Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > High Performance Bicycle Engine Tips
High Performance Bicycle Engine Tips We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us.
Old 07-28-2008, 06:09 PM
Timcycle's Avatar
Timcycle Timcycle is offline
Default Mothballs and High Octane Results
Has anyone ever tried the ole racecar driver trick of melting a mothball in the gas to boost it to a higher octane performance?
http://goldeneaglebikeengine.blogspot.com
Blog Kit Build and Experience from June 2007
Golden Eagle Bike Engine ~ Subaru Robin 35cc 4 Stroke
Current miles : 2,664 ~ Parked due to broken spokes.
Old 07-28-2008, 06:27 PM
stude13 stude13 is offline
Default Re: Mothballs and High Octane Results
hi tim; i think m/b are made differently now. high octane is not good for these low compression engines. you can lap the head, remove base gasket, port exhaust, change plug and wire, port intake. when all that is done you might find you started with a low hp engine.
Old 07-28-2008, 06:41 PM
Bikeguy Joe's Avatar
Yep, these engines wll almost run on turpentine....higher octane would only make the fuel burn slower in these engines....if that's posible.
Old 07-28-2008, 10:12 PM
Timcycle's Avatar
Thanks. No mothballs to be used.
Tim
He broke a spoke
And spoke he's broke
So spare the bloke
The spare he broke
And give the bloke
A brand new spoke.
Old 07-29-2008, 10:46 AM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
Do Da! Do Da!
I didn't know moths had those?!
If moths could drink gas what would happen when they flew into a flame?!
SSSSSSSSHHHHHHHHboooom!!!!!!!
norms-iron-works.tripod.com
Old 07-29-2008, 11:43 AM
Ilikeabikea's Avatar
I was in the store one time and asked the clerk where could I find moth balls. He told me to look between thier legs..............
Old 07-30-2008, 03:00 PM
Norman's Avatar
Your a naughty boy Ilikeabikea why were you looking for the moths balls in the first place you old pervert. You said I was nasty I can't hold candle to you naughty boy. you still working on the toilet cam?
for those who don't know we both know each other an give each other grief as often as we can that is what good friends are all about?
Old 08-05-2008, 08:53 PM
shiloh0 shiloh0 is offline
mothballs between their legs...now that's funny
"You must cultivate the feeling that a warrior needs nothing"-don juan
