Old 12-21-2011, 07:52 AM
Jumpa's Avatar
Jumpa Jumpa is offline
I I dipped my C.D.I. into some liquid rubber "The stuff used on metal handles of wire cutters , Channies. etc".Before when ever it rained out it would get wet and short out Now it is 100% water proof folks,. I did the same thing to the servo's on my Nitro cars. Works great. I was worried about over heating on my servos but 2 years later & still no issues & still the same servos
Old 12-21-2011, 12:33 PM
Skarrd's Avatar
Skarrd Skarrd is offline
did some port work on the intake pipe. (mostly portmatching the flange to the pipe)
got a little more power but it still seems to bog a tiny bit if i floor it right away (especially in the higher gears)
rode it around alot until i realized my rear tire had gone flat, and had to push the bike about 4 miles home x_x
They see me rollin'
they hatin'
Originally Posted by biknut View Post
Traditional bicycle riders think we're cheaters. Non riders think our bikes are toys. Bicycle shops think we're a threat. Tree huggers think we're polluters. The police don't know what to think.
Old 12-21-2011, 01:53 PM
killercanuck's Avatar
killercanuck killercanuck is offline
d'oh, sucks pushing that far
Sorry I just thought of this, but I heard of a trick years ago for an emergency flat. What you do is get one tire bead off, and stuff it full of grass or leaves or whatever's handy. Stuff it enough so the beads will at least stay on long enough for you to limp home. Even slow pedaling is better than pushing, eh?
Been working on a unique fix for dual broken rear studs(came that way, bought it cheap), pics/thread soon.
Cards, 29er, Trailer, Hack'em'up
Build with pride! Build to ride!
"A clean shop is a sure sign of a cluttered mind" ~ fasteddy
Old 12-21-2011, 01:56 PM
scud's Avatar
scud scud is offline
just posted some pics and a video in the motorized cruiser section of the work I've done. check it out!
[IMG][/IMG]
Old 12-21-2011, 02:57 PM
I'm doing major preventive maintenance while on vacation.
New chains haven't arrived yet, so I scrounged up some 8mm pieces and assembled one. This will be my spare for now.
Gearbox is leakproof with no runout or wobbles. Seal is good. It's not as noisy as it was earlier this year. Clutch drum shows normal wear.
The 11t sprocket is showing normal wear; backlash between splines is increasing a smidge. They cost $8, so I'll order two more for spares.
The circlip that secures the 11t sprocket to the gearbox spline wore out and looks like a fishook! This is an engineering design defect; the sprocket diameter is too small. The 8mm chain passes so close to the snapring that it rubs against it at times, wearing one of the circlip's "eyes" to a sharp hook.. This is the SECOND time I'm replacing it in two years. A 14t sprocket would prolly have enough clearance between the snapring and the 8mm chain. However, if I did not install a larger engine chainring sprocket, it would drastically reduce my gear ratios from 46.36:1 to an ineffective 36.43:1. With a 14t, replacing the 72t with an expensive, hard-to-get 92t sprocket would change first gear back to 46.55:1. Their diameters would increase from 7.2" to 9.2", which MIGHT present clearance issues at the chainstay frame.
The expansion pipe's belly positions itself very close to the gearbox sprocket. If the snapring were to fail, the pipe would keep this sprocket and chain from falling off.
It's not worth paying $100 or more, replacing the 11t/72t sprockets to 14t/92t ones to cure this factory miscue. Besides the expansion pipe, a simple gear retainer could be fabbed to keep the sprocket from slipping off the gearshaft. A broken 9/16" circlip is only 40 cents, and is so easy to replace.
The Tanaka 3-piece expansion pipe needs to be better sealed at the slip-fit flanges. This is the reason why this exhaust is considered a loud pipe. With the correctly-sized sections of silicon hose, this engine-specific exhaust system should become more quiet. The pipe's belly is chafing on the 8mm chain 4" below the gearbox sprocket at times, so I'll need to correct that. The air cleaner is also chafing against the chrome resonator, so it'll need clearancing. This engine and pipe were engineered to fit on a gokart and a scooter, not a bicycle. Fitment is needed.
When I ran over an object on the wet road, it also damaged the chainring sprocket's freewheel. That caused even more sprocket wobble than normal. A used Chinese freewheel has been temporarily installed, while an SBP HD freewheel is having its 5-bolt pattern drilled to match the pocket bike sprocket's 4-bolt pattern.
Parts needed are three short pieces of exhaust hose, An 11t sprocket, one circlip and lube for the cables. I should also service my K&N air cleaner.
Preventive maintenance needs to be done on a regular basis, especially for a daily commuter.
Old 12-21-2011, 04:49 PM
DuctTapedGoat's Avatar
DuctTapedGoat DuctTapedGoat is offline
[IMG][/IMG]
Looking great Scud! What kind of rims are those?
http://unixfi.co/uk/MotorizedBicycle/48ccEdition.html
Old 12-21-2011, 09:42 PM
Skarrd's Avatar
ordered me this thing: Manic Mechanic Gen II Head BikeBerry.com
^_^ it's gonna be so awesome when i get it!
They see me rollin'
they hatin'
Old 12-21-2011, 10:47 PM
scud's Avatar
I got them online from Bicycle Wheel Warehouse
They are the Alienation PBR's in gold.
The warehouse will actually make rims to your specifications using their parts...rim color, spoke color, nipple color...type and color of hub. So if someone is willing to pay, they can get really creative!
Old 12-21-2011, 11:07 PM
That's awesome, the color sets it off, but they really do look like they're decent quality. I'ma bookmark that site.
Old 12-21-2011, 11:50 PM
scud's Avatar
yeah I'd say they're fairly high quality. if I haven't broken any spokes after a couple hundred miles then I'll consider it a success...because I would break spokes constantly with my stockers
Tags
MotorBicycling.com
