Old 10-05-2011, 10:25 PM
jowens's Avatar
jowens jowens is offline
Finally got the replacement magneto I have been waiting for. Got it installed and my bike fired up instantly....very happy about that....not happy about the engine going through two of them in succession....hoping this is not a common occurance and everything stays firing now....went for a 10 mile trip and seems fine....definately subsided the riding fix I was in dire need of....anyone else have problems with magnetos going out?
Old 10-05-2011, 11:16 PM
Scootmeister Scootmeister is offline
It was a beautiful day so I cut out for a quick ride. I had the "quiet muffler" installed and the bike was so quiet I could hardly tell it was running. The Nexus hub worked fine even though it was under water during hurricane Irene. I rode for a mile or two along the river, watching the shrimp boats going in the opposite direction. Everything was perfect right up to the point I threw the secondary drive chain. Initially I thought the problem was the 36-tooth Sick Bike Parts sprocket I recently installed on the on the wheel since the teeth on the new sprocket are not quite as long as those on other sprockets I have used. After closer inspection I realized that the rear wheel had moved forward throwing the sprocket out of alignment, causing it to throw the chain. Apparently I failed to tighten the wheel nuts when I removed and oiled the chain last week. This experience made me realize that there is one disadvantage to having a single drive chain, if it goes, there is no pedaling home. Anyway, it was a nice walk back and after reinstalling the chain I was able to complete my ride. The Red Hornet is a blast to ride!!!!
Old 10-06-2011, 12:52 AM
Mozenrath Mozenrath is offline
^^ Is this a muffler you bought or one that you made?
Old 10-06-2011, 02:30 AM
anim8r's Avatar
anim8r anim8r is offline
yeah, what Mozenrath said....
Jml
.7 1
Old 10-06-2011, 06:50 AM
darkhawk22's Avatar
darkhawk22 darkhawk22 is offline
Rode the bike for a short run, realized that I need to use the choke on my NT Speed carb now. For some reason I have never really had to use it and just tie wrapped it to make sure it wouldn't slip and cause the bike to choke during riding. Used the choke to start the bike and it starts right up. Also, I received my carbide light from eBay, I got a really good deal on it and almost want to get some carbide rock to use as it seems mechanically sound (all the parts are there and water valve works great). Now I just have to fabricate a bracket to hold it on.
Currently no bike but thinking about starting a new build soon.
Old 10-06-2011, 11:24 AM
Originally Posted by Blakenstein View Post
Went out for a ride..to CIBC bank ..to get bank account for PAY PAL only. After account was finalized, I deposited $250.oo The bank refused one of my $50.oo bills and said it was not real!!! Man did I get angry and told them that bill came from the TD bank and that it was real. So before taking it back to other bank, I rode my bike and took the bill to the RCMP station(federal cops) There, the security gaurd told me that it is only administration building and to go about 20 blocks away to get to the RCMP.
So, back on my bike and when I get there, its not the RCMP, but the Edmonton City Police!!!!! They told me that the bill is real!!!! Before I exchange it, I am going to find out how common this misprint is because if it is a one of a kind misprint, then collectors will pay good money for it. Any way my motorized bicycle took me on this run around and back home again. I was in the house, and the motor was iddleing outside, to cool down before turning it off. Just as I was going out the door to shut it off, it turned off all by itself.
That's why I only deal with $20 bills or smaller. If I get stuck with a counterfeit $20 or less, I can live with that. If I get burned with a $50 or $100 bill, I'd feel that pain for the rest of my life. Here's how it goes down at my bank:
"Let me have $1000 in cash, then deposit the rest".
"How would you like it? Hundreds?"
"No, I want it all in $20 bills."
"Sir, that's a lot of 20's".
"Yes, I know. I've been cashing my check like this every month for nine years".
Old 10-06-2011, 11:43 AM
happycheapskate's Avatar
Wow, that's brave, taking the strange bill to the police. I wonder what else can you do if you get an odd bill or a known fake, though. Kind of sucks, because if you don't deal in fakes and didn't know it was fake till a bank or teller said so, what can be done? If it is marked with the pen and changed color, no one else will take it either.
1" roller Dax Friction Drive and Tanaka 3300 with mods.
Old 10-06-2011, 11:44 AM
Scootmeister, do you have a thread about your silencer muffler?
Also, why not carry spare chains? I popped a motor chain once and started pedaling, then thought about it and was going to put it on the motor side, but I got a ride.
After that I started carrying a spare chain that could work on either side.
Old 10-07-2011, 09:11 PM
The muffler came with an early Chinagirl, it's the one where you can remove the endcap and baffle with a screw. The muffler came with a 66 cc Chinagirl so I'm thinking it is less restrictive on the 48cc chainsaw engine. I cut the original pipe off and welded a male 3/4" pipe fitting to the muffler so I can screw it into the female pipe fitting I welded to the exhaust pipe I fabricated from thick-walled steel conduit. I welded the other end of the specially bent conduit to a manifold I fabricated from heavy square steel pipe that bolts to the engine jug in place of the standard chain saw muffler. I fabricated a gasket from copper flashing to make sure the manifold doesn't leak. The beauty of this setup is I can unscrew the quiet muffler and screw on a standard Briggs and Stratton muffler with 3/4" threads for an unrestricted Bultaco sound. I can tell a real difference in the performance of the engine with the B & S muffler, but I like the quiet purr of the other muffler when I'm crusing through the neighborhood or town. If I want to "get on it" and take a spin along the river, it takes me 5 minutes to swap the mufflers out (as long as its not too hot).
Old 10-08-2011, 03:50 AM
Smile Re: what did you do to your motor bike today?
re: 48cc chainsaw engine hehehehe
moped short clip ride 5min.wmv - YouTube (my 48cc grubee with lawnmower muffler, all the time people tell me it sounds like a chainsaw lol)
Tags
MotorBicycling.com
