Old 04-25-2012, 06:14 PM
DaveC's Avatar
DaveC DaveC is offline
C'mon.... there's at least 10-15 miles left in that tire
Old 04-25-2012, 07:32 PM
robbomberbomyea's Avatar
robbomberbomyea robbomberbomyea is offline
wow thats crazy....trimmed fender for my occ,actualy kick started,then rode it in rain.got lil wet well alot wet,but still fun.
Old 04-25-2012, 08:21 PM
happycheapskate's Avatar
http://us4.memecdn.com/mainstream_o_289106.jpg 2x4 hipster bike
That's crazy! Someone asked me about my motorized bicycle a couple days ago. At first I thought he was serious, but he wanted to put a friction drive on his crummy BMX with 1 out-of-whack brake. I told him I wouldn't touch it with a 10 foot pole. He said, well what if I just buy the motor thing and do it myself? I told him I couldn't stop him, but I don't think he should since he can't even fix his bike now. He started talking in some kind of wigger rap lingo, so I just left him alone. Weird!
Originally Posted by killercanuck View Post
Got my Clutch Roller from Al.Fisherman installed. One finger pull is the "Cat's Pajamas", truly silky. Thanks Ron!
(disregard the carb, I'm working on a new intake)
[IMG]http://i1032.photobucket.com/albums/a408/killercanuck77/29er/SAM_0290.jpg[/IMG
Oh, and someone stopped by to get something he "built"(ie slapped together) running... friggin thing was a death trap. I warned all I could, but he didn't want to listen. Some lessons are better learned the hard way.
Things like:
he had no clutch disengagement- cable not tight enough
carb slide was backwards-stuck at wot,
no kill switch! with the above 2!!
His cdi was fried either out of the box, or by backwards wiring...
I got him as safe as I could, fixed the issues above, sold him a spare cdi and it fired right up. Felt sick as he drove away thinking he can "build" like anyone...
He's lucky it didn't start when he tried it, as his brakes were crap too...
Scary what some people think they can ride...
[IMG]http://i1032.photobucket.com/albums/a408/killercanuck77/Misc/SAM_0286.jpg[/IMG
Know what I mean?
Snuck that pic when he was in the can
1" roller Dax Friction Drive and Tanaka 3300 with mods.
Old 04-25-2012, 08:31 PM
I went for a ride with the 1 gallon tank on the front rack. I'm not sure I like it. It might be overkill. It totally changed the bike handling with any more than a quart in it. I think I'll take the stem riser off and just run it like this for the summer, until I figure out a different way to run more than the weeder tank and not spend a bunch of cash.
I have found a couple of go-kart white plastic tanks I could use, if I forego the cargo box (sad), and have thought about various dual-tank set ups, including a 1/2 gallon Toro box shaped tank from a snow-blower.
Old 04-26-2012, 12:41 AM
Ibedayank's Avatar
Ibedayank Ibedayank is offline
just to show that Killer Canuck is not alone on finding such Gems...
http://motorbicycling.com/showthread...ewpost&t=38756
yes the frame has been cut
Live life as its your last day... it just may be
Learn to do it right or how to fix it later, quicker to do it right the first time.
Old 04-26-2012, 10:00 AM
killercanuck's Avatar
killercanuck killercanuck is offline
Heh heh, takes all kinds... For some, lessons are better learned the hard way when they don't want to listen to reason.
Sure, we were all newbies at one point or another, and most of the time common sense prevailed. If we didn't get it right the first time we figured out why and re-did it. We asked, we read, we learned and got better. That makes us much safer, if not smarter . So when people brush off good advice and common sense, all we can do is smile and say, "Good luck with that eh."
Cards, 29er, Trailer, Hack'em'up
Build with pride! Build to ride!
"A clean shop is a sure sign of a cluttered mind" ~ fasteddy
Old 04-26-2012, 10:09 AM
Hey Happy, have you thought of extending your rear rack and put the tank back there? and yea, you were right not to go near that bmx. Jeeze, if they can't even do basic bike repair... But you could've charged more to get the bike in working order first eh? Or break out a liability waiver, heh heh.
Lol RC, I had to go look up Lignin, but I doubt the guy was thinking of organic polymers when he stuffed those in there, heh heh. Maybe some Oak, or Hickory would fare better... but not a little chunk of pine
Old 04-26-2012, 10:39 AM
rustycase's Avatar
rustycase rustycase is offline
Gutter Rider
lol
well GOOD! u looked it up! :-)
lignin is a component of plant cell structure...
it's a good part of what gives wood it's strength and elasticity.
Wondrous stuff!
It's properties are probably among the reasons why something made of wood just 'feels' good, when placed alongside a metal, or composite item.
lol
wood has 'soul'!
rc
My goal is cheap, reliable, personal transport, below the tax collector radar. Fun counts for a lot!
Old 04-26-2012, 10:56 AM
Edit: Now I've got an idea!
http://upload.wikimedia.org/wikipedi...e-grin.svg.png
A cheap plastic cutting board is just the right size after chopping the "handle" off, to mount that 1 gallon tank. regular coarse screws will self-tap into that kind of plastic if you drill tight holes for the screws. (I've done it before.)
If one corner is drilled for the Dax pivot bolt, and the other corner drilled for 2 holes to mount to the stock holes opposite the engine (drilled on both sides for forward or reverse mount, how nice), the board can be mounted square with the drive channel, so it hangs down from it. This will put the tank in a pannier like position, and let it rest against the right tension strap for even more support. (spacers or washers required to bolt it to the engine pattern holes. This will also protect the backside of the tank from anything thrown by the wheels. Pictures to follow after parts arrive. Yay! This build has been a lot of fun.
I don't know how I could extend the dax channel without causing drive wheel skipping or strain on the frame. I am planning to just run this for now, till I figure out another option. I'm thinking of one of the 4 quart flat tanks like this: http://www.usplastic.com/catalog/ima.../sku/8663p.jpg
http://www.usplastic.com/catalog/ite...1881&catid=578
With 1 gallon flat tank, plus the stock tank, I can go 100 miles with up to 20lb cargo and I will be able to put my lunch cooler back on the front rack.
I will have to wait till I get it to see the size of it, but I may be able to fold a piece of sheet metal over the top tube, and clamp it together with the mounting bolts for this tank, so it sits center frame, near the seat tube. That would balance well.
If it can hang by the tab on one side without busting off, that would make mounting a breeze! I could mount it to the u-bracket or the side straps , esp the small ones like 2 quarts. I'll call them.
Here's a cheap option for a 1 quart booster tank
http://www.facebook.com/l.php?u=http...XuSafV_zSmBA5g
go ped tank $21 shipped with grommet and lines.
O-reilleys has these for $10-15
$15, 24 oz, can mount straight onto tension strap in vertical position
http://images.oreillyauto.com/parts/...9-1674-007.jpg
Old 04-26-2012, 07:12 PM
Scootmeister Scootmeister is offline
Took my Whizzer out for a spin to tune it for a Relay for Life run on Saturday. 2 miles into the trip a car pulled out in front of me. When I slammed on the brakes I locked up the rear wheel and heard a loud clang and felt a jerk. It was a bad feeling. I limped back home and removed the rear wheel to find the coaster brake lever broken in two places. When I removed the lever to weld the break I realized it's made from pot metal!!! Tomorrow I'll be fabricating a real steel brake lever.
"If bulls didn't have horns, everyone would be a Matador".
Tags
MotorBicycling.com
