Old 04-27-2012, 09:17 PM
GearNut's Avatar
GearNut GearNut is offline
I repaired the exhaust and rode it around the neighborhood for a whole whopping 0.7 miles.
According to the cheap Schwinn speedo I hit 31mph, was not trying to go that fast either.
It sounds good and has a little bit more hill climbing ability now.
The_Aleman:
________________________
ROTFLMAO!!!!!!
Old 04-27-2012, 10:35 PM
happycheapskate's Avatar
Smile Re: what did you do to your motor bike today?
I pulled my daughter in her kid trailer, to the neighborhood playground. My wife got off work early, so she carried her home after we ate, and I put the trailer in the car. I raced my wife back home the 5 miles from the park. My wife beat by less than 5 minutes. ;-)
1" roller Dax Friction Drive and Tanaka 3300 with mods.
Old 04-27-2012, 10:52 PM
Allen_Wrench's Avatar
Allen_Wrench Allen_Wrench is offline
Resident Mad Scientist
Well, I finished brazing my aluminum tank. Now I have to wait for my sealant to come in. Then comes surface finishing and priming. Then painting. At least the hard part is over. I may take a final picture of the finished product.
"There is nothing wrong with wanting a motorbike that is an extension of your personal taste and fashion sense; if you must ride somewhere, I say do it with style!"
Old 04-27-2012, 11:23 PM
ProMcCown's Avatar
ProMcCown ProMcCown is offline
Today I soldered and redrilled my NT jet smaller, and I'm liking it. Before my bike would bog down at high rpm, and now it just flows up the rpm until it tops out. I need to change the idle a little bit because it sounded like it was idling a little high. And I'll do a plug chop. I also purchased a rustoleum color changing paint to paint the gas tank and handle bars to compliment the color of the frame. I know I'm still new to this but I really like it!
AMF Beach Cruiser with 66cc engine kit.
Old 04-28-2012, 10:16 PM
1flyingfool's Avatar
1flyingfool 1flyingfool is offline
I rode to Lacey, from Yelm, and broke down. The woodruf key came out,my fault, it broke one other time and I had to put a gear and the key, when I put the first one in,I didn't get it right. that is all, I had to pedal about 3mils,I was hating life. I cauught the bus most of the way, I had to lift it up and down 4 times and I had stuff in the saddel carrier in the rear.Got home and fixed again,this time I was real carfel abou it this time. Then I worked on the new boat garage. Well tomarrow is another day and if it goes well I'll get the lawn mowed. Thanks all.
Old 04-28-2012, 11:22 PM
superharry's Avatar
superharry superharry is offline
I'm pretty sure I fixed the ding in my fuel tank filler. it was seeping just enough to ruin my paint .lol
It's all nuts and bolts...
Old 04-29-2012, 12:25 AM
GearNut's Avatar
I rotated the air in the tires again.
So much fun!
The_Aleman:
ROTFLMAO!!!!!!
Old 04-29-2012, 07:49 AM
robbomberbomyea's Avatar
robbomberbomyea robbomberbomyea is offline
stillbreaking in occ, mounted sprocket adapter on drifter,next to mount the 40t sprocket had 36on cranbrook good top end but light off the line hoping the 40 will do the trick on the drifter.one reason i love the adapter is easy to change gear size.motor shipped should be here in week or so. went with pirate cycles pk-80 silver,had good luck with it on the cranbrook.
Old 04-29-2012, 05:15 PM
GAS+RIDEZ's Avatar
GAS+RIDEZ GAS+RIDEZ is offline
In this days have mount a rear handbrake, My current brake setup is a coaster brake and a front handbrake,mount rear handbrake because coaster brake lever have broke thrice.
Old 04-29-2012, 05:58 PM
GAS+RIDEZ's Avatar
I've Have noticed on these days my gasoline tank switch was not doing his work on stoping gas flow,was trying to get one but not found and went to Home Depot and have to buy 3 part to make the gas line connection,after went to an Motorcycle store to buy gas line,filter and tank switch.
Tags
MotorBicycling.com
