Old 07-14-2012, 05:08 PM
killercanuck's Avatar
killercanuck killercanuck is offline
I actually have something bike-related to post, yay?
2nd jug gasket to blow in as many weeks, two different bikes, must be a summer thing Or more likely, me slacking and not doing it right the first time...
First one was a straight up huffy cruiser, lots of room to pull the jug. No problem. 2nd one was my 29er with the shift-kit... Doh!
A typical low budget motorized bicycle riders kitchen, yes I eat in front of my computer :
My baby looks so naked:
Picked up one of these plastic drawer things, does the trick and helps to keep organized:
I'm glad my tow bike is handy in case I get the itch to go for a spin. But it doesn't compare to the 29er, ie. "Why am I going so slow?" D=
Gotta get'r tip-top because Whelan and I have quite the cruise planned for this week, so I gotta keep up with his EZM. (I know, I know... I'm bringing a spare top-end and cdi/mag, chains, tubes, etc) I think it'll be almost 800km to meet him halfway and cruise back here. Should be crazy fun!
Oh yea, that bucket on the table has a couple cups of 10w-30 soaking the little chains and spacers, should permeate good, eh?
Have a good one everyone! Ride Safe!
Cards, 29er, Trailer, Hack'em'up
Build with pride! Build to ride!
"A clean shop is a sure sign of a cluttered mind" ~ fasteddy
Old 07-14-2012, 09:22 PM
Allen_Wrench's Avatar
Allen_Wrench Allen_Wrench is offline
Resident Mad Scientist
Originally Posted by Allen_Wrench View Post
Wish me luck. I'll be heading out tomorrow to a Ride-in Bike Show at Indy's own Eiteljorg Museum, as sorta part of the Steel Ponies exhibit. It's not so much a big formal thing, but Easy Riders Magazine photographer Michael Farabaugh is supposed to be there. And I intend to take a few pics of my own, and post some here. So I have spent most of this evening going over my bike, top to bottom, tightening any nuts or bolts that seemed they should be tighter (not many of these) and checking my engine mounts, chains, cables, fuel delivery, tire pressure, lights, etc. etc.
Then, of course, I went out for a very pleasant evening cruise. And I have to say, I am probably the last guy to jump on the "China Girl Haters" bandwagon. While I have to agree: these are certainly not Morinis or even Hondas, I must say mine is fairly decent by a long way. And probably more reliable than any HT 2-stroke was ever expected to be. As my old Dodge Caravan grows more temperamental with each passing year, I find myself making more local jaunts with the bike. And trying to keep most jaunts local.
I did it. I posted some bike pics in "Travels and Adventures" under the thread. Eiteljorg Bike Show (I think). It was fun, and my fellow bikers really loved my ride. It was cool.
"There is nothing wrong with wanting a motorbike that is an extension of your personal taste and fashion sense; if you must ride somewhere, I say do it with style!"
Old 07-14-2012, 09:49 PM
Scootmeister Scootmeister is offline
Today I was able to spend 3 hours working on my Stiletto bobber. First, I notched the swing arms on my springer front end so now the axle will drop out making it easier to repair flats or change wheels/tires. When I originally fabricated the springer I simply drilled a 3/8" hole for the axle which required me to remove both swing arms to drop the wheel. While I had the wheel off I upgraded the "brand X" brakes with 203mm Avid Clean Sweep discs and BB7 calipers ( I have the same brakes on my other motorized bicycle and they will lock 'em up). My original aluminum "Harley Style" caliper mount would flex under heavy braking so I fabricated a new mount from 3/16" flat steel. Finally, I mounted a new Whizzer speedometer sending unit to the wheel to drive the Whizzer speedometer I mounted on the bike several months ago. Tomorrow I will paint the new caliper mount, drill a hole in the springer top mount for the speedo cable, and fabricate a mounting bracket for the LED headlight I made from a black & decker flashlight and chrome headlight bucket.
"If bulls didn't have horns, everyone would be a Matador".
