Old 01-05-2012, 07:02 AM
I made a new front motor mount from 1/4" aluminum. Now the chain can be adjusted. All it takes is 1/4-3/8" adjustment. Just finished @ 2am.
Can't wait for daylight to commute to work!
Old 01-05-2012, 09:28 PM
Skarrd's Avatar
Skarrd Skarrd is offline
got a new spark plug in that should prove much better than a normal plug.
i'll let the pictures do the talking.
it's a NGK BU8H
They see me rollin'
they hatin'
Originally Posted by biknut View Post
Traditional bicycle riders think we're cheaters. Non riders think our bikes are toys. Bicycle shops think we're a threat. Tree huggers think we're polluters. The police don't know what to think.
Old 01-05-2012, 11:04 PM
CTripps's Avatar
CTripps CTripps is offline
Finally had a break in the weather so I got to ride to work today. Good run each way, had to tighten a couple of spokes before heading home, but that's why the spoke wrench lives on the 'biner with my keys. It's the original rim, so a few loosen up a bit sometimes.
It still has that 'new muffler smell' but that should fade in a couple more rides. I haven't got the lights aimed quite right yet. They helped in the blind curve, but aren't throwing the light far enough ahead for me right now.
CT
Any day that starts with a good ride is already a better day, and a bad day riding still beats a good day working.
My Builds: My Beast, Harley59's bike, my Cruiser
Old 01-05-2012, 11:33 PM
GearNut's Avatar
GearNut GearNut is offline
it's a NGK BU8H
Please let us know how it works out.
That is quite an interesting looking plug for use in an engine.
It resembles a mechanic's test plug.
The_Aleman:
________________________
ROTFLMAO!!!!!!
Old 01-05-2012, 11:50 PM
rustycase's Avatar
rustycase rustycase is offline
Gutter Rider
The plug sure fills the hole a lot better than a stock one, skaard! I'll bet it even bumps the compression a tad. Wonder if the coil has enuff poop to drive that plug???
Best
rc
Old 01-06-2012, 04:48 AM
Fours of sleep and I was biking to work. Previously the chain was as tight as "high G" on a guitar! After the new motor mount was installed, chain adjustment was good. Tension was the same at day's end. Previously, with the old mount and a Chinese freewheel, the chain would tense and loosen within a few strokes, then tense up again. Now, chain tension is spot on and consistent. i can sense there is less undue tension on the chain, freewheel, sprocket, even the bottom bracket cartridge.
The ride to and from work went without incident. You never know how the commute will go without a test ride.
I had been searching locally for M6-80mm length allen bolts for years. The correct bolts were found on McMaster-Carr reasonably priced. They arrived today and were quickly installed.
I can't wait for daylight and my commute to work!
Old 01-06-2012, 06:23 PM
anim8r's Avatar
anim8r anim8r is offline
It was almost 60 degrees F today, January 6th, in Michigan. Had to go for a ride.
Jml
.7 1
Old 01-06-2012, 07:15 PM
GearNut's Avatar
I rolled it out the back door of my garage so I would have room to work on my air compressor.
The_Aleman:
ROTFLMAO!!!!!!
Old 01-06-2012, 08:10 PM
Skarrd's Avatar
MM gen 2 head: check
BU8H NGK plug: check
Piston to head clearance: check
dellorto clone carb: check
*starts bike* super low compression (didn't let rtv cure long enough)
me: balls to it.. *keeps pedaling until engine starts catching. then give a gentle lap around neighborhood, stops, checks the bike. starts it (harder to start this time).*
*gave it gas*
me: HOLY S***!!! *hangs on for dear life!!!*
verdict... this bike owns my last build now!
They see me rollin'
they hatin'
Old 01-06-2012, 10:22 PM
MEASURE TWICE MEASURE TWICE is offline
Got stainless steel tubing for exhaust system out back of motorbike. 3 ft with 3/4 thread and two adapters to add at ends to make it to 1/2 pipe thread on the Briggs engine/spark arrestor muffler. Just will remove the rubber gasket for the water pipe use and put the Permatex 700 F copper forma-gasket stuff on the threads. Also go the clamps that I can hang the tube along with other brackets that I already have for assorted stuff to do on the bike. About $44 for the stuff for todays purchases.
Tags
MotorBicycling.com
