Old 10-09-2010, 09:26 PM
WildAlaskan's Avatar
WildAlaskan WildAlaskan is offline
Default Re: hello north florida
heres a couple others pics the first is another view of the pully itself it was grooved on a lathe
the second is a view of the bottom mount i used the original half round mount for the back and i drilled a hole in the top and bolted it straight to my frame i would have used other ways to secure it but i drilled the bottom mount holes already and didnt want to wait to buy another peice of steel
i have had no problems with this tensioner other than having to file more of the long groove on the flat bar so i could bring it to a higher tension its alot of work filing with a dull file and no money to buy a new one but all in all worked out well
if you can notice the groove in the skateboard wheel is slightly off center it wasnt intentional but turned out rather well it made it easier to adjust the wheel to match up with the sprocket on the wheel for finall adjustment i used washers moving them from one side of the pully to the other untill i lined up with the sproket if it isnt lined up good it will derail
Old 10-10-2010, 01:21 AM
scotto-'s Avatar
scotto- scotto- is offline
Custom 4-Stroke Bike Builder
Wink Re: hello north florida
Originally Posted by IamTheBear View Post
just got my bike motor on aand already ruined my rear rim gotta get that HD one. Plus upgraded my chain tensioner to a true roller bearing assembly, and drilled out to accept 3/8 bolt hard ware. Chinese mild metal just pissed me off.
Yes, heavy duty wheelsets are pretty much a must....especially for the rear. And welcome to the Forum by the way!
EZ Motorbike Dealer - San Diego, CA.
Nothing is out of my realm,
if it doesn't fit, make it fit! Beer is the answer....what was the question?
A sense of humor costs nothing, why don't people use them more often?
"You can't buy have to earn it"
Old 10-10-2010, 12:37 PM
IamTheBear IamTheBear is offline
think i'm gonna go with rim they are in florida so shipping time and cost are both low. I also have one of the OCC chopper frames to motorize gotta get this one working solid first. Anyone know if someone makes or had drilled a hub for a grease zerk, i go on the theory if it moves it needs regular grease. and taking apart a hub every 2 weeks to do it is just silly.
