Old 10-18-2012, 09:08 PM
lksdG2's Avatar
lksdG2 lksdG2 is offline
Built this chain tensioner the other day
Old 10-18-2012, 09:14 PM
Dan's Avatar
Dan Dan is offline
Staff
Love it IKSD2G! Very cool looking.
Jumpa, might be able to Google the numbers under the BB to find the year, DOB.
worst apocalypse ever
http://www.youtube.com/watch?v=y6Sxv-sUYtM
Old 10-18-2012, 10:57 PM
GearNut's Avatar
GearNut GearNut is offline
I installed an NGK iridium spark plug. Maby I will start it tomorrow and see if there is a difference.
The_Aleman:
________________________
ROTFLMAO!!!!!!
Old 10-19-2012, 01:40 AM
MEASURE TWICE MEASURE TWICE is offline
I recognize the wrench cut up parts used. That's really neat!
I am using V5 section belt with pulleys and may like to use an idler on the top (ruff section bump) side to push it in the opposite direction to make clearance.
I say may, as I have an alternate way of achieving a sort of multi-ratio for my pulley belt system. The only addition I may need to do with how you have it if I go with an idler, is to make two more rollers to capture the belt in the path so it is routed. It is about 1.5 ft length that I need to redirect it around an object where I had not expected in my original design.
The other way to change ratio / speed range, would have me take a cover with 8 screws and nuts off to change a 10 inch pulley with a 4.5 inch pulley.
MT
Old 10-19-2012, 09:02 AM
dodge dude94's Avatar
dodge dude94 dodge dude94 is offline
Took it off road yesterday. Did surprisingly well. It really shows its weight though, but it did 16mph through the pasture by my house. I lost a piece of my rear rack in the process, oops. lol
It runs so well when it's cooler outside, hits 30 no problem.
Old 10-19-2012, 06:42 PM
diceman2004's Avatar
diceman2004 diceman2004 is offline
My bike is an old monark ( originally a single speed ) now running a 6 speed . The bottom chainstays are just wide enough to get a 26 x 2.125 tire in .
I had bent the chainstay setting up the tensioner ( pedaling up the driveway ) when the chain rode up on top of the teeth .
new plan .. get rid of the stupid kit tensioner .
I cut out my bottom chainstays and replaced them with some cut up handle bars.
Now the chainstays are full axle width up to the pedals , and now i can run the chain direct from the motor to the sprocket without the tensioner to clear the stays .
Some people get lucky with thier frames , but my motor sits pretty low , and also it was an old single speed with narrow stays to begin with .
The new stays are only screwed in right now , just so i can use the bike untill i get them all welded up . not even gonna atempt to run a motor till the welding is done ,
Old 10-19-2012, 07:38 PM
killercanuck's Avatar
killercanuck killercanuck is offline
This is how you tow 3 bikes, can fit 4 in there but buddy wanted to ride the cruiser
Cards, 29er, Trailer, Hack'em'up
Build with pride! Build to ride!
"A clean shop is a sure sign of a cluttered mind" ~ fasteddy
Old 10-19-2012, 08:18 PM
VIKTR VIKTR is offline
Haha, that's awesome
I once secured a garden wagon to my bmx bike and hauled stuff around in it... it would have been much easier with an engine
Old 10-19-2012, 08:34 PM
Dan's Avatar
Dan Dan is offline
Staff
That is awesome Killer. motorized bicycle wrecker & tow!
I wanna do one for a bike repair and tune up service.
Old 10-19-2012, 09:06 PM
Nashville Kat's Avatar
Not a thing
GOD, I hate getting old-
I put up a storm door on the back door day before yesterday and it was the straw that broke the camel's back for a couple of very high tension days- sore ALL over and a fatigue of the ages- Autumn closin in!
http://www.youtube.com/watch?v=_mRFWQoXq4c
finally feeling better today- but not enough to ride.
Tags
MotorBicycling.com
