Old 05-12-2012, 10:59 PM
Scootmeister Scootmeister is offline
Hey Gearnut, I'm sure you already know this but if 3" tires are a little too wide I have seen some 2.5 inchers. I can't remember the brand but they had road tread.
"If bulls didn't have horns, everyone would be a Matador".
Old 05-12-2012, 11:01 PM
Goat Herder's Avatar
Gutter Rider
I wanna know where he found three inch wide tires?! If that's the case?
Old 05-12-2012, 11:16 PM
Allen_Wrench's Avatar
Allen_Wrench Allen_Wrench is offline
Resident Mad Scientist
You don't have to find 'em; you've already got 'em. You call 'em 2.5" when you put 35 PSI in 'em. You call 'em 3" when you put about 80 PSI in 'em. But watch those pot holes.
"There is nothing wrong with wanting a motorbike that is an extension of your personal taste and fashion sense; if you must ride somewhere, I say do it with style!"
Old 05-12-2012, 11:21 PM
GearNut's Avatar
GearNut GearNut is offline
The Hookworms come in 2.5 width too.
As soon as I get the $$ saved up I think that I will try them anyways. If they don't fit, perhaps someone here would want them?
The_Aleman:
________________________
ROTFLMAO!!!!!!
Old 05-12-2012, 11:24 PM
Hey Goat, check out "way to roll" on ebay. He says they are a true 3" and he has 8 of em. There are others out there, Coker sells em but they are pricey. I've seen the Maxxis 3 inchers but can't remember where.
Old 05-12-2012, 11:29 PM
rustycase's Avatar
rustycase rustycase is offline
Gutter Rider
WoW !
Tree inch wide tire is gonna need at least a little persuasion administered to the aft end!
At least to keep things aligned so the chain doesn't eat through the tire!
It's just annoying to have all the scuffing on the sidewall. :-)
S, well yah goofed on that !
No harm done, because you figured it out.
That chain must run really straight and true or you will encounter many problems when you get to motoring it down the road.
If chain alignment is not right, first thing that happens is it gets thrown off and most the time it locks up the back wheel. You may go down!
Avoid that, if possible ! It takes all the fun out of motorized bicycles.
Trial run... wear ALL the protective gear.
Long pants, jacket, and gloves. A scooter helmet, even a full-face bicycle helmet is a good prospect. Sore is bad, but road rash takes a while to recover from.
OK, what did I do to my motorized bicycle today?
Moved it. It was in the way.
But yesterday, well, the day before, I took the carb off to mail it to another member who is a masochist. :-) I guess he wants to xperiment with cns... 8-O
Tank is off now, too.
...Tank is absolute LAST thing to install on a motorized bicycle!
Every single time the handlebars turn they hit the tank!
It's just NOT good!
I'm gonna take the grinder to the dropouts and make an adjustable axle slot for chain tension. There's just NO other solution that is practical!
Best to all,
And Thanks to Skarrd for this thread!
rc
My goal is cheap, reliable, personal transport, below the tax collector radar. Fun counts for a lot!
Old 05-13-2012, 02:09 AM
Gutter Rider
They are noticeably smaller than my 3.0 Bermmasters to me. I got room for'em
Old 05-13-2012, 09:17 AM
Skarrd's Avatar
Skarrd Skarrd is offline
Pulled the driven pulley off and noticed I had set the guides wrong on it (explains the sudden super slack in the belt). the way i had it set, the rotation from the belt would loosen the pulley rather than the tightening from the belt loosening the pulley.
Originally Posted by rustycase View Post
Best to all,
rc
you're welcome ^-^
They see me rollin'
they hatin'
Originally Posted by biknut View Post
Traditional bicycle riders think we're cheaters. Non riders think our bikes are toys. Bicycle shops think we're a threat. Tree huggers think we're polluters. The police don't know what to think.
Old 05-14-2012, 01:20 AM
Priming & sanding the new tank. If I can have it finished and installed before May 23rd I will try to show up for Community Day at the Speedway track. Here's wishin' for a few more sunny days.
Old 05-14-2012, 02:55 PM
BoDean_LP's Avatar
BoDean_LP BoDean_LP is offline
This is what I did in the past week:
Installed some off brand plug (Smoother idle and acceleration now)
New back wheel and #41 chain (No more chain hopping off)
Removed head and polished combustion chamber (Way better low end torque)
Replaced acorns with grade 10.9 hex nuts (No more loosening head bolts)
Adjusted float level and air/fuel mixture (Finally got her tuned up )
Installed new petcock O-Ring as well as a new carb O-Ring (No more fuel and air leaks)
Replaced front motor mount bolts (Killed lots of vibs, no more unscrewing while riding)
Upgraded to larger/better Schwinn bicycle computer (My little one broke, so...)
Brand new tire and tube on back wheel (Smoother ride, better traction, no more leaks)
New gel filled seat cover for help with seat vibration (Feels like a new bike)
WRECKED AT 30MPH IN THE RAIN (Driving too fast, only coaster brakes, locked 'em up)
BROKE MY SCAPHOID BONE IN MY RIGHT WRIST (Caught my 30MPH fall with my hand)
Bent back wheel (And I had just installed a new one!!! No more smooth ride)
Smashed adjustment screws on clutch grip (At least it still works)
Slightly damaged throttle grip (Now it's a little sticky. Hello Cruise control )
Cracked headlight (Nothing a little super glue can't repair)
What I'll do next week:
Switch throttle control to brake style squeeze lever so I can ride with a broken wrist (...)
SLOW DOWN WHEN RIDING IN THE RAIN (Shoulda done it in the first place)
Continue to have fun. (This hobby is way too fun to give up.)
Well, after all I've done to it, there's no way I'm gonna park it 'til the cast comes off.
The injury is gonna slow down my upgrades, but not my riding. I may take it easy though.
Tags
MotorBicycling.com
