Old 07-11-2011, 03:00 PM
Dan's Avatar
Dan Dan is offline
Staff
Originally Posted by MotorizedEtc. View Post
I assembled my bike and took it for a test ride, works great! http://motorbicycling.com/f4/zipper-25cc-31554.html
Man, that is a cool looking MB. Never heard of them b4.
worst apocalypse ever
http://www.youtube.com/watch?v=y6Sxv-sUYtM
Old 07-11-2011, 03:10 PM
MarkSumpter's Avatar
MarkSumpter MarkSumpter is offline
The New Phone Books are here!!!
Not really but I couldn't pass up the chance to use a Steve Martin line but the new frame is definitely here:
http://zombiebikewerks.com/wp-conten...7/Stretch1.jpg
http://zombiebikewerks.com/wp-conten...7/Stretch2.jpg
http://zombiebikewerks.com/wp-conten...7/Stretch3.jpg
http://zombiebikewerks.com/wp-conten...7/Stretch5.jpg
http://zombiebikewerks.com/wp-conten...7/Stretch6.jpg
I posted the huge images to get a better look at the quality. Over all it is a decent frame but there is no tubed back bone or down tube per say it uses the stamped steel tank and front gusset in place of them. It looks like an easy frame to mod though for a gas engine and have an on board tank...
The Suzuki K10 forks fit like a glove but there will have to be some minor mods done before I am happy. I just cant wait to get the 1965 17x2.25" K10 front hub, rim and drum brake for it (suppose to be here on Saturday) and see how it sits with a 26" CBE-110 rear hub and rim...
Questions and suggestions will be appreciated for this one... I am still debating if I want to make it a 2 or 4 cycle...
Off to the shop for greasy hands...
Old 07-11-2011, 03:11 PM
I could only post 5 darnit here is the last:
http://zombiebikewerks.com/wp-conten...7/Stretch4.jpg
Old 07-11-2011, 03:12 PM
chrisme chrisme is offline
Tuned my bike to high octane fuel today... Advanced the timing (make, or buy an offset key), shaved the head a bit, and tuned and tuned, and re-tuned the carb. Port matching, etc, etc.
IT SCREAMS! I mounted my GPS on the handle bars and hit 39mph on flat ground (hard to find in Maine) with the 44t rear end. Which is only 4mph more than I was getting before. That's over 9000 RPMS!!!! But more than the top speed, the torque has made a huge increase. There are nothing but hills where I live, if I'm not going up a hill, I'm going down one, a little bit of flattish land between the hills. So it's greatly increased speed up hill.
One of the steepest, longest hills on my ride I only used to be able to pull up at about 12MPH. I mean a wicked steep hill. Now I can go up that very same hill at about 21.
I'm still going to keep it under 30. I feel it isn't safe/worth it to ride over 30. More sustained high RPMs will kill the engine faster. But I can get around much faster just because I can pull the hills so much quicker.
Old 07-11-2011, 04:50 PM
I was pleasantly surprised when my Tanaka 47R started easily and my bike rolled onto the street. The only problem was that the cassette gears were searching between the high gears. A visit to the bike shop after work is in order. The chain jumped off once enroute to work, so I'll adjust the Jump Stop
Since the expansion pipe's slip-joints are sealed, the engine is relatively quiet with no noxious exhaust leaks.
I'm also happy that the thirsty 47R pushed my bike almost six miles on a few ounces of gas.
I used my Fox chest protector on my ride to work today. My co-workers said I look like Transformers with all my gear on.
Old 07-11-2011, 08:35 PM
Wm Holden's Avatar
Wm Holden Wm Holden is offline
good job......
Old 07-11-2011, 08:57 PM
So I was out on a ride having fun, hit a bump. And the motor sputtered to death.... Pull over. Check the carb. Nothing wrong there. Pulled the bowl and the float and stuff was all working fine. Nothing clogged, etc. Checked spark...
Fortunately I carry a swiss army knife with me..
Pulled the magneto cover and there are three tiny coper wires coming out of the coil going to ground. One of them was broken off. So I scraped the coating off all of them, and used some strands of wire from the white wire I bound them back together again.
This repair made it 15 miles until it broke beyond side-of-the-road repair. So I ended up walking 3 miles home. Better than 18 miles.
My last side of the road repair (last week) was the carb drain screw coming out. The threads were stripped and it wasn't staying in great... I cut a bit of foam off my shoe and shoved it in the hole, that reduced it to a very slow leak which got me to work, and then back home at end of the day.
I love these bikes, so simple, simple problems, simple stuff to fix on the side of the road.
Old 07-11-2011, 09:00 PM
bishop letov's Avatar
bishop letov bishop letov is offline
Ok this is what I finished up last night..
Pvc pipe fender that I custom made.
Then stretched and primer etched, FInished
Mounted the weedwacker kill switch under my seat post:
Also mounts a few other things to make my ride enjoyable and up my performance factor streamlining my ride...
In the future,, Custom moulded front rack with headlight mount made from... PVC and vacuum formed around a rough cut wood mould, Wheel discs to cut down on the spoke drag and strengthen them, Lighting sytem using a stepper motor as an alternater lighting... 24 led lights and another to charge a 12v 18ah bat for a drill system alternative drive to help me up big hills.
ITs about how far your imagination can take you and your ability to imagine and put into production be it one off or mass quantities.
Three of my heros... Edison- ten thousand time for the light bulb then finally got it right, conviction
Ford- imagination to make things affordable,Passion
Tucker- Made a car way ahead of its time from helicopter engines- a light that turns when you turn the steering wheel innovation lexas got nothing on Tucker
Think about it...
Old 07-11-2011, 09:20 PM
wayne z's Avatar
wayne z wayne z is offline
Reached 100 miles today on my In Frame Predator Fricton Drive build. This thing rocks. Shows no tire wear or any other changes yet. Tops out at 38mph! cruises 30 very easy. No pedal assist needded for starts.
This concept of a large roller works very well. Gonna change to a 3.5" knurled roller and idler pulley manual clutch just to experiment.
Prolly end up with a Maxtorque bearing clutch later. I also want to try a grinding wheel for a drive roller to see how it affects tire wear and wet performance
Old 07-12-2011, 12:02 AM
rustycase's Avatar
rustycase rustycase is offline
Gutter Rider
Swapped my motor out to a different frame, then tried to mount the coaster rear wheel... NOT !
I need to learn how to dish a rear wheel, or switch the rag mount over to a cassette wheel. That's probably the best way to go?
Any advice on 'dishing' a rear wheel?
Tnx
rc
Tags
MotorBicycling.com
