Old 11-28-2012, 05:15 PM
fasteddy fasteddy is offline
fatdaddy,
Love that trike of yours. Like you said it would be hard for the motoring public to see you even with flags waving.
Around here your life expectancy on a main road would be about 2 blocks and that's if your beyond lucky.
We can only have 3 wheels up here as well unless it's pure pedal power then you can use 4 wheels. Add a motor and it's 3 wheels. What most people don't realize is that the U.S. and Canadian governments have the same auto laws governing what can be used on each others roads. Cuts down confusion and vehicles being illegal in the other country.
Steve.
Old 11-28-2012, 05:44 PM
fatdaddy's Avatar
fatdaddy fatdaddy is offline
Yeah d gizzle, It's a tadpole recumbent motorized. I took an old gocart frame, married it to a goped, put some pedals on it, and with a lot of other crap involved, like trying to figure out how to put both sprockets on one side, ect, Tri-Baby was born.
And yeah fasteddy, IT'S DANGEROUS. Even with the light on the pole and a flag I have to be VERY carefull. But so far, So good. It'll only do about 28mph so it's not like I'm running at light speed. And with disc brakes it stops pretty good. And like I said, I'm VERY, VERY carefull when I'm riding it.
fatdaddy.
Old 11-29-2012, 11:18 PM
dracothered's Avatar
dracothered dracothered is offline
Got my new all steel 90 degree 1" tube elbow from this company http://www.woolfaircraft.com/index.html. I had to cut down the tube to be able to use it and then open the holes in the flanges some more.
Old 11-29-2012, 11:21 PM
fatdaddy's Avatar
That's the ticket. Exactly what ya needed.
fatdaddy.
Old 11-30-2012, 12:12 AM
fatdaddy.
Still not sure if I want to take it someplace and have it welded or brazed. Or try to braze it or Silver solder it myself.
Old 11-30-2012, 12:36 AM
fatdaddy's Avatar
Silver solder should work just fine. And if ya don't like the way it comes out you can take it apart and try it again. Brazing is more permanent.
fatdaddy.
Old 11-30-2012, 10:24 PM
Scootmeister Scootmeister is offline
It seems like every time I turn around I'm replacing batteries for my lights, so I decided to make a lighting coil like the ones I had on my 50 cc motorcycles when I was a kid. I spent all day winding 18 gauge magnet wire on an old laminated magneto and fabricating a mounting plate to ensure that the coil was in line with the magnets on the flywheel and fit within the pull start housing. My incondescent headlight worked great with the coil, but the LED tail light will have to be replaced. Or, I might go to a LED headlight instead and add a rectifier. No more batteries (except for my vintage horn which might have to go if I do the rectifier thing).
"If bulls didn't have horns, everyone would be a Matador".
Old 11-30-2012, 10:46 PM
VIKTR VIKTR is offline
Threw on an expansion chamber... seems like it has a little more bottom end power which is what I was hoping for
Old 11-30-2012, 10:51 PM
Some pictures please...
Old 11-30-2012, 11:29 PM
I got the tank I will use today.
Tags
MotorBicycling.com
