Old 11-23-2012, 10:06 AM
fatdaddy's Avatar
fatdaddy fatdaddy is offline
Mooner is right about the drill speed if you have a variable speed drill press. If yer doing this with a hand drill I will pray for you.
If ya just do like I said, OIL, WOOD backing, START smaller then go bigger, IT WILL WORK, I PROMISE.
fatdaddy.
P.S. I bet if you look at the back side it has a slight bulge in it. Hence the wood backing for support. It is pushing hot metal and rounding out to the roundness of yer bit.
Old 11-23-2012, 01:44 PM
bigbutterbean bigbutterbean is offline
Loosened my flower nut just a quarter turn, and now my bike starts much easier and idles a lot smoother. Was having some issues with starting and idling as well as my killswitch not always killing my engine the first time I would flip it. Adjusting my flower nut resolved all three of these issues.
Old 11-23-2012, 03:58 PM
dracothered's Avatar
dracothered dracothered is offline
fatdaddy.
FD thanks it worked like a charm.
Old 11-23-2012, 04:16 PM
rustycase's Avatar
rustycase rustycase is offline
Gutter Rider
somebody tell me you are not gonna braze that copper pipe elbow onto the steel flange and use it on a motor...
it won't work for long.
the heat from brazing it, or the vibration of the motor, or both, will work harden it and it will crack at some in-opportune moment... could cook your motor, if not worse.
sry guys, I just dialed in, and saw this... had to put in my two cents to save you some grief.
Best
rc
My goal is cheap, reliable, personal transport, below the tax collector radar. Fun counts for a lot!
Old 11-23-2012, 04:19 PM
moonerdizzle's Avatar
moonerdizzle moonerdizzle is offline
i just got a few more pistons coated to sell, and got the next batch of pistons ready to run for next month
that effin moon kid
LabRat that golden pos ya got with the homescooled monarks
coated pistons
http://motorbicycling.com/showthread.php?t=42853
Old 11-23-2012, 04:24 PM
2stroker 2stroker is offline
I broke my hand the other day riding my honda cr250. so today i switched the throttle lever to the left side of my bike and went for a ride. couldnt go to fast cause i only have one hand right now..but it was fun..like always!
Old 11-23-2012, 04:31 PM
Best
rc
I'm using Silver Solder and if I remember right the only way to work harden copper is pound on it or bend it. The heat used to Silver Solder it will anneal the copper if I'm not wrong.
How would you do this if you had to make an intake then?
Old 11-23-2012, 04:41 PM
Blakenstein's Avatar
Blakenstein Blakenstein is offline
Originally Posted by Wickedest1 View Post
I've run into the same issue before, different application but same problem...use a nail or screw and hammer into the hole making a groove for the drill bit to catch and it should work...if not go smaller on the bit, then larger...if that doesn't work try calling superman to burn thru with his laser eyes...good luck sir
Nails and screws will not work on metal , for wood, yes but for metal You need a center punch . You should not even have a drill without one. When drilling through steel, make a dent in the center of your hole with the punch. Then drill a much smaller hole first . This is called a pilot hole. You can even drill a second one, being a little larger. You do not need a drill press for that.
One more thing . This is very importent !! Use cutting fluid or threading oil, or you will burn that bit to nothing and will have to sharpen it.!!!
P.S. Center punches are very very common and u can get them at your local hardware.
It is obvious that you are a beginner cause you did not drill a pilot and you burned up your bit but thats okay . We all had to start somewhere, and you are doing a good job cause yopu are almost through.
Very Importent: WEAR SAFTEY GLASSES !!! All it takes is just one tiny little hot chip or kernal to screw you up real bad!!! I'm surprise that nobody here has told you this.
Old 11-23-2012, 04:49 PM
fatdaddy's Avatar
Hey Big, I don't see how loosening the nut would make yer engine start easier, one has nothing to do with the other UNLESS clutch was slipping, then TIGHTENING it would help, not the other way around. And the only way it would help the idle is if the clutch was not fully disengaging and dragging at the engine when the lever was in..
And then there's the kill switch. I'm just goin, HUH, WHAT THE---?????
NO WAY IN THE WORLD would adjusting the flower nut make yer kill switch work better. Think about everything you said, trace it in your head as to WHAT can ACTUALLY affect WHAT.
Not tryin to be an A**, but again, think hard about it. Taking the clutch adjustment OUT would not affect any of these things.
fatdaddy.
Old 11-23-2012, 05:10 PM
fatdaddy.
Ok, the clutch was too tight. It wasnt disengaging completely, and thats what was causing it to not idle correctly. Have you ever hit your killswitch with your clutch engaged? It doesn't shut off the engine. So the clutch not disengaging completely could definitely cause the killswitch to not work properly. Here is how I theorize that the clutch being too tight could cause starting issues. There are two springs that work the clutch, an outer spring behind the clutch plate and an inner spring inside the engine case. These springs push in opposite directions. when the outer spring is slack, the inner spring is tight. Too much tension on the outer spring will cause too much tension on the inner spring, causing some slipping. At least this is my theory. I do know that my clutch would slip a lot when I would try to start it, and it was worse the colder it got. When I went to adjust the flower nut, I locked the clutch lever in place and removed the cover. Before I adjusted the flower nut, I puhed on the clutch plate and it was tight up against the pads. It didnt budge a nano-millimeter. So if the clutch plate was right up against the pads, then it wasn't disengaging properly. Whether I am right about how the springs work or not (which I could be, I'm not 100% sure on that), my clutch was definitely too tight. One thing I do know is that previous to making the adjustment, my engine would jerk sometimes when I would go to start it, taking off for a second or two, then almost dying, and doing that a few times until the engine would warm up. My theory on that is that maybe a cold clutch can slip if its too tight. But after loosening the flower nut today, I went around the corner and dumped the clutch and she kicked like a mule and took off instantly. No jerking, no starting and stopping. Also, the last time I started it, I tested my theory about the killswitch by pulling the clutch lever clear in to the handlebars and flipping the killswitch, and the engine died instantly. This was before adjusting the flower nut. If I tried the killswitch with the clutch lever locked, I would always have to hit it twice. Now that the flower nut is properly adjusted, I only have to flip the switch once. I can also hear the difference in the rpms at idle now. When the clutch was too tight, if I locked the clutch lever, the engine would sound too quiet, and when I pulled the lever all the way in, it would sound like normal. Now it sounds like a normal idle when I lock the clutch lever
Tags
MotorBicycling.com
