Old 12-14-2010, 06:32 AM
WildAlaskan's Avatar
WildAlaskan WildAlaskan is offline
well i woke up thi morning and smelled gasoline so i knew my bike was leaking i was so tired i jus put it out side (i dont have a petcock) i figured it was just a hose or something but when i fuled it up and went for spin it wouldnt start i think it was flooded
well anyway i needed to go to work so i pulled out my dads bike that was running perfectly fine before winter and tried to start it i couldnt i was dripping sweat after many attemps to start but had to get a ride for work very sad day
now i gotta figure out whats the problem
~~~ __o
~~~ _ <_
~~~ (_)/(_)
Old 12-14-2010, 04:54 PM
killercanuck's Avatar
killercanuck killercanuck is offline
Good luck, hopefully its nothing serious!
Cards, 29er, Trailer, Hack'em'up
Build with pride! Build to ride!
"A clean shop is a sure sign of a cluttered mind" ~ fasteddy
Old 12-14-2010, 05:02 PM
Dan's Avatar
Dan Dan is offline
Staff
Originally Posted by WildAlaskan View Post
well today i took my new peddal bike out for a spin and i honestly forgot how much work it was to peddal around i am exausted i cant wait to get a motor on it i still need a name though im thinking something with wild in it like wildrider or wild green since its green or i dont know i dont really have that kind of imagination maybe money pit or suicide ride
YouTube - Wild Thing-The Troggs (High Quality)
Just a thought WA. Sounded like ya had a rough one today and a lil head banging, make yer ears bleed loud motorized bicycle theme music always helps. Snork
Each one of my motorized bicycles sort of get an unofficial theme tune. I have found some songs just naturally play in my head for the personality of each MB.
Have a better one tomorrow!
worst apocalypse ever
http://www.youtube.com/watch?v=y6Sxv-sUYtM
Old 12-14-2010, 05:20 PM
solokumba's Avatar
solokumba solokumba is offline
Made me some fender stops.
I may be slow, but I'm not very accurate.
Old 12-14-2010, 06:23 PM
bairdco's Avatar
bairdco bairdco is offline
a guy who makes cool bikes
rode all over on my trusty 24" to get parts for the souped-up 26."
came home, and got the new bike running. the mikuni needs to be tuned, but it started first try with no choke. yay!
Old 12-14-2010, 07:29 PM
chrisme chrisme is offline
I spent half an hour searching craigslist for a small engine to make a new build for my deceased MB... I guess that counts as working on it.
Old 12-14-2010, 08:56 PM
Dan's Avatar
Dan Dan is offline
Staff
Research counts Chrisme.
Sorry to hear your bike is no more
Old 12-14-2010, 09:17 PM
Thanks Dan. I had it coming... But I do miss the thing.
I blew the HT over the summer to the point of needing a total rebuild. So I'm going to go complete DIY and do my own build. I think after the experience I had with that, and the knowledge of people on here I can make something work!
Old 12-15-2010, 06:16 AM
ok so update on my motorized bicycle i was too lazy too pedal start my motor so i used a power drill and a socket on the mag bolt to turn eer over
it took a long time to start and the entire crank case was full of gas cause it all came spewing out but after a while i got it started then after about four or five minutes it died i went to check on it and the fuel was leaking ou the carb so i drained the tank completly took apart the carb and found nothing wrong the needle valve was seeling perfectly fine and the float was water proof so i put it back together and it stoped leaking
i didnt find anything inside so i assume condensation froze or something im gonna start putting heat in my fuel every tank full to protect from flooding
i didnt really have enough time to put it together before work so i bummed a ride
tommorow its supposed to be really windy out there i cant wait 0 degrees wind and then more wind from going fast
~~~ __o
~~~ _ <_
~~~ (_)/(_)
Old 12-15-2010, 06:20 AM
ohh i fogot to mention when i was starting my bike with a drill and had the mag cover off i noticed that the crank itself moves in and out easily by hand and moves about a 3/16 of an inch what could cause this bad bearing or has it been like this since day one
~~~ __o
~~~ _ <_
~~~ (_)/(_)
Tags
MotorBicycling.com
