Old 12-15-2012, 03:58 PM
Wickedest1's Avatar
Wickedest1 Wickedest1 is offline
Found a donor bike today...exact same size and dimensions tires that ineed and already took the wheels off for a bearings check up before I swap the 40toother to it...and the tires and brakes are absolutely brand new....thats a bonus...still going to get a set of those heavy duty rims from the swap and shop section...great price and for the quality...
Thats a lot of moving parts...hope it all works...
FD4E
Old 12-15-2012, 04:50 PM
GearNut's Avatar
GearNut GearNut is offline
You must mean these: http://motorbicycling.com/showthread...940#post446940
An awesome value and very well made.
The_Aleman:
________________________
ROTFLMAO!!!!!!
Old 12-15-2012, 06:08 PM
Wickedest1's Avatar
Exactly my point gn...and the guy said he probably won't ever sell out and if he does he can get more...hope I can scrounge 50$
FD4E
Old 12-15-2012, 06:48 PM
moonerdizzle's Avatar
moonerdizzle moonerdizzle is offline
I got the motor mounts made for the snow bike
that effin moon kid
LabRat that golden pos ya got with the homescooled monarks
coated pistons
http://motorbicycling.com/showthread.php?t=42853
Old 12-16-2012, 01:53 AM
bigbutterbean bigbutterbean is offline
It wasn't today, it was yesterday, but I replaced the wire connectors on the battery that powers my brake light. Its a 7.2v nicad battery from an r/c car, and I just bring it in my house and wall-charge it every so often. When I first rigged it up for my brake light, the wire connections were not the best, due to the fact that I had removed the original connectors and used them for something else. So I put male/female connectors on them, and also put matching female connectors on the wall chargin unit. Now I can quickly and easily disconnect the battery and bring it inside for charging, and it sits in the inside flap of my saddlebag when its on the bike. So thats a big plus for me right there.
Old 12-16-2012, 01:12 PM
fatdaddy's Avatar
fatdaddy fatdaddy is offline
I did something like that to my bike a while ago Big. The difference is that my 12V battery is mounted in my side case. I put quick connects coming off my battery and charger so I could just plug in in instead of trying to use the chargers cheapo clips. I've had those just fall off after I leave so it's not charging, ALL NIGHT. I just found out that my battery lasts about a month, cause that how long I didn't charge it before it started going dead.
I also FINALLY got my suspension forks on. I'll take a pic later today. It looks GOOD.
fatdaddy.
Old 12-16-2012, 02:13 PM
Wickedest1's Avatar
So yesterday I got another back rim from a donor bike. I was going to swap my 40tooth to it but decided to install the 44 that came with the fh kit. Got the wheel ready to go, then realized that the banana plates dont line up at all in any configuration. I tried anyways and got the bolts through. But no matter how I tighten it the overlap throws off the balance and the rear sprocket wobbles...no amount of tightening and patterning has solved this...I've contacted the vendor and see where it goes...oh and apparently 1700 miles on a sprocket has a tendency to work harden the bolts into a locked position...without thread locker...so the 40toother is a no swap for now...and I'm still without a bike to ride...going to build a cardboard engine mock up and see if I can squeeze a kit into my 1950 jc higgins 20"er...
FD4E
Old 12-16-2012, 02:43 PM
fatdaddy's Avatar
There are (at least that I know of,) 2 different sizes of bolt hole diameters on the sprockets. This also means that there are 2 sizes of back plates and mounting rubbers. I don't know why, but I found out the hard way. I've MADE different sizes work together when I had no choice, but it wasn't easy.
fatdaddy.
Work harden the bolts my A**. I use them over and over till they strip out.
Old 12-16-2012, 02:53 PM
Wickedest1's Avatar
fatdaddy.
And thats what is happening with the old bolts...the nuts spin but dont loosen...and im out of dremel cut off wheels for the moment...
FD4E
Old 12-16-2012, 02:59 PM
fatdaddy's Avatar
Drill out the head of the bolt.
Tags
MotorBicycling.com
