Old 09-17-2010, 05:52 PM
kipharley's Avatar
kipharley kipharley is offline
Default Re: Master Link Jams
Originally Posted by bowljoman View Post
I read 'Master Link jams' And I thought he was talkin about a DJ
That's a pretty good one!
Old 09-17-2010, 06:37 PM
bairdco's Avatar
bairdco bairdco is offline
a guy who makes cool bikes
i have a good chain breaker, so you just put the links back together without the masterlink.
Old 09-18-2010, 08:05 PM
kicking kicking is offline
Thumbs up Re: Master Link Jams
Originally Posted by kipharley View Post
Where's it jamming? if it's jaming around the front sprocket then it sounds like KC has it nailed.If that's the case.I would just add that you should install the retaining clip so that the opening of the clip is trailing in the back during operation.
If not your chain could be jamming on the casting boss for the bottom screw of the cover.
If your chain is loose enough.
I mold metal putty on that little "shelf" on the casting boss and let it harden.In a Kinda 1/4 moon shape.Make sure you mold the putty so that the cover can be re-installed properly.
This creates a nice transion for the chain to follow and not catch.Also when you have that cover off check for chain wear marks on the cover expecially on the front "wall" of the cover if there is I notch the wall out a little wider than the chain for clearance,or you can file or dremil it for clearance.
While your at it pull out the clutch actuator rod.It's that 8mm round rod sticking out of your motor,Be carefull there's a ball bearing in there.
If the bearing stays in good.take a little dollop of grease and smear it in there.About the size of a small marble.
Then clean off your actuator rod and check it for wear marks along the sides.
I've seen them with burrs from where the factory cut them on one end and lathe cut off nipples on the other end.make sure it's de-burred and file the nipple off."Don't round the ends"Just take off the sharp edges.
Then I smooth the rod up with sand paper and grease it and re-install it.With a dollop of grease on the actuator end.
A little PM while you have it apart might help down the road!Kip
This was the fix that done it . The only place the chain was jamming was at the front sprocket ; and only at the master link . I done the putty modification with marine tex I had laying around . I made up some vegetable oil with charcoal pencil shavings and turned my chain by hand while smearing the oil with charcoal shavings on the chain . It showed the rub on the white putty until I grind it down . I also had some white ceramic paint to paint the inside of my clutch cover and done the same technique with the oil . Takes an while for paint to dry . But the word is patients on this kind of stuff .
I had to dremel the clutch cover too. I fed the chain around the sprocket without removing the clutch cover plate because the screws striped out and I could not remove it . ( I wanted to ride ! ) I got the hardware kit from sick bike parts and the striped screw remover from an friend who bought his at ; as seen on tv . I have since rode 8 miles without an jam . Fixing this problem had more to do than filing the nipples on the master link ; which I done that along with the cutch case modification . I turned the master link plate out too. One day I will cut my own chain and will never have an master link ( any new post on chain cutting without an master link subject along with tools and procedures would be an nice thread to have , but Iím hitting the search forums to see if there is an much needed road tools in an handle bar bag list. No master link may hurt you in an roadside break down . The master link was not the sole problem here ; but the nipples 'were' too far out and the plate is still more lose than I like it to be . ( seems to be wearing in but may be another jam waiting to happen on down the rode due to loose plate on master link ). This is my first build and the word so far is " modification " so thanks a lot and I will post pictures of my build on my post operation op before I bench my bike motor and do more much needed modifications. I think this was an worthy thread for an newby .
