Old 11-22-2012, 04:14 PM
killercanuck's Avatar
killercanuck killercanuck is offline
Easy Blake, lol. Not much can be said about watching a cold start If you mount the camera and boot around in some snow that'd peak ppl's interest, eh?
I finished cutting some gussets for the Hack'em'up, they turned out good:
Cards, 29er, Trailer, Hack'em'up
Build with pride! Build to ride!
"A clean shop is a sure sign of a cluttered mind" ~ fasteddy
Old 11-22-2012, 07:04 PM
Blakenstein's Avatar
Blakenstein Blakenstein is offline
That's nice work !!! Ya thanks for the idea . I might just do that - a short one up and down the alley. I've got stuuded tires but the studs don't seem to be long enough - I should make my own like ones that you showed here in this forum a long time ago.
Old 11-22-2012, 07:52 PM
Wickedest1's Avatar
Wickedest1 Wickedest1 is offline
had my turkey dinner with the new horse...the ol lady didnt agree but i know how to get my way sometimes...plus it was like 90 degrees inside...enjoy
Thats a lot of moving parts...hope it all works...
FD4E
Old 11-22-2012, 07:56 PM
d_gizzle's Avatar
d_gizzle d_gizzle is offline
Wicked,that is just plain beautiful
Old 11-22-2012, 07:57 PM
k.mah k.mah is offline
Boost ported and intake port mached the piston today. did it make a difference....not on my butt dyno but maybe it will show while under load? we shall see
Old 11-22-2012, 09:04 PM
dracothered's Avatar
dracothered dracothered is offline
Worked on the intake manifold build but ran into one slight problem. I couldn't get the two bolt/stud holes to drill all of the way through. At first I though I dulled my bit so I switched out. Then I tried to drill the other one and got the same depth. Is it possible I hardened the steel that the flange is being made out of?
Old 11-22-2012, 09:08 PM
moonerdizzle's Avatar
moonerdizzle moonerdizzle is offline
use soap or some oil as a cutting fluid, whats your flange made out of?
that effin moon kid
LabRat that golden pos ya got with the homescooled monarks
coated pistons
http://motorbicycling.com/showthread.php?t=42853
Old 11-22-2012, 09:14 PM
As far as I know it is just a mild steel washer, just like the one next to the one I shaped already in the picture.
Old 11-23-2012, 09:31 AM
Wickedest1's Avatar
I've run into the same issue before, different application but same problem...use a nail or screw and hammer into the hole making a groove for the drill bit to catch and it should work...if not go smaller on the bit, then larger...if that doesn't work try calling superman to burn thru with his laser eyes...good luck sir
FD4E
Old 11-23-2012, 09:41 AM
lowering the drill speed might help also.
that effin moon kid
coated pistons
Tags
MotorBicycling.com
