie35 is offline
tested the turn signals I bought for it and installed the flasher....little buggers works great and are bright...I'll put them on perm later.
Old 12-25-2012, 04:10 PM
culvercityclassic's Avatar
culvercityclassic culvercityclassic is offline
Default
Rode my well running motorbike.... Lol
CulverCityClassic
wolfcreativecustoms.com
Old 12-25-2012, 09:21 PM
Wickedest1's Avatar
Wickedest1 Wickedest1 is offline
Tightened my loose rear brake mechanism and re-installed my rear fender with the stock mounting brackets. Installed new brake pads in the rear, and cruised for about 45 very cold minutes then wiped the road grime and salt off of her and begrudgingly locked her up for the night...hope to get more gas tomorrow....and more miles on my tires
Thats a lot of moving parts...hope it all works...
FD4E
Old 12-26-2012, 08:25 PM
jimmymc2286 jimmymc2286 is offline
I made the exhaust and the intake for my vintage build today. I only need to finish the tank and get my rear sprocket then test ride.
Woo hoo.
Made in Who Cares. Assembled in my garage. Jimmy
Old 12-26-2012, 08:47 PM
andrewflores17's Avatar
andrewflores17 andrewflores17 is offline
finaly fixed my leaky exhaust on my predator and got a drill set to fix my bike rack
Great bikes are built not Bought
http://motorbicycling.com/showthread.php?t=34006 Link to INFIDEL 99cc predator build
http://motorbicycling.com/showthread.php?t=39541Link to Recumbent golden eagle build
Old 12-29-2012, 04:01 PM
Wickedest1's Avatar
Talking Re: what did you do to your motor bike today?
I took a fall today in the snow...broke my left pedal, loosened my tension wheel, ripped my seat and landed in the only puddle on the street...and I laughed the whole time...
FD4E
Old 12-29-2012, 06:11 PM
SavageBlunts904 SavageBlunts904 is offline
Originally Posted by dracothered View Post
Got my new pedal crank and bottom bracket bearing set with cones. Will have to bend it to make it wide enough, but I'm not sure if I want to use this crank as it looks to be the same length as the old one. I also not sure how easy it will be to bend it even with heat to make it red hot. Can any of you give some idea of how hard they are to bend with heat applied?
I heated up the bend in my crank and bent it out a little to allow clearance very easily. Get it red hot in the bend and put a big wrench around it or big vice grips on it and bend it slowly
Bam let it sit and cool down and ur set. maybe throw some rust paint on the burnt spot after u clean it up a little bit if its black
Chrome just polish up
Orlando FL. Who rides down here?
Old 12-29-2012, 07:57 PM
GearNut's Avatar
GearNut GearNut is offline
"and I laughed the whole time"
You must have a very cheery disposition on life to be doing that while crashing!
I am sorry to hear that you went down, but I am glad that nothing broke, got loosened or ripped on you personally.
Good luck with the repairs, and ride safe!
The_Aleman:
________________________
ROTFLMAO!!!!!!
Old 12-29-2012, 08:18 PM
Wickedest1's Avatar
Thanks gear...think its time to put the new mountain terrain tires on...and lock tite...as for a cheery disposition id say it was a moment of joy riding in fresh powder in sunny weather that had me laughing...
FD4E
Old 12-29-2012, 08:52 PM
Blakenstein's Avatar
Blakenstein Blakenstein is offline
Woh !! nothing from this forum in E-mail for a long time and tonight I just got back from store with my motorized bicycle and this came up !!! wow !! anyway ya I wiped twice this winter untill i threw on my NOKIAs studded tires . Tonight was a beautifull ride !!! only -2 Celsius 28 below Farhenheit. Glad to hear that you are OK !!!
Tags
MotorBicycling.com
