Old 09-08-2012, 12:10 PM
JonnyR JonnyR is offline
took a ride this morning to check out my work from yesterday must have had crap in the tank because it clogged the stock screen (should have known better) but got it to work again with a little road side mechanical work then when i got home i noticed i lost a screw from my new rear fender which sucks but i can get another plus i need to cut a little more off of the motor side for chain clearance it works but its to close for me i will just cut it with the grinder and re paint with rattle can black thinking about changing to my nt speed carb but dont want to mess with it while it runs good also thinking about making a exhaust out of 1" mild steel tube 1/16 wall or 1/32
Old 09-08-2012, 11:43 PM
happycheapskate's Avatar
I got my wife to ride hers today. She said she had fun and would come back to ride around the parks with me on bikes again. Last few times we tried it, she had knee aches and was aggravated about how to start the motor. This time, we have her seat and bars dialed in, and she has had more practice with the Dax kit. She rode through a whole tank (1/5 gallon) of fuel and we did not have to stop anywhere except to let our baby play at the usual stops.
1" roller Dax Friction Drive and Tanaka 3300 with mods.
Old 09-09-2012, 08:59 AM
Goat Herder's Avatar
Gutter Rider
http://motorbicycling.com/showthread.php?t=315 Might read this link. Much has been covered on the danger of front fenders. That fender can lock up the front wheel big time! While a rear fender might not be so bad to lock up it is still a unplanned event.
Old 09-09-2012, 09:35 AM
this only happens if you buy crappy fenders i have had the front on for almost 150 miles and a crash from being run off the road and it is still perfect the crash only scratched it and as everything on these bikes locktite is your buddy i can tell you a good body panel from a cheap one in 10 seconds of looking it over my welding is almost to the point of being great (still need the grinder) i do paint and also build motors (for cars).
today after the roads dry a little i might take her for a little trail ride and get a inline fuel filter and take the one inside the tank out add a small washer to the petcock to change its orientation and Teflon it back in trim my rear fender a little more also for extra chain clearance i hear it slap a little when i pull the clutch in and coast
Are you callin' me crazy! just cuz i got a hotel in my foot doesn't make me a boogali moogali moogali
Schwinn jaguar with a 66cc flying horse
they all run fantastic till they don't
smoke tires not drugs
YES! YES! JESUS H. TAP-DANCING CHRIST... I HAVE SEEN THE LIGHT!
http://www.youtube.com/watch?v=YoPVC4YxDlI
http://www.youtube.com/watch?v=y0O7_...eature=related
Old 09-09-2012, 09:52 AM
The_Aleman's Avatar
The_Aleman The_Aleman is offline
That isn't true at all. 150 miles? Ha! I've put over 50,000 miles on bicycles with fenders. Any bike with fenders can pose a danger if they are not secured. Motor or not, even just pedaling. Cheap fenders, expensive fenders, don't matter. If they aren't secured properly they can come loose.
Meh.
Old 09-09-2012, 11:31 AM
that is why you locktite the hardware i didn't locktite the rear yet because im still modifying it and yes a good fender makes a world of difference if its got fully rolled edges and stiffening beads rolled in it it doesn't flex i have do 30 - 35 mph on this bike regularly and the front stays right where it is supposed to be
Old 09-09-2012, 02:01 PM
fatdaddy's Avatar
fatdaddy fatdaddy is offline
It's not the fender, it's the cheap little tin tabs they give you to bolt it up with. They are usually pop riveted on and can break or just plain come loose. I usually remove them completely and make my own if I run with a front fender. After I make a tab out of better thicker steel I use a small bolt to attach it to the fender, Then peen it down like a rivet. Then lock washers and locktite to install. The rear fender is important also, just not as critical as the front.
Anyway, got my cheapo retro speedo in and installed. I'm finally almost finished with my bike. Well, as far as one can be with a build. There are always things that come up that make you want to change things around. I was looking to put drum or disc brakes on the front, but one was really expensive, (disc,) and the other, (drum,) was a LOT of work. (rebuilding and lacing a wheel.) So I got rid of the calipers and put on a set of cantilever forks. I got it all together last night and now I just have to tighten everything up and take it for a test ride. I found a set of Schwinn forks with cantilever bosses at Fabers Cyclery that are almost the exact copy of my huffy forks, so I kept the fat fork old school look. Was hoping to find some suspension forks with a 1" head tube and cantilever bosses but everything today is 1 1/8". Oh well, It's together now. LETS RIDE.
fatdaddy.
Old 09-09-2012, 02:41 PM
Mike B's Avatar
Mike B Mike B is offline
Rode the e-Revive out to the local street festival. Rode right past the barricades up to a street sign and locked the bike to the sign.
Got some food at a couple of stands, put it in the basket and rode home and had street fair food with pops.
People were talking. What is that? That's an electric bike. Where do you get those? Looks like the guy built that one. That's cool...
I just love riding past barricades. Can't do that with a motorcycle -
I did take the scooter up to Stockton yesterday for the Greek festival. Sign said parking lot full. But they can always find space for a bike -
Good weekend, lotta 2 wheel ridin', lotta good food and drink, lotta good conversation. Mostly about good food. All made easier by motorized bikes and scooters.
Cars suck for getting to crowded events -
The only thing in my garage with 4 wheels is the lawnmower
Old 09-09-2012, 11:30 PM
Arrow Re: what did you do to your motor bike today?
This topic comes up a lot in the motorized bicycle world. The only mass production 1" threaded suspension forks are from RST, and not "real forks", basically just spring and elastomer jobs that work, but don't have any real damping.
You can convert your 1" threaded bike to take 1 1/8" threadless forks, but you will need probably 2 headsets to combine, and will need a threadless stem to match the fork. Call Lynne at www.custommotoredbicycles.com if you really want to do it without welding a new head tube on your frame.
fatdaddy.
Old 09-09-2012, 11:40 PM
d_gizzle's Avatar
d_gizzle d_gizzle is offline
Monark forks are true shock forks and they most certainly have disc brake adaptors AND they are 1 inch threaded.
Tags
MotorBicycling.com
