Old 07-10-2011, 04:03 AM
happycheapskate's Avatar
I do all my own bike work. I get parts cheap too, from -- Bicycles, Bike parts, Mountain Bikes, BMX, Road Bikes, Haro Bikes, KHS Bikes, Felt Bikes at Niagara Cycle Works, nashbar, and sometimes a few others like e bikestop.
I don't understand why people (usually pedal bicyclist) want to shift under power. This causes so much more cassette and chain wear. Easing up just a little bit on the pedals (or the gas in your case) will let the chain just fall swiftly into the next gear without the hard CLUNK or worn or broken teeth.
Steel cassette gears will do much better, and a chain checker or metal ruler are essentials for keeping your drivetrain in check. Steel freewheels are still a good deal for heavy use, and can be had in the 34,28-13 varieties called "MegaRange".
1" roller Dax Friction Drive and Tanaka 3300 with mods.
Old 07-11-2011, 03:36 AM
Well, my motorized bicycle is fully assembled and ready for tommorow's commute. New exhaist gaskets were doubled where the OEM muffler bolts onto the expansion pipe's silencer. Both of the pipe's slip joints were treated with liquid muffler weld. Then they were wrapped in a saturated exhaust bandage. This should cure the exhaust leak I've been having.
While the engine was out, I opened the pocket bike gear box to check for damage. I had been hearing a noisy bearing, so now was a good time to check. All gears and bearings were still greased. The gearbox has grease not oil, which leaks out and makes a mess. The last time I worked on the box, I cleaned the mating surfaces, but did not replace the torn gasket or use sealer. This time, I cleaned and sealed the box well.
I have a spare gearbox handy, so I'll pull one of its bearings and find good quality replacement ones.
The exhaust fix should cure by 7am tomorrow, when I leave for work.
Honey, it's just a bicycle. and i REALLY need it to excercise, and to ride it to work.(hehe)
Old 07-11-2011, 03:45 AM
MotorizedEtc. MotorizedEtc. is offline
I assembled my bike and took it for a test ride, works great! http://motorbicycling.com/f4/zipper-25cc-31554.html
EZ Motorbike Dealer - Fremont, CA
Old 07-11-2011, 05:05 AM
DuctTapedGoat's Avatar
DuctTapedGoat DuctTapedGoat is offline
Got my CNSv2/GenB carb working by using a Manic Mechanic intake.
As well, I adjusted the float tang, put my drilled out NT air filter cover on, tightened the jets, and chopped the choke cable.
http://unixfi.co/uk/MotorizedBicycle/48ccEdition.html
Old 07-11-2011, 10:29 AM
Skarrd's Avatar
Skarrd Skarrd is offline
got my chain breaker in the mail, was able to break the (i think #41) chain apart.
They see me rollin'
they hatin'
Originally Posted by biknut View Post
Traditional bicycle riders think we're cheaters. Non riders think our bikes are toys. Bicycle shops think we're a threat. Tree huggers think we're polluters. The police don't know what to think.
Old 07-11-2011, 10:38 AM
MarkSumpter's Avatar
MarkSumpter MarkSumpter is offline
UPS Notification says my new frame is here and out for delivery... YIPPEEEEEE
*Taps Foot*
*Taps Foot*
*Taps Foot*
OH COME ON DARNIT!!!!!!!
Old 07-11-2011, 01:31 PM
flatblack flatblack is offline
Wrecked it...or more like it wrecked me. Brake mount broke. Brake fell locking up wheel.
Old 07-11-2011, 01:35 PM
road rash sucks but at least you are still breating...Bikes can be fixed but dead cant.
So wanna enlighten us on the cause of the spill? Might save others some pain...
Old 07-11-2011, 01:37 PM
http://motorbicycling.com/f3/scuffed...-me-31604.html
Old 07-11-2011, 02:38 PM
ducedave ducedave is offline
I have to fix the key on the 10t AGAIN -the 3rd time I swear the drive on this thing is going to be my undoing!-I weigh 185lb. if the key can't take that well I'll fix one more time but a mod is coming
Tags
MotorBicycling.com
