Old 10-23-2012, 11:06 PM
VIKTR VIKTR is offline
Originally Posted by fatdaddy View Post
You must be using the white wire for the kill switch,(maybe not.) BUT, if so, cap off the white and wire the two kill switch wires to the black and blue wire on yer CDI.(one to each.) If you already have it wired this way then no explaination is needed. If not, just ask around and I'm sure someone will explain why it should be wired this way. Or just get back to me.
fatdaddy
I'm not using the white wire... you had already advised me against it
But one or both of the wires were touching the socket I had the switch sitting in. Electrical tape fixed it.
Old 10-23-2012, 11:18 PM
fatdaddy's Avatar
fatdaddy fatdaddy is offline
VIKTR, sorry bro. Yer right, we already talked about this. I read and answer so many posts on two sites that sometimes I lose track. The reason I thought it was a white wire issue is the only way to get a shock is to ground a wire to the frame, and thats how the factory recommends doing it.
(stuupit faktory.)
fatdaddy.
Old 10-24-2012, 12:55 AM
xcspirit xcspirit is offline
replaced gaskets. which stopped the oil leak at the exhaust. and bought a red light for the back
Old 10-24-2012, 07:11 PM
killercanuck's Avatar
killercanuck killercanuck is offline
Replaced a crank that blew the bottom con-rod bearing(of course, only bearing not easily fixed, doh!). Crank bearings were locked onto that crank and came out of the case with it(no decent puller yet). Soo, dug out an old case for bearing harvest... Swap bearings from 49 case to 66 after freezing bearings/heating case in oven, reassembled.
And all with only one decent blood blister Good day
Cards, 29er, Trailer, Hack'em'up
Build with pride! Build to ride!
"A clean shop is a sure sign of a cluttered mind" ~ fasteddy
Old 10-24-2012, 07:46 PM
(stuupit faktory.)
fatdaddy.
No worries
Cleaned the carb, shortened the throttle cable
Old 10-24-2012, 08:45 PM
fatdaddy's Avatar
Not really an "oil leak" Just a dirty old 2 stroke doing what it does best, Throwing oil everywhere. What is your mix ratio? If it's a LOT of oil on yer cylinder you might be running it too heavy. If it's a new engine then thats fine. Anyway, just wondering how much oil yer using per gallon.
fatdaddy.
Old 10-25-2012, 08:05 PM
dracothered's Avatar
dracothered dracothered is offline
Welded the other side of my motor mount. See the Huffy build for the pictures.
Old 10-25-2012, 08:38 PM
fatdaddy's Avatar
Saw it, Good job.
fatdaddy.
Old 10-28-2012, 08:56 PM
lksdG2's Avatar
lksdG2 lksdG2 is offline
swapped my mountain bike forks w/disk brake and shocks along with the handlebars on it, completely changed the look and feel as well as the riding experience. stopping is amazing and the steering will take a little getting used to but so far i like it...
couldnt find the motivation to swap out the rear white wall for a all black tire, but i will eventually
Old 10-28-2012, 10:43 PM
I changed up the the seat position from this...
To this...
On what was my dad's 58' Schwinn Wasp.
The Huffy is not in the build mix right now because I want to build up my dad's old bike in honor of his passing. So now I am switching all the Huffy parts to the Schwinn Wasp. Take a look at the link below for the build progress. Still not sure if I want to repaint it or just go with the rat rod look.
Tags
MotorBicycling.com
