Old 11-16-2010, 07:39 PM
WildAlaskan's Avatar
WildAlaskan WildAlaskan is offline
so a little back story the other day i took my clutch cover off the seal was leaking so there was oily gas in the case i drained it and felt lazy so i put the cover back on to work on it later but heres the thing my gasket broke so i just put the cover on anyway i thought it will be just fine but the clutch rubbed the case causing a very fine aluminum dust to get everywhere and the clutch was slippin very badly
so today i took eveything apart under the clutch case replaced the seal for crank took clutch pucks out sanded both sides and cleaned everything off when i went to start i was supprised at how quikly it turned over started right away
i also put better studs on the rear mount and tightened air intake manifold down it vibrated loose somhow
every thiong is running good now
~~~ __o
~~~ _ <_
~~~ (_)/(_)
Old 11-16-2010, 07:47 PM
Skarrd's Avatar
Skarrd Skarrd is offline
i found out that the 60second epoxy they sell at auto stores works great at sealing the carb too.
put some of it on today just out of curiosity. set quick and even after a good hour or so of riding it just got to a slightly squishy, but still gripped great.
also i think my float needs adjustment, seemed to be overflowing a little today as well
They see me rollin'
they hatin'
Originally Posted by biknut View Post
Traditional bicycle riders think we're cheaters. Non riders think our bikes are toys. Bicycle shops think we're a threat. Tree huggers think we're polluters. The police don't know what to think.
Old 11-17-2010, 01:28 AM
Hammond Egger Hammond Egger is offline
Built a taillight array for the back of my pannier rack to go underneath the M-wave topcase I put on it. That turned out real well. Prolubed the chains on both my bikes. I'm going to dedicate tomorrow trying to get my 2010 66cc GT5 to run half as good as my 2010 48cc GT2 does. It thinks it's a 4 stroke.
Old 11-17-2010, 01:53 AM
caduceus's Avatar
caduceus caduceus is offline
Ordered heavier clutch springs for my Grubee Stage-III centrifugal clutch. I'd like to get the stall speed up to around 2500rpm if I can.
Old 11-17-2010, 11:08 AM
Skarrd's Avatar
interesting... you don't need to pedal it at all when you go to start moving right? (just pull start to start the engine)
They see me rollin'
they hatin'
Old 11-17-2010, 06:41 PM
caduceus's Avatar
I usually push off, add a little throttle, swing a leg over and pedal a few times to get going. But with more engine rpms before the clutch engages I think the Honda GXH50 will be right on the pipe. I'll have to see.
Old 11-17-2010, 10:13 PM
Skarrd's Avatar
got bored and took the forks and tire off my occ stingray and put them on the mountain bike.
looks very odd and needs some type of spacer for it to fit right, but i like it!
They see me rollin'
they hatin'
Old 11-17-2010, 10:49 PM
Dan's Avatar
Dan Dan is offline
Staff
Cool, please post a pic if you can. Sounds great
worst apocalypse ever
http://www.youtube.com/watch?v=y6Sxv-sUYtM
Old 11-17-2010, 11:30 PM
Skarrd's Avatar
here ya go
They see me rollin'
they hatin'
Old 11-17-2010, 11:46 PM
Dan's Avatar
Dan Dan is offline
Staff
Wow, that does look cool Skarrd.
Tags
MotorBicycling.com
