Old 04-05-2012, 07:53 PM
Scootmeister Scootmeister is offline
I finally replaced the SS bicycle chains on my Stiletto Bobber with KMC H410 BMX chains. I have a primary drive chain from the engine to the jackshaft, and a main drive chain from the right side of the jackshaft to the wheel. The new chains fit the sprockets much better due to the larger rollers, and there is less movement in the chain while I'm riding. I can't imagine these KMC chains will ever wear out on an MB, unlike my kit 415 chains that started cracking from continued use.
Old 04-06-2012, 02:30 AM
Originally Posted by Dan View Post
Sounds cool 5-7.
Pics?
I'll have my son shoot pics soon.
Old 04-06-2012, 09:23 AM
Hey 5-7, where do you get the motor mounts? I've been making my own from strap hinges or using Kuryakyn clamps which are pricey. How do torque-verters work? Do they change the ratio? I've thought about using a variable pulley but they seem to self-adjust at very low RPMs, around 1400. I'd like to find a manual pulley that can be controlled with a cable. Do you know of any? I had one on an old Allis Chalmers garden trator but it was heavy cast iron. An aluminum unit would work at our HP levels.
Old 04-06-2012, 02:03 PM
motor_bike_fanatic motor_bike_fanatic is offline
took my pocketbike xchamber to a machine shop and had it welded together today. I previosly had it put together with fiberglass and painted with hi-temp paint, but the fiberglass still failed. they mig welded it, and it cost me $30. well worth it in my opinion.
STRICTLY FOR MY NINJAS
"and my time is a piece of wax, fallin' on a termite, that's chokin' on the splinters"
"If we change the way we look at things, the things we look at will change"
Old 04-06-2012, 04:07 PM
happycheapskate's Avatar
The KMC chains will eventually wear, because they are bushingless designs, with stamped ridges that the rollers ride on. The plates are strong, though. But keep a 12" steel ruler and check your chain wear by measuring at the pins from 0 to 12" , with chain under tension.
1" roller Dax Friction Drive and Tanaka 3300 with mods.
Old 04-06-2012, 09:16 PM
I have a couple of 4-stroke motor mounting plates around. Either that or a simple 1/8" steel plate welded to the bike frame. Top mount prolly steel or aluminum plate and muffler clamp onto the down tube. I haven't mounted the Robin yet.
The Torq-Verter I have changes ratios from .9:1 to 2.7:1. Methinks you need an initial gear ratio of 8:1. Then your bike should launch HARD @ 21.6:1 and cruise @ 7.2:1. However, it is VERY difficult to make 8:1 on a single jackshaft. On my setup, I would need a custom-made 64t rear sprocket to fit my Motobecane rear drum. The lowest gearing I can muster now is a 52t rear sprocket and an 8-tooth jackshaft gear, which equals to 6.75:1. That means I would need a SECOND jackshaft with 12t/10t sprockets. So, 6.75 x 1.2 = 8.1:1 gearing.
That's with the Torq-Verter.
Sorry, I know nothing about manual pulleys.
The frame of the Torq-V is basically a jackshaft plate. I can remove the pulleys and belt, and install a MaxiTorque clutch w/10t sprocket. The Torq-V's shaft will hold a 12t sprocket on the outboard side. An 8t sprocket will mount inboard on the Torq-V's lengthened jackshaft. This 8t then chains up to the 54t rear wheel sprocket, resulting in 8.1:1 gearing.
That's strictly gearing, no Torq-Verter.
Old 04-06-2012, 10:30 PM
Skarrd's Avatar
Skarrd Skarrd is offline
got some more #41 chain in, along with a 14t #41 sprocket for the engine side jackshaft. bolted up the SBP jack shaft plate, and chain tensioner. tightened it up and ran it. she ran wonderfully! shook a bit but i was able to easily just floor it and it locked up and took off. will need to adjust the clutch some more (and get a picture of the area i drilled to lighten the shoes)
just need to shorten the engine chain, and figure out about a charging circuit for a 12v battery for the electronics; wideband o2 sensor, brake lights, and turn signal lights.
once i get the charger working i'll try to do a write up on all the electronics i'm putting on.
i figured i could get a much more accurate tune if i use a wideband o2 sensor rather than reading the plug.
They see me rollin'
they hatin'
Originally Posted by biknut View Post
Traditional bicycle riders think we're cheaters. Non riders think our bikes are toys. Bicycle shops think we're a threat. Tree huggers think we're polluters. The police don't know what to think.
Old 04-06-2012, 11:29 PM
Ibedayank's Avatar
Ibedayank Ibedayank is offline
Originally Posted by 5-7HEAVEN View Post
My new Roadmaster/Cleveland steel frame arrived, so I trial-fitted a 6 hp Robin engine to it.
Robin fits well without the aftermarket motor mount, should be okay with it on.
I'm following Glennbo's 212/Roadmaster build. I ordered the same antenna mounts for the jackshaft, also 8t/9t/10t/12t sprockets. Rear sprocket will be 54t.
Unsure if I'll run 7.2:1 gears only, or Torq-Verter w/8.1 sprockets.
Also removed the engine governor and disconnected the low-oil sensor.
Awaiting more parts.
cvt with your 54 tooth gives you a low of around 14-1 and a high of 5-1
over 50mph at 3600 rpm
Live life as its your last day... it just may be
Learn to do it right or how to fix it later, quicker to do it right the first time.
Old 04-06-2012, 11:47 PM
Yes, I know.
However, methinks my bike will not like cruising @ 5:1, especially when approaching a hill.
54t/8t = 6.75:1
6.75 x 2.7 = 18.225:1
6.75 x .9 = 6.075:1
53mph @ 5,000rpm(no governor)
Robin will like taking off @ 18.225:1
Robin will not enjoy climbing hills @ 6.075:1.
Purely conjecture.
What I'll do is try out the TAV jackshaft plate with 12t/10t sprockets, along with 54t/9t sprockets. That's 7.2:1 gears. Then I can experiment with the TAV-2 with 54t/8t gears. If Robin doesn't like the 6.075:1 high gear, then a second jackshaft needs to be fabbed to lower gearing, close to 7.2:1.
(12t/10t) x (54t/8t) x .9 = 7.29 to 1 gear.
44mph @ 5,000rpm.
Time will tell.
Old 04-07-2012, 02:26 AM
fugit's Avatar
fugit fugit is offline
I fired up my second build today using the 66cc motor on a 3g Isla Vista. She went chug chug chug varooooommmmm....
Pirate Adapter/Sprocket/Chain upgrade. Manic's moutor mounts. That baby frigging sruises. I stripped out the kill switch throttle housing somehow so the throttle goes past the "0" point forward and kicks the cable out of the housing. I ordered a new kill switch to correct.
But I stil lam breaking it in I just need to be a bit careful not to push thrpottle past that point. I have the needle valve set to 2nd to lowest setting to start but opened her up and put on third from bottom. Checked everything for tightness.
Also, bought a wireless turn signals ( bicygnals) and set all that up but ended up removing them. They are not working right for me for some reason. They worked fine without the bike started but after rolling around with engine on the back turn indicators didnt work. I tried it a few times but I think that they vibrate too much and that screws up the "synchronicity" between units and/ or some how the 2.4 ghz signal gets jammed. Oh well
I will try the cheap chinese ones next.
Tags
MotorBicycling.com
