Old 12-03-2012, 10:09 AM
d_gizzle's Avatar
d_gizzle d_gizzle is offline
Ok wickedest,ill be on the lookout for your thread.
Old 12-03-2012, 11:16 AM
fatdaddy's Avatar
fatdaddy fatdaddy is offline
Originally Posted by soup325 View Post
just an idea...
why dont you use an 12V alternator from a small car/motorbike....fab up a chain drive...and bing.....some wires.....lots of juice for lights, sirens, and a phone charger or stereo.
They don't really make em small enough to use on a bicycle. I guess you could use a small motor and reverse the polarity. But I don't know if that is even possible.
fatdaddy.
Old 12-03-2012, 02:26 PM
jimmymc2286 jimmymc2286 is offline
just an idea...
You can use a brushless motor like used on RC airplanes and make the converter to dc and that will charge a small battery. They are using this setup on RC helicopters. Do a Google on it.
Old 12-04-2012, 08:44 PM
Nashville Kat's Avatar
Absolutely nothing!
Rode the ole Peugeot out to coffee and then some- seven miles or so- peddlin all the way- almost 59- used to be a warm up before a race, but keeps me goin now
Jacksonville- sunny and low 70's- Far Out!
Old 12-04-2012, 10:20 PM
fatdaddy's Avatar
Thanks for the weather report Kat, now I'm really depressed.
Worked on a customer build all day,
No time for the coffee shop,
and it's been cool and overcast all day long in San Jose.
fatdaddy.
Old 12-04-2012, 10:26 PM
moonerdizzle's Avatar
moonerdizzle moonerdizzle is offline
since its no longer riding season ive been making videos of my bike, hoping to have one more warmish day to do a ride along video with a better camera. and by warmish i mean 31 or over. also got around to making a oil catch can write up and video, its in the four stroke section if any one is interested.
that effin moon kid
LabRat that golden pos ya got with the homescooled monarks
coated pistons
http://motorbicycling.com/showthread.php?t=42853
Old 12-04-2012, 10:58 PM
MEASURE TWICE MEASURE TWICE is offline
I have an extra alternator from a pickup truck that I got 230 thousand miles on and subsequently have sold. There was just one brush that was cracked, but working enough to run real noisily just after about 30 thousand miles and no warranty for the work. If I had known first, I would have just removed the broken piece and taken a Dremel to form a new round edge on 2/3 of the remaining brush.
I bought a new alternator and regulator with integral brushes built in. The brushes cannot be bought without the voltage regulator unless you try spot welding some brushes that you might find somewhere to fit.
I kept the old alternator and got extra voltage regulator and extra pulley and had kept in truck for long trips to swap in place doing the work myself on the road if necessary.
Now with my motor bike and a piece of a jack shaft is left long enough sticking out if I remove a cover, I can put a pulley on it to match the old alternator pulley.
I do need a battery as an alternator needs the 12 volt field current, but my old electric troll motor AGM battery will do at 12 volt 30 ampere hour.
Now I plan to make a cover to this setup for just stationary use by popping off the belt to rear drive wheel and find a way to make a custom carbon arc lamp to use with it.
With the 60 amps when running this hair brain scheme, I hope there is a possibility of a 720 watt arc lamp.
I have to research maybe 12 volts direct current needs to be up higher for arc lamps so an inverter to get higher voltage and using alternating current might do.
Hacking the alternator and using the AC out put before the full wave bridge to get the higher voltage might be an option that would omit the inverter.
What’s that beam up in da sky?
MT
A carbon arc lamp using lantern battery (link):
http://www.instructables.com/id/Carb...ghts/?ALLSTEPS
Last edited by MEASURE TWICE; 12-04-2012 at 11:29 PM. Reason: A carbon arc lamp using lantern battery (link)
Old 12-04-2012, 11:01 PM
d_gizzle's Avatar
Measure twice,that's the bat signal.
Old 12-04-2012, 11:30 PM
GearNut's Avatar
GearNut GearNut is offline
Originally Posted by MEASURE TWICE View Post
Now I plan to make a cover to this setup for just stationary use by popping off the belt to rear drive wheel and find a way to make a custom carbon arc lamp to use with it.MT
I used to make carbon arc lamps when I was a kid.
I took the center carbon rods out of old Rayovac size D batteries.
The rest of the lamp details I will not bore you with.
I never did come up with a device to accommodate the erosion of the carbon rods though.
They were lots of fun!
The_Aleman:
________________________
ROTFLMAO!!!!!!
Old 12-04-2012, 11:47 PM
MitchP's Avatar
MitchP MitchP is offline
I made a clutch roller out of a strike plate for a door.
People on 4 wheels are always out to kill people on 2 wheels. ~MadProfessor
it's hard to be snob when you're riding a moped lol.
~BikNut
Tags
MotorBicycling.com
