Old 04-10-2012, 09:19 PM
happycheapskate's Avatar
Please post your results on http://www.facebook.com/pages/Dax-Fr...18445778250153 Dax Fan Club
I have been wondering the same thing! http://waldsports.com/index.cfm/wald...ingbasket.html
Probably cheaper at Niagaracycle. I think you get 2 in a set.
You could get some All Thread, bend it in a couple places , and run it through 4 drilled holes in the friction drive channel, for a place to hook panniers. Then use a conduit bracket or something to tie the rack to the seat stay. Good luck! Send pics!
https://www.google.com/images?q=tbn:...xexRM3_9yrPVhQ
I bet they will be noisy, but if the drive doesn't flex a lot, it should work fine, opposite the engine and gas. I think you might have to reinforce the drive channel though (some cross bolts and nuts inside and outside the box). I drilled through mine to mount that little plastic bin for the reflector tape and spares. The metal was fairly easy to cut through, and didn't flake any, but it was pretty stout.
Adding extra nuts on the u-bracket bolts helped me a lot too. (bolt through bracket, nut, then mounting plate, washer, lock washer, nut, nut. )
1" roller Dax Friction Drive and Tanaka 3300 with mods.
Old 04-10-2012, 09:24 PM
rustycase's Avatar
rustycase rustycase is offline
Gutter Rider
Didn't get a round tuit today, but I eyeballed the chain alignment... it actually doesn't look bad so as to throw the chain.
The rag joint does have a warble though. gotta fix that.
VERY nice Kalifornia day, today.
i shoulda been riding!
rc
My goal is cheap, reliable, personal transport, below the tax collector radar. Fun counts for a lot!
Old 04-10-2012, 09:32 PM
kings has clamshell mounts, and a forum member Sgt. Howard sells US-made heavy duty 3pc clamshells that take the Grubee cogs. I got one and it's thick!
Old 04-10-2012, 11:02 PM
rc
After many chain jumping issues previously, I bought this chain alignment tool:
http://www.ebay.com/itm/Motion-Pro-C...c9ab29&vxp=mtr
Old 04-11-2012, 11:11 PM
Spaz_Static's Avatar
Spaz_Static Spaz_Static is offline
Resoldered the ground on my mag, which resolved my issue of my engine not running, and promptly took her for a short jaunt considering she had been out of commission for about two weeks, between that and the installation of my shift kit.
I also applied a thread locker to jackshaft screws, and some silicone between my carb and intake pipe (had to re apply it for air leaks because I had to take my carb off for getting the jack shaft on).
Tomorrow, I may start assembly of the x chamber... if I have time. I owe my girlfriend a date. Oh well, its supposed to be cold and windy yet again tomorrow. Not my favorite riding weather.
Old 04-13-2012, 02:32 PM
darkhawk22's Avatar
darkhawk22 darkhawk22 is offline
Took the bike up to the old house up the road today and got a pic. Jetted down to #68 and haven't noticed a real dramatic difference maybe a little less 4-stroking at WOT. Re-mounted the light but still not happy with the bracket so I have to fabricate another one.
Currently no bike but thinking about starting a new build soon.
Old 04-13-2012, 02:54 PM
I trued my front wheel, replaced the rim tape with Gorilla Tape, my favorite, and soldered the wires back onto my speedo computer. They got yanked out the other day. I figured it was worth a try, and it seems to work ok.
Old 04-13-2012, 03:19 PM
jowens's Avatar
jowens jowens is offline
Have been going on break in runs now that I have my Predator built. Im loving this build so far, very smooth ride.
Old 04-13-2012, 03:56 PM
GearNut's Avatar
GearNut GearNut is offline
I removed the exhaust that I made for it and took it over to FSI to have it Jet Hot coated.
2 Fridays from now I will get it back. Until then she sits... waiting...
The_Aleman:
________________________
ROTFLMAO!!!!!!
Old 04-13-2012, 04:14 PM
rustycase's Avatar
Gutter Rider
What is 'JetHot' coating?
Sounds good!
HCS... I kinda like that schwinn avenue bike.
Where can I get a bargain deal on those fancy wheels in the following pics?
I'd like to try them one day. :-)
rc
Tags
MotorBicycling.com