Old 07-14-2012, 10:07 PM
Goat Herder's Avatar
Gutter Rider
Nice Kitchen. That's my kinda Kitchen
This friggin hot weather has teased me just a little with my 21mm PHBG del carb on my BoXer. In the heat of the afternoon it is too rich. In the Morning its just a smidgin too lean. This has been so ever so slight some one else might not notice?
Researched spark plugs and found one that will self clean perfect to go richer for optimum power! 6 heat range with an extended electrode. Nice 19mm reach NGK and still works with my D.H. attachment. Most importantly does not hit the piston lol.
While playing with the air mixture screw began too notice the tiniest spot on my throttle body needle that I wanted to make ''I mean JUST barely richer''.
Gave it two days of thinking and chucked up the throttle body needle in a cordless drill. Right at the tip of the needle 1/4 of an inch inward took off guessing? about 1 thousand of an inch with sand paper. Used 80 grit then chased the scratches back of with 1200 grit. Material came off alarmingly fast. Glade I* quit when I did.
So far I like it!
Off the line the launch is like mebbe a whole 2% stronger lol when I want it to be and it still cruise's modestly at as low as 5 mph. Its the little things in life... just love to tinker and chase perfection
Old 07-14-2012, 11:19 PM
Who else can't eat without a vid queued? Now that's fine tuning when 1200g is taking off too much
Old 07-15-2012, 12:18 AM
Gutter Rider
It was one heck of a lucky guess man. For a few I thought wow wounder if I just totally trashed it and messed up? Egdeimucated guessing? At its finest. Just gotta try it? Lucky Never know other wise?
Did have a spare W7 needle on stand by but it's for another motor and a another 21mm carby. So all this guess work is gonna get repeated! Slowly but surely er surly. Ha ha
Now if my fuel mixture screw is off by much 1/4 turn. It will act a tiny bit like the main jet is off? Mebbe to a fellow that would not know how this carby acts? Talking mid range feel now instead of the first 1/3 of throttle. Touchy bugger.
Ran repeated laps around the city block here tuning that screw and its dead on. Pretty tickled with it ATM! Dang now I got to go fire it up again! ''Mandatory!'' This is half the fun. Can't wait for winter to see the differential? It is gonna hit sweet hard!!
Last winter it ran awesome. At times this thing ran and thought like it was a 80cc engine?
Will have to split the difference on that screw for the hot of day and the cool of morning. Only the two hottest months of summer teases me like this. Was the same thing last summer when I first got anywhere near tuning this carby right and finally figured out WUT I was doing???? Have come a long ways with this machine. Loving it now more and more.
I am putting a big honking carby on a 49cc motor after all at a pretty high altitude over here. Darn carb barrel is darn near the size of the piston! Surprisingly if I just go about 20 mph everywhere and never open it up it gets close to 150 mpg? If I beet it more like 70 mpg. Barometric atmospheric conditions etc change tiny little character notes now and then here in the summer desert. Love it when it rains... This bike is my favorite toy right now.
Old 07-15-2012, 12:26 AM
Ibedayank's Avatar
Ibedayank Ibedayank is offline
lol I normally have a movie playing
Live life as its your last day... it just may be
Learn to do it right or how to fix it later, quicker to do it right the first time.
Old 07-15-2012, 01:50 AM
humm318 humm318 is offline
Trying to fine tune the carb. just found a leak in the gas tank by following the trail of blistered paint on the tube.
I guess I know what Im doing tommorow!
Old 07-15-2012, 02:23 AM
happycheapskate's Avatar
Hahhah. My wife made me get another keyboard for eating dinner at the computer.
1" roller Dax Friction Drive and Tanaka 3300 with mods.
Old 07-15-2012, 05:02 PM
DaveC's Avatar
DaveC DaveC is offline
Brake arm got here, finally. It's a Wald and it's about 1.5x as thick as the CYY Chinese one that broke. I need to find someone with a oxy torch to heat it up and bend it. My propane torch won't come close to getting it hot enough to bend and I don't need to break another.
The X is here so it's takeing me forever to get this posted
Tags
MotorBicycling.com
