Old 09-24-2010, 08:38 AM
moronic_kaos's Avatar
moronic_kaos moronic_kaos is offline
Default Gas-Resistant Rubber Grommets?
Got a weed whacker tank mounted up to the bike. Relatively low-profile & hidden compared to the stock tank that comes with the kit and has a tendency to collide with my knees (not to mention, seems to fit very loosely on the frame).
The only problem with the system is that the hole for the gas to go through was on the wrong end of the tank because weed whackers use a 2 or 3 line gas system so they can pump gas through in any direction, unlike our MBs. So I drilled a hole in the bottom of the tank & stuck a grommet in there and the line through that.
It works great for about twenty minutes or so, but the grommet expands as if it were a sponge, gets very brittle, and cracks along the edge of the plastic hole. Then I just get a big mess.
I've been to the following places:
  • Home Depot
  • True Value Hardware
  • Lowes
  • Tractor Supply
  • Autozone
All of which do not sell a rubber grommet rated for gasoline. Anyone know where to get one? I've found them for sale online, but they want in excess of 15 dollars which seems ridiculous for something so simple & tiny.
Super•Happy•Fun•Time (soo-per-hap-ee-fuhn-tahym) n, 1: The expression of time one
enjoys riding a Happy Time motorized vehicle. 2: A high-risk situation one participates in with a Happy Time motorized vehicle that society considers to be reckless, dangerous, and/or stupid. SEE Suicide.
Old 09-24-2010, 08:57 AM
BarelyAWake's Avatar
Default Re: Gas-Resistant Rubber Grommets?
To only compound the problem, you're not just looking for a gasoline resistant grommet, but an alcohol resistant one as well due to the ethanol content in today's fuels ... wish I could help you, but I'm suffering from similar problems - as are my marine technician friends & many others I'm sure
Aircraft Spruce & Specialty is a helpful company I called a few times when I was playing with ultralights, they've alcohol resistant fuel line readily available: BING ALCOHOL RESISTANT<br>FUEL LINE from Aircraft Spruce and as many ultralights and experimental aircraft use plastic tanks and grommets they may well have what you're looking for - just not in their online catalog... I'd give them a call.
As anything for "aviation" is subject to a serious price markup even if not FAA approved, get a part number & shop around
Old 09-24-2010, 12:07 PM
2door's Avatar
2door 2door is offline
Check your local Yellow Pages for a supplier of seals/gaskets and 'O' rings. There are several types of rubber-like compounds which are gasoline/alcohol/solvent resistant. Viton, comes to mind as well as others. There are teflon seals and 'O' rings which might fit your purpose. Good luck, let us know what you find.
This is a Denver company but most major cities will have a similiar supplier> http://www.rocketseals.com/
Old 09-24-2010, 12:28 PM
Kevlarr's Avatar
Kevlarr Kevlarr is offline
Check lawn equipment dealers in your area too, they'll have a much better selection of what you're looking for then any of the other places you listed.
Straight tubes suck, the beauty is in the bend.
Old 09-24-2010, 01:10 PM
r00t4rd3d r00t4rd3d is offline
Check your local ATV/Dirt Bike/Jet Ski shop. They normally have stuff like that or can get it. Neoprene washers will work with gas too.
Or the redneck method :
Cut a thin slice of gas line and use that for a washer/grommet/oring. Its what I do.
Old 09-24-2010, 01:25 PM
Dan's Avatar
Dan Dan is offline
Staff
"Just for now", 2 days ago I cut the tip off a chemical resistant rubber glove finger and wrapped it over a steel washer. Not suggesting it but has worked just for now. (read until it fails and I have to fix it, lol)
Was wondering, would nylon washers work? I am guessing if they did, you would see em used a lot. Will soak one in gas and check. Easily found an' cheap.
You could also just cut a thin slice of gas line and use that for a washer/grommet/oring. Its what I do.
Neoprene washers will hold up to gas also.
Purty cleaver R00t. Gonna try that
worst apocalypse ever
http://www.youtube.com/watch?v=y6Sxv-sUYtM
Old 09-24-2010, 01:31 PM
Squeeze the fuel line in a vise then slice it even with a razor blade. You can make a pile of them in no time for a fraction of the cost of actual rubber washers.
Old 09-24-2010, 04:12 PM
I couldn't see a washer ever working, since it would have no way to hold itself to the tank. The grommet has that groove in it that fits perfectly into the hole in the tank...
MotorBicycling.com
