Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > DIY Home Built Motorized Bicycle (non kit)
DIY Home Built Motorized Bicycle (non kit) Post all about your home built rides here. Weedwacker motors, lawn mower engines ect. This area is for non kit builds
Old 07-28-2008, 09:44 PM
handy_Biker handy_Biker is offline
Default Compression PSI 25cc vs 32cc
Since I built my bike with a 25cc homelite, I have inherited a couple more ( non running. Wondering what general condition these were in I hooked up a compression gauge and I get 90 lbs ( 100 if I try really hard)..
I also Have a Mculloch 32 cc weed eater , so I took a compression reading to that came to 125 lbs easy, and that got me to wondering...
I know the homelite only has one ring, I think this is pretty standard for two strokes.
The main question I have is, are most 25cc equal about 90 psi
and do most 32 cc equal about 120 psi
Old 07-28-2008, 11:20 PM
deacon's Avatar
deacon deacon is offline
minor bike philosopher
Default Re: Compression PSI 25cc vs 32cc
I dont have a way to measure it so this is pure antidotel but I can feel a big difference when I turn them over. How they act on the road I don't really know since i can't get my 25cc to run just now. I don't remember it being anywhere near as powerful but that could be because I was using a different drive system. Maybe someone else can tell us how they act as bike engines.
I do know my 31cc bolens pulls the bike along very well.
Old 07-29-2008, 08:17 AM
Bikeguy Joe's Avatar
90 is O.K. for a two stroke, it may be getting tired....70 will run, but not well. 120 is about the highest you see on a small two stroke.
Also, some engines have a higher or lower compression ratio which will make a difference in your readings, as will how fast you spin the engine, if you are doing it "dry" or "wet" and how the engine is ported.
Old 07-29-2008, 10:03 AM
I did the compression tests on three - 25cc homelites, dry, and they all read 90 psi. I added a couple of drops of regular motor oil to one of them, spun it several times, and got 100
I run one on my motored bike, and it does surprisingly well for what it is... can do ok on the flats, helps over the hiway overpasses, steep hills ( and theres lots of them here), it pretty well better to walk it than chew up the tire tryin LOL . Of course, if I weighed in at 150 or less, these lil homelites would do a lot better.
The Mac 32cc was tested dry and read 125 psi,
And as many others wonder, if using a 32 cc would be enough of an increase to make a difference.
Which now makes me wonder... how much PSI is there in one of the China kits ??
Old 07-29-2008, 02:30 PM
jasonh's Avatar
jasonh jasonh is offline
Well if nobody beats me to it, I'll see if I can bust out my compression gauge tonight and check.
Old 07-30-2008, 10:29 AM
jonboy2five jonboy2five is offline
that mc 32cc with 120+ compression wil be a BIG improvement to the homelite 25cc. like, try about 30% more power at least...go for it!
Old 07-30-2008, 10:32 AM
oh BTW, really high performance 2-strokes in racing motocross machines ALL have only one ring, and they absolutely rip! like 25hp from 125cc... divide those numbers by 5 and you see what i mean?
Old 07-30-2008, 10:59 AM
jasonh's Avatar
ok I suck, I didn't check the compression. Sorry.
