Old 06-17-2012, 09:11 AM
Dan's Avatar
Dan Dan is offline
Staff
Thumbs up Re: what did you do to your motor bike today?
Originally Posted by tooljunkie View Post
try to find a small piece of tubing that fits in the hole,and a drill that fits the tubing.it will keep the bit close to center allowing you to get a mark started for drilling.
i have done this with good success.
a centre punch,good and sharp and a teenie drill bit will get it started too.
a pilot hole is always a good way to start.
third is for hard bolts,a carbide burr in (i prefer the ball shape) a slow drill will grind away the broken bolt.very slow and compressed air to blow away the chips.
i was the broken bolt guru in the shop i worked in for a few years,exhaust manifolds were my forte'
Cool tip/trick FD! I always mess up the pilot.
Gonna try that. Thanks!
worst apocalypse ever
http://www.youtube.com/watch?v=y6Sxv-sUYtM
Old 06-17-2012, 09:20 AM
tooljunkie's Avatar
tooljunkie tooljunkie is offline
i got a million of em,i just need to remember.
im fortunate enough to have a lathe,so i can make a drill bushing for any bore i need.
Old 06-18-2012, 03:39 PM
Steve1990 Steve1990 is offline
Test fit my engine in a '75 Schwinn Continental. I think it may be getting a new home.
Old 06-18-2012, 05:09 PM
fatdaddy's Avatar
fatdaddy fatdaddy is offline
A nice, lightweight chrome-moly steel frame. They used brazed connections instead of the "lug" type. It should make a great Motorized. Send us some pic's when it's done.
Big Red.
Old 06-18-2012, 05:39 PM
ran into a hitch with it almost right away. Since it uses tall flange hubs, I can't bolt the sprocket to it. Not too big of a deal, I've got other hubs I can build the wheel around, just wasn't planning on rebuilding a wheel for this.
Old 06-18-2012, 06:17 PM
fatdaddy's Avatar
Hey Steve, You can enlarge the center hole of the sprocket. I do it all the time for coaster brake hubs. I did just notice that the Continental is one of those "skinny tire" bikes. To each his own, I just prefer building a bike with more rubber on the road. It is a great frame though.
fatdaddy.
Old 06-18-2012, 07:06 PM
Its not the bore size thats the problem, its the fact that the bolt holes on the sprocket aren't far enough apart to clear the hub flange. They actually line up perfectly with the part of the flange that the spokes pass thru.
Old 06-18-2012, 08:35 PM
fatdaddy's Avatar
That would be an awfully large hub flange. is it this one? This is an original 1975 rear wheel, or so the dude claims. It doesn't look all that big in the pic. But I guess you would know. How about a pic of it?
fatdaddy.
Old 06-18-2012, 10:30 PM
That isn't a '75 hub, but it is the same size. A '75s hub has triangular openings, otherwise the same. Its not really that big, just big enough that the holes in the sprocket don't clear the edge of it.
Old 06-19-2012, 12:11 AM
fatdaddy's Avatar
Might be a stupid idea. If it only misses by a LITTLE bit, take a small round file and notch out for the bolts. I've done it on a OCC with the big flange, worked great.
fatdaddy.
Tags
MotorBicycling.com
