Old 08-01-2012, 08:20 PM
Goat Herder's Avatar
Gutter Rider
It just needs to be above the water lol.
On second thought I just remembered when I had set my first tank up ages ago with this fuel line like this as a vent. On a hot summer day I had my fuel line up high and got fuel dribbling out of the vent line. It was not until my first Boxer bike purchase and I saw how they vented it that I don't use that hose as a vent any more. Just finessed my fuel cap to breath and plugged that port off for ever. Works perfectly for me...
Their tank had that port blocked off plugged. There was only one line coming out of my tank the fuel line that was it. Only thing was that later I discovered my cap needed modded to breath and that the fuel filter the tank came with ''Goped suppler'' had a very small restrictive fuel filter.
I gutted the fuel filter out and used it to attach my hose. Then put a nice inline filter down the line. It has been pleasant ever since.
Old 08-01-2012, 10:06 PM
grizadams's Avatar
grizadams grizadams is offline
Do you have a petcock/shut off valve? I would like one I could attach to my frame.
Old 08-01-2012, 10:20 PM
Ibedayank's Avatar
Ibedayank Ibedayank is offline
one of the FEW i found that you can make a bracket to mount it
http://www.themopedjunkyard.com/fuelvalves.html
its the part number 900
Live life as its your last day... it just may be
Learn to do it right or how to fix it later, quicker to do it right the first time.
Old 08-01-2012, 10:29 PM
grizadams's Avatar
looks like that would work thanks.
Old 08-02-2012, 01:08 AM
happycheapskate's Avatar
http://sadpanda.us/images/1111584-SPNW04K.jpg
I mowed a yard with my bike. hahahha. I could use my motorized bicycle if the grass wasn't so high and I could go a little faster. If I put the 1" roller on the Dax, it will work. If I use a 44 tooth wheel cog on the china-kit bike, it should work well. That will be wild, mowing a yard with a little motorcycle. hahaha
I'm not inclined to go real fast on it. Also the design can work with a 4 string trimmer head, especially if you have a long crankshaft, or can machine a 6-10" round flywheel. You can file some 1/2" bolts flat and drill through them, to pin down weeder strings (.155")
http://youtu.be/dT_RbxgruLs
1" roller Dax Friction Drive and Tanaka 3300 with mods.
Old 08-02-2012, 01:54 AM
fatdaddy's Avatar
fatdaddy fatdaddy is offline
Added dual brake...works great.
Support bracket for gas tank. Did notice that maybe I should have tilted the tank back towards the seat so I can get more gas out of an almost empty tank.
Think I'll cut the welds and weld hinges on it so I can tilt it back.
Goat What do you think about how I wrapped the vent around the bracket?Seems like it hasn't leaked yet.
Depending on where your vent tube goes onto the tank. I think if ya fill the tank higher then the vent tube end, simple physics says it's gonna overflow. The tube end needs to be higher then the fuel in the tank or it will "gravity feed" out.
fatdaddy.
Old 08-02-2012, 05:21 PM
grizadams's Avatar
Yeah that's what I'm gonna do, I'll get it high than the gas tank...I think I'll be mounting it to the front pretty soon any ways, got a new fork for my bike so no more brake cable in the way.
Old 08-02-2012, 05:42 PM
grizadams's Avatar
Thanks for the heads up on the petcock...I ordered it.
Old 08-02-2012, 08:33 PM
xenodius xenodius is offline
Switched out some jets on my carb since it was four-stroking, went from a .70 to a .66. Plug chop indicated it was a little bit lean, then I realized I had an air leak. Fixed that, went to a .68... looks good, but for some reason my top end is still 29mph even though it's not four-stroking... and I've lost a noticeable amount of acceleration power confirmed by GPS.
I should be getting more than 29 mph top with a 66cc and a 36t sprocket, shouldn't I? I've ridden it over 50 miles. I just want to go 35 to keep up with traffic... I doubt everyone else is imagining they're going as fast as they report. In fact, switching to a 36t from a 44t only added 2 mph. I thought several folks said they could get their bikes to 6,000 rpm at WOT, but the best I can do based on my speed is about 4,500.
In other news, finally got my CREE P4 LED's and mounted a pair into 2 heatsinks with thermal epoxy, it's almost set and then I'm going to mount them in the reflectors and then mount them into my headlight and wire them up. =) Going to try the notorious white wire first, then resort to my dynamo if that doesn't work.
Old 08-02-2012, 08:37 PM
Ibedayank's Avatar
hills... your weight.... your size wide/tall.. how heavy the bike is...
A 5foot tall #120 guy will go faster then a 6 foot 5 #300 guy on the same bike over the same road
Tags
MotorBicycling.com
