Old 05-21-2011, 04:10 PM
chrisme chrisme is offline
Originally Posted by Mike B View Post
Took it out for a ride, and much quieter, the stuff worked good.
Yep, amazing difference greasing those gears up.
I cut a piece of cardboard that fits inside the clutch cover. Free way to reduce noise by a serious amount.
When you're greasing it up, don't forget to pull off the sprocket cover, pull out the rod and bearing and put some grease in there too!!
Old 05-21-2011, 04:33 PM
Mike B's Avatar
Mike B Mike B is offline
This is the second time I greased. I use white lithium which comes in a little "toothpaste" type tube. I squeeze out a tiny dab (about the size of a BB) on my finger and apply to the big gear and rotate and repeat about 6 times with the sparkplug out. Then spin it a couple of wheel spins to distribute and it works real good. There wasn't a lot of splatter on the cover when I took it off.
The only thing in my garage with 4 wheels is the lawnmower
Old 05-21-2011, 04:39 PM
DuctTapedGoat's Avatar
DuctTapedGoat DuctTapedGoat is offline
I got my new sparkplug, bringing up the heat from a BR7HS to a BR5HS.
Popped by Wally World on the way home, and found a marine fuel connector setup (male and female for 3 bucks a piece).
So, now I'm going to connect it up into my gas can for a cheap gallon tank. Only thing is I need to fab up a cage for my luggage rack so I can securely mount it.
Old 05-21-2011, 04:40 PM
When I had my bike running, once a week I'd just put a little BB sized dab on the gear. You don't want too much in there. I think I used wheel bearing grease. But just because that's what I have.
Old 05-21-2011, 07:07 PM
mapbike's Avatar
mapbike mapbike is offline
How about some pics of that work your talking about here, I'm curious.....
Originally Posted by ducedave View Post
WOW! I spent all day well 12hrs. setting up a inline reed first I drilled out the piston and then a power port and reused the gaskets-had many vac leaks head and base so ride re-tork ride re-tork ride re-tork I finely got it to seat,then on to the reed cage I made it of 7 plates you know that had to leak and it did so I tighten it down 3 times and then ended up wrapping it in two part puddy that did the trick. I'll lean the carburetor and crimp the muffler stinger for the right back presser in the morning.
Old 05-21-2011, 08:03 PM
ducedave ducedave is offline
see you at willow spring on the 18-I don't have a digital camera
Old 05-21-2011, 09:21 PM
Goat Herder's Avatar
Gutter Rider
I road it..
Old 05-21-2011, 09:40 PM
ok I've got the bugs out of it. Gos like a shot!!!!!-dead spot after 40 if held wot I back off the throttle and it's good
Old 05-21-2011, 09:59 PM
mapbike's Avatar
No I dont guess I will see it then, I wont be at willow springs but I would really enjoy being there I'm sure.......
In the future if you do get a camera I would still liek to see what you have done, sounds like some very good work......
Be careful on that thing if it runs that good......
Peace
Old 05-21-2011, 10:33 PM
GearNut's Avatar
GearNut GearNut is offline
Started chopping and welding an old motorcycle engine guard to create a new exhaust system. So far I have the cylinder flange fabbed and match ported, cut the engine guard in two to give it the correct twist, and welded up the whole mess. A good start for a header. I plan on having the exhaust exit out the right side of the bike. It will cross over right behind the seat tube and come out between the pedal chain and chain guard.
The_Aleman:
________________________
ROTFLMAO!!!!!!
Tags
MotorBicycling.com
